Page 6 of 8
Re: Tutorial: Compile VLC with HW acceleration - Stretch, RPi 2/3
Posted: Thu May 03, 2018 11:27 am
by McLion
Just tested with VLC 3.0.2 ... still no joy, not with MMAL nor with OMX-IL. :(
Posted: Tue May 15, 2018 6:50 pm
by Panometric
FYI, as of Ubuntu MATE 16.04.2 (Xenial) this done already, you just need to set the outputs.
Posted: Wed May 16, 2018 7:25 am
by McLion
Not on Raspbian. See this thread: https://forum.videolan.org/viewtopic.php?f=13&t=142905
Unfortunately, no-one at Videolan seems to show any interest in this issue.
Posted: Wed May 30, 2018 10:10 pm
by ninjaEF
Pi 3
Debian Stretch kernel 4.14.34-v7+
At 'make install' I get the following error related to pulse??
libtool: warning: relinking 'libpulsesrc_plugin.la'
libtool: install: (cd /home/daz/VLC/vlc-2.2.8/modules; /bin/bash "/home/daz/VLC/vlc-2.2.8/modules/../libtool" --silent --tag CC --mode=relink gcc -D_REENTRANT -I/opt/vc/include/ -I/opt/vc/include/interface/vcos/pthreads -I/opt/vc/include/interface/vmcs_host/linux -I/opt/vc/include/interface/mmal -I/opt/vc/include/interface/vchiq_arm -I/opt/vc/include/IL -I/opt/vc/include/GLES2 -I/opt/vc/include/EGL -mfloat-abi=hard -mcpu=cortex-a7 -mfpu=neon-vfpv4 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -pipe -fvisibility=hidden -O4 -fno-math-errno -funsafe-math-optimizations -fno-rounding-math -fno-signaling-nans -fcx-limited-range -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../compat/libcompat.la ../src/libvlccore.la -L/opt/vc/lib -o libpulsesrc_plugin.la -rpath /usr/lib/vlc/plugins/access access/libpulsesrc_plugin_la-pulse.lo libvlc_pulse.la -lpulse )
/usr/bin/nm: 'access/.libs/libpulsesrc_plugin_la-pulse.o': No such file
gcc: error: access/.libs/libpulsesrc_plugin_la-pulse.o: No such file or directory
libtool: error: error: relink 'libpulsesrc_plugin.la' with the above command before installing it
Makefile:4565: recipe for target 'install-accessLTLIBRARIES' failed
make[5]: *** [install-accessLTLIBRARIES] Error 1
make[5]: Leaving directory '/home/daz/VLC/vlc-2.2.8/modules'
Makefile:9990: recipe for target 'install-am' failed
make[4]: *** [install-am] Error 2
make[4]: Leaving directory '/home/daz/VLC/vlc-2.2.8/modules'
Makefile:9655: recipe for target 'install-recursive' failed
make[3]: *** [install-recursive] Error 1
make[3]: Leaving directory '/home/daz/VLC/vlc-2.2.8/modules'
Makefile:9984: recipe for target 'install' failed
make[2]: *** [install] Error 2
make[2]: Leaving directory '/home/daz/VLC/vlc-2.2.8/modules'
Makefile:2267: recipe for target 'install-recursive' failed
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory '/home/daz/VLC/vlc-2.2.8'
Makefile:2733: recipe for target 'install' failed
make: *** [install] Error 2
[email protected]:/home/daz/VLC/vlc-2.2.8#
Posted: Thu May 31, 2018 8:10 am
by gkreidl
Did you run it without sudo?
sudo make install
Posted: Thu May 31, 2018 12:32 pm
by ninjaEF
Yes I did.
I was running as root, i.e. "sudo su" .... yes I know, don't go there (!)
So it did not work under root.
sudo make install
Posted: Fri Jun 08, 2018 2:41 am
by amarahjiwa
I made a bash file for people who really lazy to type and following the instruction.
