Page 1 of 2
Driver installation impossible? RTL8812AU
Posted: Sat Oct 07, 2017 2:16 pm
by deady1000
Hello guys,
I can nowhere find a working tutorial for how to install the driver for rtl8812au (AC1200 Wireless Adapters).
Is there some working solution available?
Thank you
Re: Driver installation impossible? RTL8812AU
Posted: Sat Oct 07, 2017 2:35 pm
by MrEngman
Hello guys,
Thank you
I compile the rtl8812u drivers for Raspbian and they are available for people to download and install.
I have a script that will download and install the driver. It will determine the Raspbian kernel version and select the appropriate driver version.
Download and install the script using commands
sudo wget http://fars-robotics.net/install-wifi -O /usr/bin/install-wifi
sudo chmod +x /usr/bin/install-wifi
To see info on how to use the script use command
sudo install-wifi -h
To download the driver for your current Raspbian kernel use command
sudo install-wifi
Posted: Sat Oct 07, 2017 3:10 pm
by deady1000
Dear MrEngman I found your tutorial earlier but this does not work with my Raspberry.
The real device is found @USB and drivers are downloaded well.
The adapter even can connect to a wifi but with iwconfig I can't start monitor mode because the driver is not detected properly.
When I for example use airmon-ng to check whats going on I see that driver is not running well.
login as: pi
[email protected]'s password:
Linux raspberrypi 4.9.53-v7+ #1040 SMP Fri Oct 6 14:19:18 BST 2017 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sat Oct 7 14:55:02 2017
[email protected]:~ $ sudo su
[email protected]:/home/pi# install-wifi
*** Raspberry Pi wifi driver installer by MrEngman.
*** Performing self-update
*** Relaunching after update
Your current kernel revision = 4.9.53-v7+
Your current kernel build = #1040
Checking for a wifi module to determine the driver to install.
Your wifi module is Bus 001 Device 004: ID 0bda:8812 Realtek Semiconductor Corp. RTL8812AU 802.11a/b/g/n/ac WLAN Adapter
And it uses the 8812au driver.
Checking for a new 8812au wifi driver module for your current kernel.
There is a driver module available for this kernel revision.
Downloading the 8812au driver.
Installing the 8812au driver.
Installing driver module 8812au.ko.
Syncing changes to disk
A version of the 8812au driver is already loaded and running.
You will need to reboot to load the new driver, 8812au.ko.
# I rebooted
[email protected]:/home/pi# iwconfig
eth0 no wireless extensions.
wlan1 unassociated Nickname:"<[email protected]>"
Mode:Managed Frequency=2.412 GHz Access Point: Not-Associated
Sensitivity:0/0
Retry:off RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
lo no wireless extensions.
wlan0 IEEE 802.11 ESSID:"XXXXXXXX"
Mode:Managed Frequency:2.437 GHz Access Point: 34:81:C4:3C:6B:67
Bit Rate=72.2 Mb/s Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:on
Link Quality=62/70 Signal level=-48 dBm
[email protected]:/home/pi# airmon-ng
PHY Interface Driver Chipset
phy1 wlan0 brcmfmac Broadcom 43430
phy0 wlan1 ?????? Realtek Semiconductor Corp. RTL8812AU 802.11a/b/g/n/ac WLAN Adapter
[email protected]:/home/pi# iwconfig wlan1 mode monitor
Mode:Auto
Sensitivity:0/0
Encryption key:off
The adapter can work in usual "managed mode" but not in "monitor mode".
It always goes into "Auto mode" which is quite useless.
Furthermore the driver 8812au (how its detected on my laptop) is not detected --> "??????" (see Airmon-ng)
Nevertheless I would like to thank you for your work.
Please keep up doing such a good job.
Other driver installations were not even compiling properly.
Posted: Sun Oct 08, 2017 12:45 pm
by deady1000
I still have no clue whats the problem but when I enter "lshw -class network" it says that the working driver is "driver=rtl8821au".
Logical name is wlx00c0ca95e545 instead of wlan0 or wlan1.
