gkreidl
Re: Tutorial: Compile VLC with HW acceleration - Stretch, RPi 2/3
Mon Aug 06, 2018 5:52 am
mrdone wrote:
Sun Aug 05, 2018 4:59 am
Thank you for this tutorial, the compilation process went smoothly. I have two questions. First, can you recommend some good pages to read about compilation process of these days. For example, what bootstrap is actually doing. I realised that my knowledge is a bit outdated :?
Second, when I try to play matroska HD videos it plays it ok, with some slight lags. However, when I try to rewind a video the image freezes while sound suggests that it was actually rewinded. The player is still responsive to keys but image doesn't change. Do you experience the same behaviour or something is wrong on my side? I have set outputs as you suggested and allocated 128Mb to GPU. I tried to play it with omxplayer and everything was fine.
"bootstrap" is a script. You can open and read it (heavy stuff).
I also have problems with some HD MKV files.
Usually I prefer omxplayer(GUI).
Minimal Kiosk Browser (kweb)
redbr64
Tue Aug 07, 2018 5:40 pm
It seems I forgot to thank you for your help. thanks @gkreidl !
alexkapoios
Tue Sep 18, 2018 5:42 pm
Hello :D
I'm beginner and I need your help please.
I installed vlc from guide here. Also, I hange the following options: Settings, simple, Audio: make sure, ALSA and bcm2835 are selected, Settings, simple, Video, output: select "OpenMAX IL video output". I have little problem. When I play video, I don't see toolbar elements (Play, Stop, Pause.....).
How to fix that?
gkreidl
Tue Sep 18, 2018 9:41 pm
Hello :D
How to fix that?
You can't. Video is displayed in a screen overlay like with omxplayer. You have to use keyboard commands,
You might try my omxplayerGUI (part of kweb suite), which can play the video (overlay) inside a window area and lets you use the control elements.
mcca69
Sun Sep 23, 2018 8:06 pm
Works like a charm on Raspberry Pi 3. Thank You!
andes
Tue Oct 09, 2018 3:47 am
Hi all, I am just a newbie with Raspberry. I've just compiled VLC on my Raspberry Pi 3B+ following the tutorial in page 1. Unfortunately all the fullHD videos I use to test are still broken in VLC. Is there any advice for me to fix it please? Thanks a lot.
gkreidl
Tue Oct 09, 2018 10:26 am
What does "broken" mean? Do other (not full HD) videos play in overlay mode?
andes
Sat Oct 13, 2018 1:23 am
After increasing GPU memory to 512Mb, I am now able to play .MP4 videos of full HD resolution and framerate 25fps. But there is still issue with playing .MKV files as shown in the picture below. How can I fix it? Should I increase GPU memory more than 512Mb?
gkreidl
Sat Oct 13, 2018 1:45 am
128 MB should be enough. 512 MB is far too much (missing ARM memory).
Check the MKV files with mediainfo - or try to play them with omxplayer. Perhaps they are out of specs. If omxplayer can play them, VLC should also work.
andes
Sat Oct 13, 2018 7:57 am
Thanks. The codec is VP9, that's why I can't play them.
cedrickzepp
Fri Oct 19, 2018 6:35 am
codec/avcodec/video.c: In function ‘ffmpeg_InitCodec’:
codec/avcodec/video.c:877:24: error: ‘FF_INPUT_BUFFER_PADDING_SIZE’ undeclared (first use in this function)
                        FF_INPUT_BUFFER_PADDING_SIZE );
Makefile:7738: recipe for target 'codec/avcodec/libavcodec_plugin_la-video.lo' failed
make[4]: *** [codec/avcodec/libavcodec_plugin_la-video.lo] Error 1
make[4]: *** Waiting for unfinished jobs....
make[4]: Leaving directory '/home/cedrickzepp/vlc-2.2.8/modules'
Makefile:9655: recipe for target 'all-recursive' failed
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory '/home/cedrickzepp/vlc-2.2.8/modules'
Makefile:4529: recipe for target 'all' failed
make[2]: *** [all] Error 2
make[2]: Leaving directory '/home/cedrickzepp/vlc-2.2.8/modules'
Makefile:2267: recipe for target 'all-recursive' failed
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory '/home/cedrickzepp/vlc-2.2.8'
Makefile:2152: recipe for target 'all' failed
make: *** [all] Error 2
Where will the error be found?
gkreidl
Fri Oct 19, 2018 8:28 am
I've never seen that error. Did you apply the patch?
ERO
Thu Nov 01, 2018 9:55 am
Thank you very much for this, VLC is now running well on my Raspberry Pi 3 B+!
For some reason that I can't quite understand (no errors visible during the whole process) my first attempt partially failed - launching VLC didn't create any X Window, but I could invoke it from a terminal and it could play videos (without hardware acceleration).
I uninstalled everything, used the script as suggested by amarahjiwa to re-run the download, patching and compilation-installation process and VLC now creates a window where I have access to the settings.
Great stuff. Thank you for sharing.
gkreidl
Thu Nov 01, 2018 11:21 am
Perhaps you missed something during the manual process.
cjan
Fri Nov 16, 2018 3:00 am
2018-11-13.mg
* VLC media player with VideoCore hardware acceleration included in image
what is this?
cjan
Fri Nov 16, 2018 1:24 pm
2018-11-13.mg
what is this?
ok, vlc packages update to 3.0.3-1-0+deb9u1+rpt1.
use: MMAL x11 splitter for rasberry Pi, done.
dom
Fri Nov 16, 2018 1:40 pm
2018-11-13.mg
what is this?
Raspbian now includes an even more accelerated VLC.
This uses mmal for video decode and the new hvs component for resize, yuv->rgb conversion and composition of subtitles.
Let us know if there are any improvements or regressions compared to the VLC version that has been used here.
gkreidl
Fri Nov 16, 2018 5:08 pm
2018-11-13.mg
what is this?
Great work!!!!
I have tested a lot today and it really works well for video. But there is a problem with audio files: they need a lot of time to start (tested mp3 and flac)
I've also modified my youtube-dl-server (part of my kweb suite) a bit so that it (optionally) works perfectly with VLC now. It will be be published as a hotfix in a short while. And I'll update the OP of this thread to point to the new release.
LTolledo
Sat Nov 17, 2018 12:30 am
2018-11-13.mg
what is this?
I've started a topic on a particular problem I faced using the repository available VLC (using apt install vlc ) on a recently updated and upgraded RPi3B/RPI3B+. The link is below.
viewtopic.php?f=28&t=227092
Some people be like:
cjan
Sun Nov 18, 2018 5:25 am
can not play webm format, gpu_mem=192.
gkreidl
Sun Nov 18, 2018 7:51 am
Check the codec being used. VP8 should be supported if you have enabled the additional codecs, but not VP9 AFAIK.
cjan
Sun Nov 18, 2018 8:41 am
which package should install?
gkreidl
Sun Nov 18, 2018 9:36 am
start_file=start_x.elf
fixup_file=fixup_x.dat
in /boot/config.txt
cjan
Sun Nov 18, 2018 10:02 am
in /boot/config.txt
no go.
gkreidl
Sun Nov 18, 2018 10:05 am
in /boot/config.txt
no go.
Did you reboot?
Check the file with mediainfo to get the codec being used.
Return to “Raspbian”