#!/bin/bash
set -e
sudo apt-get -y update
sudo apt-get -y upgrade
sudo apt-get -y purge vlc libvlc-bin libvlc5 libvlccore8 vlc-bin vlc-data vlc-l10n vlc-plugin-base vlc-plugin-notify vlc-plugin-qt vlc-plugin-samba vlc-plugin-skins2 vlc-plugin-video-output vlc-plugin-video-splitter vlc-plugin-visualization
sudo apt -y autoremove
sudo apt-get -y install autopoint pkg-config libtool build-essential autoconf
sudo apt-get -y install liba52-0.7.4 libasound2 libass5 libavahi-client3 libavahi-common3 libavc1394-0 libbasicusageenvironment1 libbluray1 libbz2-1.0 libc6 libcairo2 libcddb2 libcdio13 libchromaprint1 libdbus-1-3 libdc1394-22 libdca0 libdirectfb-1.2-9 libdvbpsi10 libdvdnav4 libdvdread4 libebml4v5 libfaad2 libflac8 libfontconfig1 libfreetype6 libfribidi0 libgcc1 libgcrypt20 libglib2.0-0 libgme0 libgnutls30 libgpg-error0 libgroupsock8 libgsm1 libjpeg62-turbo libkate1 liblirc-client0 liblivemedia57 liblua5.2-0 liblzma5 libmad0 libmatroska6v5 libmodplug1 libmp3lame0 libmpcdec6 libmpeg2-4 libmtp9 libncursesw5 libogg0 libopus0 libpng16-16 libpulse0 libraw1394-11 libresid-builder0c2a librsvg2-2 librtmp1 libsamplerate0 libsdl-image1.2 libsdl1.2debian libshine3 libshout3 libsidplay2 libsnappy1v5 libsndio6.1 libspeex1 libspeexdsp1 libssh-gcrypt-4 libssh2-1 libstdc++6 libtag1v5 libtheora0 libtinfo5 libtwolame0 libudev1 libupnp6 libusageenvironment3 libva-drm1 libva-x11-1 libva1 libvcdinfo0 libvorbis0a libvorbisenc2 libvpx4 libwavpack1 libwebp6 libwebpmux2 libx11-6 libx264-148 libx265-95 libxcb-keysyms1 libxcb1 libxml2 libxvidcore4 libzvbi0 zlib1g libgdk-pixbuf2.0-0 libgtk2.0-0 libnotify4 libqt5core5a libqt5gui5 libqt5widgets5 libqt5x11extras5 libxi6 libsmbclient libxext6 libxinerama1 libxpm4 fonts-freefont-ttf libaa1 libcaca0 libegl1-mesa libgl1-mesa-glx libgles1-mesa libgles2-mesa libxcb-shm0 libxcb-xv0 libxcb-randr0 libxcb-composite0
sudo apt-get -y install liba52-0.7.4-dev libasound2-dev libass-dev libavahi-client-dev libavc1394-dev libbluray-dev libbz2-dev libc6-dev libcairo2-dev libcddb2-dev libcdio-dev libchromaprint-dev libdbus-1-dev libdc1394-22-dev libdca-dev libdirectfb-dev libdvbpsi-dev libdvdnav-dev libdvdread-dev libebml-dev libfaad-dev libflac-dev libfontconfig1-dev libfreetype6-dev libfribidi-dev libgcc-6-dev libgcrypt20-dev libglib2.0-dev libgme-dev libgnutls28-dev libgpg-error-dev libgsm1-dev libjpeg62-turbo-dev libkate-dev liblircclient-dev liblivemedia-dev liblua5.2-dev liblzma-dev libmad0-dev libmatroska-dev libmodplug-dev libmp3lame-dev libmpcdec-dev libmpeg2-4-dev libmtp-dev libncursesw5-dev libogg-dev libopus-dev libpng-dev libpulse-dev libraw1394-dev libresid-builder-dev librsvg2-dev librtmp-dev libsamplerate0-dev libsdl-image1.2-dev libsdl1.2-dev libshine-dev libshout3-dev libsidplay2-dev libsnappy-dev libsndio-dev libspeex-dev libspeexdsp-dev libssh-gcrypt-dev libssh2-1-dev libstdc++-6-dev libtag1-dev libtheora-dev libtinfo-dev libtwolame-dev libudev-dev libupnp6-dev libva-dev libvcdinfo-dev libvorbis-dev libvpx-dev libwavpack-dev libwebp-dev