[email protected]:/home/XXX# lshw -class network
  *-network:0
       description: Ethernet interface
       physical id: 2
       logical name: enxb827eb2cbd88
       serial: b8:27:eb:2c:bd:88
       capacity: 100Mbit/s
       capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autone        gotiation
       configuration: autonegotiation=on broadcast=yes driver=smsc95xx driverver        sion=22-Aug-2005 duplex=half firmware=smsc95xx USB 2.0 Ethernet link=no multicas        t=yes port=MII speed=10Mbit/s
  *-network:1
       description: Wireless interface
       physical id: 3
       bus info: [email protected]:1.2
       logical name: wlx00c0ca95e545
       serial: 00:c0:ca:95:e5:45
       capabilities: ethernet physical wireless
       configuration: broadcast=yes driver=rtl8821au multicast=yes wireless=unas        sociated
  *-network:2
       physical id: 4
       logical name: wlan0
       serial: b8:27:eb:79:e8:dd
       configuration: broadcast=yes driver=brcmfmac driverversion=7.45.41.26 fir        mware=01-4527cfab ip=192.168.2.15 multicast=yes wireless=IEEE 802.11
Airmon-ng still can't even see the Adapter:
[email protected]XXX-rpi:/home/XXX# airmon-ng
Interface       Chipset         Driver
wlan0           Unknown         brcmfmac - [phy0]
wlan0 is RPis onboard adapter... RTL8812AU is missing here.
Is there someone who knows how I can get RTL8812AU to work on Raspberry?
If not I will have to return the adapter to the vendor.
Too bad.
Posted: Sun Oct 08, 2017 2:38 pm
by MrEngman
Don't know what your problem is, other than you want to use it in monitor mode, but the 8812au driver works fine on all my Pi ever since I started using it, B1, B+, 2B, 3B, 0, 0W.
Never seen lshw before but installed it on my Pi 0 W and it shows
[email protected]:~ $ sudo lshw -class network
*-network:0
physical id: 2
logical name: wlan0
serial: b8:27:eb:cc:7e:89
configuration: broadcast=yes driver=brcmfmac driverversion=7.45.41.46 firmware=01-f8a78378 ip=192.168.1.19 multicast=yes wireless=IEEE 802.11
*-network:1
physical id: 3
logical name: wlan1
serial: 74:da:38:2a:d3:86
configuration: broadcast=yes driver=rtl8821au ip=192.168.1.6 multicast=yes wireless=IEEE 802.11bgn
Currently running Raspbian Stretch 4.9.53+ #1040. Installed image 2017-09-07-raspbian-stretch-lite then ran rpi-update, apt-get update/upgrade and my install-wifi script to install the wifi driver and installed lshw which seems somewhat pointless as similar info is shown using ifconfig or iwconfig.
Posted: Sun Oct 08, 2017 2:52 pm
by deady1000
Thank you for your reply.
My problem is that I can't get into monitor mode.
Is it possible or not?
Could you please test
iwconfig
and show output?
Is it in "Auto" or "Monitor"?
Mine always just gets into Auto-Mode and monitor does not work.
Airmon-ng also does not see the adapter/driver.
Just to get that clear.
You say that when I install a fresh Raspbian, RPI-Update, apt-get update/upgrade, Install-wifi-script then I can get it into monitor mode?
Will try it again then...
Posted: Sun Oct 08, 2017 3:09 pm
by MrEngman
No, I did not say I used in in monitor mode. I have no idea if it could work in monitor mode. Probably not as you have found.
Posted: Sun Oct 08, 2017 3:34 pm
by deady1000
Ok I came a little closer. MAYBE.
I connected the RTL8812AU to my smartphone hotspot.
Suddenly I could see the RTL8812AU in airmon-ng (Adapter started blinking blue, not kept black as before).
[email protected]:~# airmon-ng
wlx00c0ca95e545         Unknown         rtl8821au - [phy2]
So now I can see it in Airmon-ng and it appears that it now uses this driver.
When I now do:
airmon-ng start wlx00c0ca95e535
(which is a damn long command - any possibility to rename it??)
Found 6 processes that could cause trouble.
If airodump-ng, aireplay-ng or airtun-ng stops working after
a short period of time, you may want to kill (some of) them!
PID     Name
589     avahi-daemon
630     avahi-daemon
655     NetworkManager
775     wpa_supplicant
790     dhclient
3741    dhclient
Process with PID 3741 (dhclient) is running on interface wlx00c0ca95e545
Process with PID 790 (dhclient) is running on interface wlan0
Then iwconfig says that wlx00c0ca95e545 still is in managed mode.
So nothing happened.
