verify EXPR bug in SHELL
Posted: Thu Nov 09, 2017 1:21 pm
by paulwratt
can a few people verify a bug in different versions of Raspbian, on a console:
expr 85 * 3
I dont use X, Bash is the $SHELL
I just verified this works:
expr 85 \* 3
Cheers
Paul
Re: verify EXPR bug in SHELL
Posted: Thu Nov 09, 2017 1:28 pm
by jahboater
Try doing
echo *
You will see that the shell expands * into all the visible filenames in the current directory.
\* stops that expansion.
There is no bug.
Posted: Thu Nov 09, 2017 1:29 pm
by n67
This has nothing to do with BASH (other than that is common behavior in all Unix shells) or the Pi. It is a basic limitation of 'expr'. As you've deduced, you need to escape any arguments to 'expr' that are "special" to the shell. This includes, as you've noted, the * character.
'expr' is pretty much obsolete in the modern world. Back in the day, it was all we had, but there are better tools available now.
Using bash, the simplest way to do math in the shell is to use $(()) like this:
$ echo $((85*3))
255
$ foo=85;bar=3
$ echo $((foo*bar))
255
Now, if you are maintaining old code that uses 'expr', then the original authors would have been aware of these limitations and coded accordingly. If you are writing new code, don't use 'expr'.
Posted: Thu Nov 09, 2017 1:30 pm
by DougieLawson
If you want to do complex maths in bash pipe it into bc with suitable use of apostropes and/or quotes.
Posted: Thu Nov 09, 2017 2:50 pm
by piglet
Yup: echo '(85 * 3)^2'| bc
65025