libx11-dev libx264-dev libx265-dev libxcb-keysyms1-dev libxcb1-dev libxml2-dev libxvidcore-dev libzvbi-dev zlib1g-dev libgdk-pixbuf2.0-dev libgtk2.0-dev libnotify-dev libqt5x11extras5-dev libxi-dev libsmbclient-dev libxext-dev libxinerama-dev libxpm-dev libaa1-dev libcaca-dev libegl1-mesa-dev libgles1-mesa-dev libgles2-mesa-dev libxcb-shm0-dev libxcb-xv0-dev libxcb-randr0-dev libxcb-composite0-dev libavcodec-dev libavformat-dev libgstreamer1.0-dev libswscale-dev
yes | wget https://download.videolan.org/vlc/2.2.8/vlc-2.2.8.tar.xz
yes | wget http://steinerdatenbank.de/software/vlc-2.2.8-ffmpeg3-1.patch
tar -xJf vlc-2.2.8.tar.xz
cd vlc-2.2.8
./bootstrap
patch -Np1 -i ../vlc-2.2.8-ffmpeg3-1.patch
sed -i 's/error-implicit-function-declaration//' configure
export CFLAGS="-I/opt/vc/include/ -I/opt/vc/include/interface/vcos/pthreads -I/opt/vc/include/interface/vmcs_host/linux -I/opt/vc/include/interface/mmal -I/opt/vc/include/interface/vchiq_arm -I/opt/vc/include/IL -I/opt/vc/include/GLES2 -I/opt/vc/include/EGL -mfloat-abi=hard -mcpu=cortex-a7 -mfpu=neon-vfpv4" CXXFLAGS="-I/opt/vc/include/ -I/opt/vc/include/interface/vcos/pthreads -I/opt/vc/include/interface/vmcs_host/linux -I/opt/vc/include/interface/mmal -I/opt/vc/include/interface/vchiq_arm -I/opt/vc/include/IL -mfloat-abi=hard -I/opt/vc/include/GLES2 -I/opt/vc/include/EGL -mcpu=cortex-a7 -mfpu=neon-vfpv4" LDFLAGS="-L/opt/vc/lib"
./configure --prefix=/usr --enable-omxil --enable-omxil-vout --enable-rpi-omxil --disable-mmal-codec --disable-mmal-vout --enable-gles2
yes | make -j3
yes | sudo make install
Quick note: I recommended that you place this file in a folder because this file creates some folders and data, and to make sure every command work as intended.
who to create .sh file
create the file using sudo nano
1. type this command
sudo nano vlc_installer.sh
2. paste it
3. now save it
  • ctrl+x
  • y
  • enter
3. then type
chmod +x ./your_file.sh
4. run the file by typing
sudo ./vlc_installer.sh
for people who want to create .sh file using notepad++
1. set this following configuration
  • language: shell
  • encoding: encode in UTF-8
  • edit > EOL conversion : Unix (LF)
2. paste it
3. save as .sh file
4. tranfer your file to your raspberry pi
5. then type
chmod +x ./vlc_installer.sh
6. run it by typing
Posted: Fri Jun 08, 2018 7:55 pm
by rpdom
Why are you using sudo to run the file that has sudo for the command inside it?
Posted: Tue Jun 12, 2018 10:53 am
by Tichun
Provide compiled binary or don't bother at all.
Bonus points for getting it into the Raspbian repository.
It's not like this build is using some arcane optimisations that run only on your own Pi, if there were any.
BTW has any programmer even tried to publish his software to the official repo or is it so restrictive that it doesn't allow it?
There are countless projects that are PITA to install.. (go on and compile OpenMW for the next 72 hours, add repositories, try to steal packages from other distributions and so on)
It has to end, I guess?