When I type
airmon-ng check kill
to kill the processes which maybe obstruct the mode change
--> RTL8812AU disconnects from smartphone hotspot and disappears in Airmon-ng :cry:
MrEngman wrote: No, I did not say I used in in monitor mode. I have no idea if it could work in monitor mode. Probably not as you have found.
Posted: Sun Oct 08, 2017 4:21 pm
by MrEngman
The long name you see for your wifi is how Raspbian Stretch originally named network devices. It was changed in the new updates so why you still see it like that I'm not sure. I think there is an option in raspi-config that will enable you to get the name back to wlanx, etc.
I had a look at the driver source github and it looks like it can operate in monitor mode but may have some problems. There are a couple of issues here https://github.com/diederikdehaas/rtl8812AU/issues regarding monitor mode.
Tried these commands and they look OK
sudo iwconfig wlan1 mode monitor
sudo iwconfig wlan1 mode auto
and don't give any errors.
Posted: Sun Oct 08, 2017 4:25 pm
by DougieLawson
There's an option in sudo raspi-config to disable predictable interface names and go back to wlanX,
Posted: Sun Oct 08, 2017 11:01 pm
by deady1000
Ok I was running Ubuntu Mate today.
Now with a fresh Raspbian I could change it in the config as you said.
I made a clean install of all updates and installed the wifi driver but still I cant get monitor mode to work.
MrEngman wrote:Tried these commands and they look OK
No there wont be errors but when you check "iwconfig" you will see that the adapter goes into "AUTO" and not "MONITOR".
So basically nothing really happens.
When I do this on my laptop it goes into "MONITOR".
Thats the difference.
By the way. Now with airmon-ng the adapter directly appears but again without the driver specs.
It says "??????" again.
This is so annoying. Nothing is working... Guess I'll have to return the adapter.
I can't be the only person who wants to use a raspberry pi with rtl8812au in monitor mode. :|
Posted: Tue Oct 10, 2017 3:18 pm
by deady1000
I just returned the AWUS036ACH and bought AWUS052NH with Ralink RT3572 Chipset.
Hopefully this is better supported.
Thank you
Posted: Tue Apr 10, 2018 6:52 pm
by Schorschi
Just for reference... Got the driver in install-wifi (version 4.3.14) to work with RTL8811AU chip wifi dongle. This is even on kernel 4.14.33(-v7+) no less. But any newer version of the driver source, say 4.3.20 for example, the RTL8812AU driver does not see the RTL8811AU chip. Not have I found any of the GitHub sources to work that newer than 4.3.14 from ether the RTL8812AU or RTL8811AU driver sets.
Posted: Thu Jul 26, 2018 1:37 am
by FogHorn
MrEngman, thank you for your script. It worked perfectly for me on my Model B Rev 2 with the latest raspbian installed. Bravo!
Posted: Thu Sep 13, 2018 8:46 pm
by letshin
Hi, I've trying installing the RTL8812AU driver using your script, MrEngman, but have faced this error:
install -p -m 644 8812au.ko /lib/modules/4.14.62-v7+/kernel/drivers/net/wireless
depmod: FATAL: Module index: bad character '\ufffd'=0xe1 - only 7-bit ASCII is supported:
qpp_ddfl\ufffdte
Loading and running the 8812au driver, 8812au.ko.
modprobe: FATAL: Module 8812au not found in directory /lib/modules/4.14.62-v7+
Could anyone help please?
Posted: Fri Sep 14, 2018 6:40 am
by MrEngman
qpp_ddfl\ufffdte
Hi letshin,
I install that driver on all my different Pi (Pi 0, P0W, B+, 2B, 3B, 3B+) with my script and I don't see any problems so I'm sure it is not an issue with the driver or my script.
When a driver is installed it needs to be registered and this is done using the depmod command. It updates a number of files as far as I know to create a list of available modules/drivers the kernel is able to use and it is possible one of the files it is trying to update may be corrupt.
One other thing is the value 'qpp_ddfl\ufffdte' it is showing. I don't know what this is but could it be a corrupt file? I don't know, but if it is is it this that is causing your issue. You could try searching for 'qpp_ddfl' or 'ufffdte' in the modules directory to see if they exist and deleting them if they do.
Then try running command sudo depmod -a again to see if it works.
Posted: Sat Sep 15, 2018 9:46 am
by letshin
Thanks. There was a corrupted folder as you suspected. I'll just write down what I did here in case someone has a similar issue.
