vladoportos
Do I need this services to boot ?
Thu Oct 19, 2017 8:11 am
Hello all,
Trying to shave off some time from boot of rpi zero w and main culprits are:
6.024s dev-mmcblk0p2.device
5.645s hciuart.service
3.886s php7.0-fpm.service
3.884s networking.service
3.863s nginx.service
3.286s keyboard-setup.service
3.089s dphys-swapfile.service
1.868s raspi-config.service
1.740s ntp.service
1.616s lightdm.service
1.563s systemd-udev-trigger.service
1.502s systemd-logind.service
1.278s avahi-daemon.service
1.244s phpsessionclean.service
1.191s systemd-journald.service
1.184s systemd-udevd.service
1.181s systemd-fsck-root.service
I know I need most of them so there is probably nothing to do, but what about:
keyboard-setup.service - I was googling around and could not find normal answer... is it needed when there is no keyboard attached ? ( only ssh )
raspi-config.service - What does it do, ,is it needed ?
ntp.service - Hmm I was thinking turning this off and have the time synced every 30 min by cron
avahi-daemon.service - I think this can be turned off, no need for zeroconf discovery on net
Re: Do I need this services to boot ?
Thu Oct 19, 2017 9:39 am
dev-mmcblk0p2 is the filesystem check for your SDCard
hciuart is bluetooth.
php7.0-fpm is the php handler for NGinx
Networking is, kind of, essential or your RPi isn't much more use than a chocolate teapot
NGinx is your web server
Keyboard-setup is only needed if you're not running headless
dphys-swapfile allows you to overcommit RAM and swap to your SDCard
raspi-config is a one-shot set-up process for Raspbian
ntp can be replaced with systemd-timesyncd, don't do time sync from cron
lightdm is the GUI login screen or the GUI autologin
udev-trigger is the "hotplug" manager, that allows you to plug in USB devices
logind is essential, it starts the getty that allows lightdm to autologin
avahi-daemon is the mDSN Bonjour service that allows other devices (like Apple things) to find your RPi on your network
systemd-journal, systemd-udevd are essential operating system services
systemd-fsck-root is a one-shot process that ensures your root filesystem is intact
If you're running headless then set the "boot to command line login" in sudo raspi-config. That will disable a bunch of non-essential services for you.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
Since 2012: 1B*5, 2B*2, B+, A+, Zero*2, 3B*3
Please post ALL technical questions on the forum. Do not send private messages.
Return to “Raspbian”
Who is online
Users browsing this forum: No registered users and 12 guests