As a sidenote, I am a far seer, a crowd of angry people is going to gather up to burn me on a stake for expressing my opinions, as it sure hurt their feelings, as it always seems to happen nowadays. Grow up.
Posted: Tue Jun 12, 2018 12:13 pm
by n67
I agree with you - this "providing it in kit form with (lots of) assembly required" is no good.
But they will tell you that it is all we have at the moment. And they refuse to explain further.
The point is that Linux is supposed to be progressing beyond this "kit" approach. As long as it does, the Windows people will be right to look down on it.
Anyway, I predict certain (important) people will not like your post.
Posted: Tue Jun 12, 2018 2:59 pm
by gkreidl
@Tichun & n67:
I don't like your belligerent tone. Did you ever provide something useful to the community yourself?
The RPi has been built for education and learning. What's so bad about providing a tutorial about building a package?
Following it you create a VLC version, which
1) is newer than the one in the Stretch repository
2) uses armv7 optimization for RPi2/3
3) adds GPU support using OMX
Because of 1) and 2) it won't find it's way into the Raspbian (armv6hf) repository.
3) is working, but not completely stable - in VLC 3.x versions it doesn't work at all and the VLC developers don't seem to be interested in fixing OMX or MMAL support. I would not recommend adding an unstable version to an official repository.
Feel free to create a package and make it available somewhere. I've done that in the past for a number of packages and will continue to do so. For a number of reasons I have decided not to offer a VLC+GPU package for download.
And if you are not happy with the Debian/Raspbian approach (stability first), you are free to choose another Linux distribution like ARCH which follows a different philosophy.
Posted: Thu Jun 14, 2018 8:56 am
by Ger_Pa
first and foremost, thank you for the tutorial, is quite useful for those who want to compile VLC. But i have a question.
Why do you disable OpenGL??? It works just fine with opengl, in fact using Output OpenGL GLX, it behaves like it does in any x86/x64 system..
Instead of
just a plain
./configure
Will do the trick and at the first start instead of selecting "OpenMAX IL video output" use "OpenGL GLX video output (XCB)" Then the videos will play the right speed and inside the windows, which means full use of the controls.
https://www.youtube.com/watch?v=5BAWH-e3DE4 Short video, PI 3 using Open Gl GLx as output and as you can see it works great.
Posted: Thu Jun 14, 2018 9:33 am
by gkreidl
Instead of
just a plain
./configure
1) A simple "./configure" does not include the use of HW decoding (OMX or MMAL).
2) OpenGL is in alpha state and disabled by default. It is not compatible with a lot of other applications/frameworks using the GPU.
3) I do not disable it in my configuration at all.
4) Without GPU support (OpenMax) you cannot play HD videos. SD videos may work, e.g. with SDL output inside a window.
Posted: Thu Jun 14, 2018 10:08 am
by Ger_Pa
You are right i was looking at other code line... and :o yes i'm able to play up to 720p 60fps... 1080p just black screen... So time to compile it again...
Posted: Wed Jun 27, 2018 7:37 am
by Slarty
Hi.
Absolutely fantastic job. ! I've always used VLC as my favourite media player, on Windows, but recently, after buying a RPi 3 B+, had an absolute nightmare trying to run it. I followed your instructions to the letter, and wow... after a few stuttery moments, it ran. Fantastic. Thank you so much. I'm completely new to all this stuff, so please excuse me. I'm having a couple of niggly problems popping up. I'm getting 3 Display Errors : Failed to change zoom... Failed to set on top... and... Failed to set Fullscreen. I'm sure it's something incredibly simple that I've overlooked, so I'll take a good look at my Settings. Thank you so much again for an incredible job. ! :D Cheers. Bill.
Posted: Wed Jun 27, 2018 12:17 pm
by airdrummer
any hope for osmc?
The following packages have unmet dependencies:
 libgstreamer1.0-dev : Depends: gir1.2-gstreamer-1.0 (= 1.10.4-1) but it is not going to be installed
 liblircclient-dev : Depends: liblirc-dev but it is not going to be installed
 libqt5x11extras5-dev : Depends: qtbase5-dev but it is not going to be installed
sudo apt --fix-broken install liblirc-dev
Preparing to unpack .../liblirc-dev_0.9.4c-9_armhf.deb ...
