wally333
Install Stretch and set it up on Pi3 then move SD card to PiZero-W?
Tue Sep 12, 2017 5:26 am
I've a problem building pybluez[ble] where it crashes my PiZero-W as described in this thread:
viewtopic.php?f=32&t=192820
It builds fine on my RPi3
I'm using Raspbian-stretch 2017-09-07 image.
Can I expect the card setup on the Pi3 to "just work" if moved to the PiZero-W
I'd just try it but I've the "official" PiZero case and a camera module, I had enough trouble getting the camera installed correctly that taking it apart again to swap SD cards is very unappealing!
Re: Install Stretch and set it up on Pi3 then move SD card to PiZero-W?
Tue Sep 12, 2017 6:32 am
It will "just work", as long as /boot/kernel.img and /lib/modules/4.9.48+ exists.
The RPi2 & RPi3 use /boot/kernel7.img and /lib/modules/4.9.48-v7+
The rest of the stuff on the SDCard is version agnostic.
Note: your kernel version will differ.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
Since 2012: 1B*5, 2B*2, B+, A+, Zero*2, 3B*3
Please post ALL technical questions on the forum. Do not send private messages.
wally333
Tue Sep 12, 2017 4:37 pm
Thanks, this worked great, so great that next time I need to setup another PiZero-W I'll do the SD card on the Pi3 (or Pi2 with WiPi dongle). I used the Pi2 with WiPi dongle and everything booted up fine, I then built the pybluez[ble] successfully and returned the card to the PiZero-W.
None of the python examples seemed to do anything with my Radius Dot beacons despite no errors when running, but that is a problem for another day, as my kludge of a shell script scanning with hcitool | hcidump and a node-red flow seems to be working well enough sending beacon presence states over MQTT that I can move on to the next phase of the project.
Return to “Raspbian”
Who is online
Users browsing this forum: No registered users and 34 guests
