[Help] Can't install PiFace Digital software
Posted: Fri Sep 29, 2017 9:16 pm
by CraftMarine
Hi ! I just got my Piface 2 for my raspberry 3.
I've managed myself to find the documentation and install everything correctly.
So, my RB run with the latest version of Rasbian.
My probleme is I can't instal the Piface digital software.
I found on the documentation the commande you need to install it.
"To install the PiFace™ Digital 2 software, open a terminal and run the following command:
sudo apt-get install python3-pifacedigitalio"
But after that, I've got this message:
E: Unable to locate package python3-pifacedigitalio
I've done the following command too:
sudo apt-get upgrade
How can I install this software ?
CraftMarine.
Re: [Help] Can't install PiFace Digital software
Posted: Sat Sep 30, 2017 6:26 pm
by pcmanbob
Hi.
A quick check using
sudo apt-cache search pifacedigitalio
on a pi running raspbian stretch does not find any packages.
but running the same on a pi running raspbian Jessie
results in
python-pifacedigitalio - The PiFace Digital I/O module.
python3-pifacedigitalio - The PiFace Digital I/O module.
So I would say the packages are not in the stretch repository, a quick search on the web suggests the package is now called pifacecommon but that package is also not in the stretch repositories.
The original package is available from here
https://pypi.python.org/pypi/pifacedigitalio/
you install it manually like this
wget https://pypi.python.org/packages/06/33/38ff94cd74442da0f2d18241b88ebd3c8a89489ddb1d880d72a67306569c/pifacedigitalio-3.0.5.tar.gz
tar xvzf pifacedigitalio-3.0.5.tar.gz
cd pifacedigitalio-3.0.5/
for python2
sudo python setup.py install
for python3
sudo python3 setup.py install
or the new package is available for here
https://pypi.python.org/pypi/pifacecommon/4.0.0
wget https://pypi.python.org/packages/6d/23/ecfca34aeabb6bb720c96cb5ed0c9c768b012d13174cee25c67aa5dc8c8a/pifacecommon-4.0.0.tar.gz
tar xvzf pifacecommon-4.0.0.tar.gz
cd pifacecommon-4.0.0
for python2
for python3
I have run both sets of instructions on a pi running stretch and the packages do install but I don't have a piface so I don't have anyway to test if they actually work.
Posted: Sun Oct 01, 2017 3:47 pm
by DirkS
pcmanbob wrote: ↑Sat Sep 30, 2017 6:26 pm
Why not use pip / pip3 to install them?
Posted: Sun Oct 01, 2017 6:36 pm
by pcmanbob
Only because I have never used pip, always just done it the way shown, because that was the way I was shown.
Posted: Sun Oct 01, 2017 7:02 pm
by DirkS
pcmanbob wrote: ↑Sun Oct 01, 2017 6:36 pm
sudo pip install pifacecommon
sudo pip install pifacedigitalio
should install the latest versions (use pip3 for python 3)
Posted: Mon Oct 02, 2017 4:28 pm
by CraftMarine
I've tryed first, with pip (way faster) and it worked
even with pip3
thanks pcmanbob and Dirks for your help
Posted: Sat Nov 25, 2017 10:20 am
by bbreton
thanks pcmanbob and Dirks for your help.
I thought I could use pifacedigital-emulator as it's in the pifacedigitalio-3.0.5 package but I can't.
Have you got an idea to install it?
thanks
bbreton
Posted: Sat Nov 25, 2017 1:50 pm
by pcmanbob
Hi.
I think you need to install it as a separate package, as per the install instructions.
https://piface.github.io/pifacedigitali ... ation.html
Posted: Mon Nov 27, 2017 9:15 am
by bbreton
Hi pcmanbob,
thanks for your response. I've tried to install the Emulator as explained in the link you gave me but it doesn't work, here is the message
E: Unable to locate package python3-pifacedigital-emulator
It seems this package is not in the stretch repository.
I tried to install it manually as you explained previously (sudo pip3 install pifacedigitalio) but the Emulator still does not installed
If you have an idea to solve this problem it would be great for me!
bbreton
Posted: Mon Nov 27, 2017 10:38 am
by B.Goode
At least 2 other people have encountered the same problem and reported it to the PiFace Developers/Maintainers:
https://github.com/piface/pifacedigital ... r/issues/9
Posted: Fri Dec 01, 2017 9:10 am
by bbreton
I saw this report but no solution is given. The last post was in october 12th. That's why I try on other forums.
Is there someone who solved the problem of installing the piface digital-emulator on strech?
Thanks for your help
bbreton
Posted: Fri Dec 01, 2017 11:28 am
by DougieLawson
The PiFace stuff is bordering on
"abandonware". So the only way to fix it would be to download (or fork) a copy of the stuff on the github and see if you can re-write the code to get it working with your hardware and Raspbian Stretch.
I've got a PiFaceCAD on one of my Raspberries but I'm driving it with my own code written in C rather than python or python3.
Posted: Sat Dec 02, 2017 10:09 am
by bbreton
Thanks DougieLawson for this information.
It's a pity if the Piface is abandonned because it's a very usefull card. I haven't seen something similar to replace it!
Could you say more about the procedure you used to developp your own code in C for this card?
bbreton
Posted: Sat Dec 02, 2017 10:38 am
by DougieLawson
The PiFaceCAD has a 23S17 SPI chip. The schematic for it is also available. So it's trivial to write C code to run it.
If I get a chance over the weekend I'll build a sample program for you.
Posted: Mon Dec 04, 2017 9:25 am
by DougieLawson
Posted: Mon Jan 22, 2018 3:02 pm
by longshanks
Interesting thread. I managed to install pifacecommon, but not sure that it is the same as the piface digital emulator as it doesn't run. Anybody got any idea or updates?
Posted: Sat Jan 11, 2020 12:02 am
by BozoCake
As mentioned that it is found in the Jessie repository, I successfully got the emulator and python running. I downloaded Jessie from here
http://downloads.raspberrypi.org/raspbi ... 017-07-05/ and ran the set up instructions as documented.
