twocantech
Multiple Pi 3's - wlan0's all have the same MAC address
Tue Nov 21, 2017 9:57 pm
Hi, I am using 4 Raspberry Pi 3's for a project, using a wireless network.
I have built the first SD card and then cloned the SD cards to give me 4 identical setups, however they all have the same MAC address on the wlan0 interface which means the router is treating them as the same device and issuing the same IP address to them all.
When I look at /proc/cpuinfo they all have different serial numbers.
I have tried looking at /var/udev rules to see if there is a persistant network rule, but could not locate any.
I have tried installing macchanger, but that does not appear to have fixed the problem.
Does anyone have any ideas how I can fix the wifi problem? Has anyone else experienced this issue?
I am hoping to avoid having to create new images and configure each one individually as I don't really have the time, but that is my backup plan.
Many thanks,
Richard
DirkS
Re: Multiple Pi 3's - wlan0's all have the same MAC address
Wed Nov 22, 2017 2:28 pm
How did you check that? ifconfig?
twocantech
Wed Nov 22, 2017 5:41 pm
Yeah, I used ifconfig and also
cat /sys/class/net/wlan0/address
Just to be sure.
mikerr
Wed Nov 22, 2017 5:48 pm
Seems it might be a problem with current batch
- someone else mentioned this on twitter today.
You can force a new Mac address like this:
ifconfig wlan0 hw ether 02:01:02:03:04:08
Or to survive reboots stick the last bit in /etc/network/interfaces
iface wlan0
DirkS
Wed Nov 22, 2017 6:20 pm
That was about a couple of Pi0Ws though (rev 900c1)
twocantech
Fri Nov 24, 2017 9:20 am
iface wlan0
Thank you for your advice, I have got a workaround in place now (it is not very elegant, but it works).
So, I should have mentioned I am using the latest raspbian, when I added the above lines into /etc/network/interfaces it broke the wireless networking totally, so I added:
allow-hotplug wlan0
iface wlan0 inet manual
	wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
This used the alternative MAC address, but the pi would not connect on startup.
I tried using "auto wlan0" instead of "allow-hotplug wlan0" but this caused the pi to ignore the alternative MAC address and connect with the original duplicated one.
So in the end I left the entry in /etc/network/interfaces as above, and added the following into /etc/rc.local:
# Wireless workaround - reset the wireless adaptor
	ifdown wlan0
	sleep 1
	ifup wlan0
They are all working at the moment, and able to be assigned different IP addresses, not confusing the router now.
Thank you mikerr for your suggestions.
Fri Nov 24, 2017 12:39 pm
Try running
sudo rpi-update
to get latest bootcode and kernel.
If the problem persists we'll need to flag this to the RPF folks as they may have an engineering problem in a factory somewhere.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
Fri Nov 24, 2017 3:20 pm
Try running
sudo rpi-update
Already investigating.
Please direct all questions to the forum, I do not do support via PM.
Return to “Raspbian”
Who is online
Users browsing this forum: donbrew and 21 guests
