Re: Tutorial: Compile VLC with HW acceleration - Stretch, RPi 2/3
Sat Jan 13, 2018 8:29 am
For this sort of thing I would use omxplayer with h264 video and the --loop option. I've had a video of that form running continuously for a few months on a Pi (I'd switched the screen off and forgotten it was running) with no problems at all.
(It was a 4 hour long video of a log fire that I downloaded and was using to provide ambience for Christmas a couple of years ago. It ran fine on a Pi 1B)
moh86
Sat Jan 20, 2018 1:09 am
Hello, I have a problem. Today I've got my brand new RPi3 and Samsung Evo Plus 64GB microSD card. After installing a fresh Raspbian Stretch on the SD Card I came to that topic and followed all the steps. So far so good. But if I play an example Video which came with Raspbian "/opt/vc/src/hello_pi/hello_video/test.h264" I see the Video like 1fps. Very choppy/jerky.
Hardware is new and software is fresh installed. I havent overclocked or something similiar.
Ive tried 128MB on GPU already, its a little bit better but not watchable at all.
Can anybody help me?
gkreidl
Sat Jan 20, 2018 7:16 am
Get some "real videos" for testing. VLC doesn't like this raw h264 video (no container).
BTW, VLC has some advantages but it is not as efficient as omxplayer.
Minimal Kiosk Browser (kweb)
moh86
Sat Jan 20, 2018 9:14 am
I‘ve tried a 1080p full movie as well. There were more fps but it was still not watchable.
What can I do? Do you have a video file which I can test and compare my result with yours?
cjan
Sat Jan 20, 2018 9:49 am
try 720p.
gkreidl
Sat Jan 20, 2018 10:42 am
With the GPU running a 500MHz omxplayer can play up to 1080p60. This doesn't work with with VLC. But all of my 1080i50 recorded (or live) TV streams work well with VLC.
moh86
Sat Jan 20, 2018 11:19 am
try 720p.
Ok right now I‘m watching a 720p movie. It runs very fluent even with 64GB GPU. Sadly I have still problems with 1080p.
frmkaiser
Thu Jan 25, 2018 1:19 am
I followed the guide but I am still having issues. I am using the standard Big Buck Bunny 1080p 30fps video http://distribution.bbb3d.renderfarming ... normal.mp4 which works in omxplayer.
Here is the console log:
cvlc bbb_sunflower_1080p_30fps_normal.mp4 -v
VLC media player 2.2.8 Weatherwax (revision 2.2.7-14-g3cc1d8cba9)
[013522a0] dummy interface: using the dummy interface module...
[73e00db0] mp4 stream warning: unknown box type btrt (incompletely loaded)
[73e00f28] mp4 demux warning: STTS table of 1 entries
[73e00f28] mp4 demux warning: CTTS table of 16212 entries
[0135e110] alsa audio output warning: device cannot be paused
[6e600648] core video output warning: Not enough direct buffers, using system memory
[6e600648] core video output warning: picture is too late to be displayed (missing 80 ms)
[color=#FF0000][01395cb0] core vout display error: Failed to set fullscreen
[01395cb0] core vout display error: Failed to change zoom
[01395cb0] core vout display error: Failed to set on top[/color]
[6e600648] core video output warning: picture is too late to be displayed (missing 77 ms)
[6e600648] core video output warning: picture is too late to be displayed (missing 76 ms)
[6e600648] core video output warning: picture is too late to be displayed (missing 69 ms)
Any thoughts? Can my issue be reproduced by others?
Thank you
gkreidl
Thu Jan 25, 2018 5:21 am
Thank you
Yes, but it is not an "issue". VLC is simply less efficient than omxplayer (that's one of the reasons why I wrote omxplayerGUI).
cjan
Sat Feb 03, 2018 10:29 pm
now official ffmpeg-mmal supported, do we need rebuild vlc? any benefit?
gkreidl
Sun Feb 04, 2018 4:54 am
You cannot really compare a full sized, feature-rich media player like VLC with ffmeg (basically a library and a few command line tools).
cjan
Sun Feb 04, 2018 7:01 am
rebuild with --enable-mmal options, but mmal-vout OK omxil-vout not OK test some mp4 files.
does mmal in conflict with omxil ?
gkreidl
Sun Feb 04, 2018 9:21 am
I never got the mmal version to work and so i have always used omxil and disabled mmal.
cjan
Fri Feb 09, 2018 7:32 am
vlc-3.0 released, no more ffmpeg-3 patches needed.
gkreidl
Fri Feb 09, 2018 7:43 am
Thanks for the information. I'll test it as soon as I find the time and then I will update the OP.
McLion
Fri Feb 09, 2018 8:35 am
Do we still have to compile it by ourselves to get HW acceleration or will the version from the Raspbian repo include GPU acceleration?
runboy93
Fri Feb 09, 2018 5:37 pm
I'm pretty sure we still need compile it to get HW acceleration, I'm going try it later as I get more time.
Indeed the 3.0.x branch will contain the last releases running on:
- Windows XP, Vista, and the servers equivalent of those Windows versions
- macOS 10.7, 10.8 & 10.9, iOS 7 & 8
- Android 2.x, 3.x, 4.0.x & 4.1.x
- Compilers before gcc 5.0 and clang 3.4, or equivalent
ksharindam
Sat Feb 10, 2018 2:27 am
I hope VLC in raspbian repo will be HW Accl supported within one month.
My Qt projects at ... https://github.com/ksharindam
gkreidl
Sat Feb 10, 2018 6:45 am
What makes you think so?
ksharindam
Sat Feb 10, 2018 7:05 am
Because, previously I have sent a patch to enable HW accl in ffmpeg. You can see that they have added my patch.
Now I have sent a patch to enable HW accl in VLC. It may take time to get my message, but then I hope they will add my patch.
gkreidl
Sat Feb 10, 2018 7:19 am
In the past it was Raspbian policy not to add RPi specific code or patches. Packages specifically compiled for RPi are only in the Foundation archive, which is added "on top" of Raspbian. And in fact, ffmpeg is now in the Foundation archive.
ksharindam
Sat Feb 10, 2018 7:52 am
To add the patch , at first they added ffmpeg in RPi Foundation repo. Then added the patch.
cjan
Mon Feb 12, 2018 7:14 am
Changes between 2.2.8 and 3.0.0:
* Important improvements for the MMAL decoder and output for rPI and rPI2
albertserene
Mon Feb 19, 2018 6:07 am
The installation doesn't work for me. I think it is because:
wget http://www.linuxfromscratch.org/patches ... g3-1.patch
The file is no longer there. It returns a 404 file not found error.
Can you revised the link or revised the entire guide using VLC 3.0.0? I am new to Raspbian and eager to make movie playing works with my Pi3.
Thank you very much.
gkreidl
Mon Feb 19, 2018 10:22 am
I could not compile VLC 3.0. Compilation stops with a number of errors and I have found no way so far to disable the stuff that doesn't work-
Return to “Raspbian”
