tonychang-uk
RASPBIAN STRETCH auto login as root not working
Tue Sep 12, 2017 11:18 am
in Jessie we can edit /etc/lightdm/lightdm.conf login as root and auto login
but in stretch can't login as this way.
How to auto login as root ?
RaTTuS
Re: RASPBIAN STRETCH auto login as root not working
Tue Sep 12, 2017 11:37 am
you don't want to log in as root under x
it is just the wrong way of everything
Covfefe
tonychang-uk
Tue Sep 12, 2017 10:27 pm
I want login as root under x , Jessie can use this way, but Stretch can't use this way.
any other way can login as root under x ? Thanks !
RaTTuS
Wed Sep 13, 2017 7:00 am
before I answer this, can you explain to us
why you want to run as root under x
because what you are asking for is so monumentally insecure it is like <REDACTED>
Covfefe
tonychang-uk
Wed Sep 13, 2017 9:32 am
Because we need load driver for UART HAT, need use root for permission.
Pi user can't use some hardware resource.
tonychang-uk
Fri Sep 15, 2017 11:06 am
Any one know how to setting "RASPBIAN STRETCH auto login as root under x" ???
klricks
Fri Sep 15, 2017 1:04 pm
Have you tried changing to root using su command under x?
First you need to set a root password:
sudo passwd root
Then
su
And enter the new root password
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
tonychang-uk
Sat Sep 16, 2017 12:51 pm
sudo passwd root
Then
su
need automatic login as root, don't need input any password? got ideal how to setting??? Thanks!
knute
Sun Sep 17, 2017 8:45 pm
So the driver only loads when you use X? You can't use a [DesktopEntry] file executed with sudo? You know that running X as root creates a whole host of possible issues?
Is your default user still pi? If it is then do this:
Click the Raspberry -> Preferences -> Raspberry Pi Configuration
Set Boot: To CLI
Set Auto login: Login as user 'pi'
Click the OK button
Edit pi's /home/pi/.profile file and put this at the end:
if [[ $(tty) == "/dev/tty1" && $ROOTX != "true" ]]; then
ROOTX="true"
export $ROOTX
sudo startx
fi
and reboot your computer.
It is moderately stable with nothing else running but who knows after you start installing drivers and other software.
Disclaimer: There is always a small risk of nuclear detonation if you run X as root.
asandford
Mon Sep 18, 2017 1:24 am
This. Don't do it.
artisticforge
Wed Sep 20, 2017 12:06 pm
hello
If you are using lightdm, you need to edit /etc/lightdm/lightdm.conf
set
autologin-user=root
save edit
restart lightdm
Side comment: This is a terrible idea. You need to rethink the project for other alternatives
than brute force with root.
artisticforge ><>
knute
Thu Sep 21, 2017 6:55 pm
hello
set
autologin-user=root
save edit
restart lightdm
That doesn't actually work on Stretch.
tonychang-uk
Thu Oct 12, 2017 1:24 pm
hello
set
autologin-user=root
save edit
restart lightdm
/etc/lightdm/lightdm.conf not work for stretch
asandford
Fri Oct 13, 2017 1:12 am
That's hopefully a feature as autologin as root is a an exceptionally bad/naive/stupid idea.
ab1jx
Tue Apr 10, 2018 11:55 pm
Ever hear "If you're not part of the solution, you're part of the problem"? Jeez. That's like telling someone they should never root an Android phone. Take the training wheels off, but you might fall down. You might screw it up so bad you have to reinstall, but you probably won't make the same mistake twice. I've been running as root for 20 years. I remember when you had to use adduser to have an alternative to root. AFAIK OpenBSD is still like that.
I think it's a deeply-ingrained permissions issue. Something somewhere specifically forbids you from doing autologin as root. Or else changing the autologin-user by itself isn't enough anymore. Almost smells like selinux at work, but it probably isn't. Android versions past about 5.0 have selinux enabled by default, it's a royal pain putting Debian on one, but it's the same sort of big brother is watching feeling.
If rooting Android wasn't a challenge there probably wouldn't be https://www.xda-developers.com Similar idea though, you paid your money for this hardware, you should have the right to do what you want with it (as long as it doesn't hurt anybody else).
RaTTuS
Wed Apr 11, 2018 7:30 am
running x as root is way worse than running windows as admin IMO
however YMMV
Covfefe
asandford
Thu Apr 12, 2018 12:28 am
I've been running as root for 20+ years as well, but I don't need to ask how to do it - if you need to ask you shouldn't be doing it.
ab1jx
Thu Apr 12, 2018 12:06 pm
Well, I didn't need to ask until Stretch. Hint, look at /etc/pam.d/lightdm-autologin, I won't say more. I wanted autologin as root on my tablet because there's no physical keyboard. I got it eventually.
I'm behind NAT on a dynamic IP so I don't really worry about people getting in. But the touchscreen does introduce a certain clumsiness factor. I don't drag and drop much anyway, it's a foreign concept to me.
ab1jx
Thu May 10, 2018 6:58 pm
And try dmesg | grep -i pam sometime, I see:
[   11.206570] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
Where did all that come from? Pam, apparmor, selinux? Yuck.
OK, cd /boot then
grep -r -i pam .
Binary file ./start.elf matches
Binary file ./kernel.img matches
Binary file ./kernel7.img matches
Binary file ./start_db.elf matches
Binary file ./start_x.elf matches
There was probably less of it in Jessie. I have an old Debian laptop from last summer and it's not in there at all. uname -a on that says
Linux hp 3.16.0-4-amd64 #1 SMP Debian 3.16.43-2 (2017-04-30) x86_64 GNU/Linux
By the /etc/sources.list file it's Jessie.
donbrew
Fri May 11, 2018 8:28 pm
Is it because the root user is disabled by default in Stretch? In order to activate it you have to give it a password.
The security Nazis strike again!
asandford
Fri May 11, 2018 9:15 pm
AFAIA, root has never had a password in any Raspbian version because you should never need to log in as root (there are other ways to get the privs you think you need).
This discussion has been done to death here and other places. It's not a case of security Nazis, or being insultingly called a problem ("If you're not part of the solution, you're part of the problem"), we're actually trying to stop you making all the mistakes we made years ago...(and I've worked many a long night recovering Sun systems that have been trashed by DBAs and developers who insisted they needed root access).
...and when the people wanting such access FUBAR, they tend to shout the loudest "Why didn't you tell me", "There should be things in place to stop this", "Why did rm -f * wipe my system"
donbrew
Sun May 13, 2018 4:19 pm
Well gee, why does the wiki explain how to enable the root user then? And why is it so easy to do?
I currently login as root with WinSCP/Putty so I can edit config files with notepad++ instead of sudo nano in Putty; that makes for a lot less typing of paths.
I totally agree that commercial operations just don't need anyone to have root access. I am a hobbyist.
asandford
Mon May 14, 2018 12:13 am
I think the goal is to have root the default login user, complete with GUI.
No more messing around with sudo.
No more hard things like working out permissions and groups.
No more being told they can't do things - this is my Pi goddammit! - I own it I must have complete control!
Oh course, when it all goes all wrong - it's why would it let me do this? how can I recover it?
We've seen this many times here, and it always ends in tears.
Return to “Raspbian”
Who is online
Users browsing this forum: Bing [Bot] and 31 guests