Unpacking liblirc-dev:armhf (0.9.4c-9) ...
dpkg: error processing archive /var/cache/apt/archives/liblirc-dev_0.9.4c-9_armhf.deb (--unpack):
 trying to overwrite '/usr/include/lirc/lirc_client.h', which is also in package armv7-lirc-osmc 0.9.0-6
E: Sub-process /usr/bin/dpkg returned an error code (1)
Posted: Wed Jun 27, 2018 12:22 pm
by gkreidl
any hope for osmc?
I do not use OSMC and so I cannot answer your question.
Posted: Wed Jun 27, 2018 2:28 pm
by McLion
These errors are normal since VLC does not feature full options to control the HW-accelerated output in terms of scaling and such.
However, what it can do is using full screen by setting the Aspect-Ratio, Try this setting from the Video menu.
Posted: Thu Jul 05, 2018 4:02 pm
by airdrummer
anybody get this to compile on osmc? i'm stuck on dependency issues:
Preparing to unpack …/liblirc-dev_0.9.4c-9_armhf.deb …
Unpacking liblirc-dev:armhf (0.9.4c-9) …
dpkg: error processing archive /var/cache/apt/archives/liblirc-dev_0.9.4c-9_armhf.deb (–unpack):
trying to overwrite ‘/usr/include/lirc/lirc_client.h’, which is also in package armv7-lirc-osmc 0.9.0-6
Posted: Thu Jul 05, 2018 4:07 pm
by McLion
You already asked this and nobody could help, a month ago :?
Posted: Tue Jul 24, 2018 4:35 pm
by tutaf
Hi! Thanks for very useful and detailed tutorial. All went fine, but I have a question: Why when I can not connect to vlc using web interface? It is enabled in settings. To repository version of vlc I connected without any problems. Thanks for help.
Posted: Fri Jul 27, 2018 9:46 am
by dl9sec
thanks for the great tutorial.
I tried to build VLC from this tutorial. At the end only the plugins seems to be build, no VLC binary.
As far as i see, the build process stops because of a Qt version conflict.
I built Qt 5.10 for my Raspberry Pi 3 for another project (see https://github.com/AlbrechtL/welle.io/b ... ERRY-PI.md) and now i get error messages like
/usr/lib/arm-linux-gnueabihf/qt5/bin/uic: relocation error: /usr/lib/arm-linux-gnueabihf/qt5/bin/uic: symbol qt_qhash_seed, version Qt_5 not defined in file libQt5Core.so.5 with link time reference
when trying to compile VLC.
Any ideas how to solve this conflict?
I assume something points to wrong Qt stuff which doesn't fit to my Qt 5.10 deployment, but i am not that expert, just following tutorials :D
Thank you in advance.
Regards, Thorsten
Posted: Thu Aug 02, 2018 9:52 pm
by Will200218
I have unsuccessfully tried to install and compile vlc (my pi froze halfway through)
How do i get rid of all the files and programs installed in this process?
Posted: Fri Aug 03, 2018 1:13 am
by gkreidl
Did it really freeze? Perhaps you have run into swapping, which may look like freezing, but you simply need the patience to wait then until it finishes.
As you did not finish compiling it (I assume), notking was installed to your system. Simply remove the VLC folder
Posted: Sun Aug 05, 2018 4:59 am
by mrdone
Thank you for this tutorial, the compilation process went smoothly. I have two questions. First, can you recommend some good pages to read about compilation process of these days. For example, what bootstrap is actually doing. I realised that my knowledge is a bit outdated :?
Second, when I try to play matroska HD videos it plays it ok, with some slight lags. However, when I try to rewind a video the image freezes while sound suggests that it was actually rewinded. The player is still responsive to keys but image doesn't change. Do you experience the same behaviour or something is wrong on my side? I have set outputs as you suggested and allocated 128Mb to GPU. I tried to play it with omxplayer and everything was fine.