I searched for non-ASCII characters:
LC_ALL=C find . -name '*[! -~]*'
Then deleting the offending file and all directories, rerunning sudo depmod -v returned no errors, and I was then able to load the module with sudo modprobe -r 8812au.
Posted: Sat Sep 22, 2018 8:08 pm
by MattInNNJ
Getting this error message. Everything seems to look ok on my end. Any help is greatly appreciated!
"[email protected]:~ $ sudo wget http://fars-robotics.net/install-wifi -O /usr/bin/i nstall-wifi
--2018-09-22 15:52:05-- http://fars-robotics.net/install-wifi
Resolving fars-robotics.net (fars-robotics.net)... 212.23.8.80
Connecting to fars-robotics.net (fars-robotics.net)|212.23.8.80|:80... connected .
HTTP request sent, awaiting response... 200 OK
Length: 17088 (17K) [text/plain]
Saving to: ‘/usr/bin/install-wifi’
/usr/bin/install-wi 100%[===================>] 16.69K 80.2KB/s in 0.2s
2018-09-22 15:52:19 (80.2 KB/s) - ‘/usr/bin/install-wifi’ saved [17088/17088]
[email protected]:~ $ sudo chmod +x /usr/bin/install-wifi
[email protected]:~ $ sudo install-wifi -h
!!! Failed to download update for install-wifi!
!!! Make sure you have ca-certificates installed and that the time is set correctly
[email protected]:~ $ date
Sat Sep 22 15:54:09 EDT 2018
Posted: Tue Oct 16, 2018 8:13 am
by Doriangrey
Had anyone luck with this Network adapter?
I am Facing the exact same problem and tried different things.
Im having all the time
Posted: Thu Oct 18, 2018 8:32 am
by Hootie81
MrEngman,
Thanks for the driver, works a treat!
Im trying to increase the speed of my AP and need to know the ht_capab and vht_capab flags enabled in the driver to put in hostapd.conf
And idea where i could find them? i have seen a post somewhere that the ht ones are listed with "iw list" but the vht ones he had to find in source code.
Thanks,
Posted: Thu Oct 18, 2018 9:44 pm
by MrEngman
MrEngman,
Thanks,
Hi Hootie81,
Sorry, but I don't think I can help. I compile several wifi drivers but knowing the internals of the drivers and how they work is a totally different matter. I tried command iw list and it outputs a load of data but whether that is useful I don't know.
If it helps the source I use is from https://github.com/diederikdehaas/rtl8812AU
Posted: Sun Dec 16, 2018 9:45 pm
by ilmza
sudo install-wifi
This saved my butt so much I just registered to thank you, MrEngman! I LOVE YOU.
Posted: Wed Mar 27, 2019 12:46 pm
by sealy_au
Greetings All,
MrEngman, i noticed in this thread you mention the source you use for building your drivers in your installer, which BTW I love, use it for my trl8192EU all the time, however as the driver for the rtl8812 your building off doesn't support injection or changing the tx power via "iw wlanx set txpower fixed xxxx" i went on the hunt for a different source. This lead me to https://github.com/aircrack-ng/rtl8812au which supports all of the above along with turning the LED on/off and also seems to be using a newer rtl driver then the source your building from.
I've also experienced an issue with the driver installed by install-wifi dropping the connection to me Samsung S7 hotspot, (i use a PI as a NAT gateway with two wi-fi adapters) this seems to be more stable with the alternate driver source.
anyway as your the one doing all the work for these rtl88xx drivers its completely up-to you if you'd like to look at the alternate source.
either way keep up the good work.
Posted: Thu Mar 28, 2019 12:15 am
by MrEngman
Greetings All,
Hi sealy_au,
Thanks for the post. I've got quite a list of 8812au sources from github and other places but not this one. As it's fairy new I shall definitely take a look and check it out myself.
MrEngman
Posted: Thu Apr 04, 2019 12:03 pm
by dariuszb
MrEngman - I have noticed that you have upgraded 8812au drivers to v5.2.20.2_28373.20180619. And finally my TP-Link -T4UHv1 seems to be stable on ac 5GHz channels. I have been fighting with ac stability for quite long trying multiple github sources. The best results I had were with v5.2.20_25672.20171213 from TP-link website after small tweaking to make them working on RPi. But it was not perfect neither. Your version seems to work perfectly. Only what I am missing is /proc/net/8812au access. Could you let me know which github source you are using? So maybe I can tweak it to my liking.
