beta-tester
Raspbian Stretch: login cursor jumps to pos0 of line.
Mon Sep 11, 2017 8:18 am
hi,
since raspbian stretch images were released (2017-08-16 and 2017-09-07),
i have an issue, that on the login terminal the cursor is jumping to the begin of the line after a while.
what i did:
  1. flash 2017-09-07-raspbian-stretch-lite.img to sd card
  2. boot rpi
  3. wait until login appears ("raspberrypi login:")
  4. wait further longer (~10..15s)
  5. see, that the blinking cursor is jumping to the begin of line, just in front of the "raspberripi login:".
this happens every time after a fresh boot/reboot.
EDIT: it seems to be network related.
in the previous example i had the ethernet cable connected. without the ethernet cable connected, the cursor behaves quite normally.
even when i plug the ethernet cable later, the cursor does not jump.
so reboot without ethernet cable connected, the rpi behaves as usual.
but when the ethernet cable is connected at booting, the cursor is jumping after a while
(~10..15 seconds after "raspberrypi login:" message appears).
i tested 2017-08-16-raspbian-stretch-lite.img and 2017-09-07-raspbian-stretch-lite.img and 2017-09-07-raspbian-stretch.img;
i tested on a RPi 2 B and a RPi 3 (and RPi1B rev.1);
i tested the RPi's on two different routers (192.168.ccc.xxx and the other 10.bbb.ccc.xxx);
on all combinations the the same behavior.
is the ethernet cable is connected, the cursor jumps after 10..15 seconds after the "raspberrypi login:" message appears.
this is very annoying, because the cursor will also jump, then you are typing in your user name at login. that will be very confusing.
EDIT2: it happens when there is just a switch on the other end of the ethernet cable
(only a switch without any other devices connected, except the RPi itself)
sometimes only the cursor just jumps to the beginning of the line,
sometimes the cursor jumps to the beginning of the line with erasing everything behind the cursor.
EDIT3: added 2017-09-07-raspbian-stretch.img to thetested images (when setup to boot into console).
same behavior - cursor jumps
RPi Model B (rev1, 256MB) & B (rev2, 512MB) & B+, RPi2B (1GB), 64GB microSDXC1 class 10, HDMI 1920x1080, keyboard-mouse-combo (wireless), PiCamera, ethernet-cable, 5V/1.2A power supply, Wifi dongle (rt5370)
biasha
Re: Raspbian Stretch: login cursor jumps to pos0 of line.
Tue Sep 12, 2017 3:51 pm
i confirm this.
i have not tested, but it looks like additional wifi interfaces (i have 3) make it worse. screen blinks, redraws all the time and makes it almost impossible to use.
FTrevorGowen
Wed Sep 13, 2017 5:07 pm
I've also observed similar, intermittent, behaviour with Stretch (full), on a P3B, booting to command-line, but not subsequently (following a "startx") within a desktop terminal. I put it down to "USB switching" or keyboard issues, since my (wired) keyboard & mouse are shared between the Pi (whatever model, O.S etc. I currently testing GPIO driven hardware with) and a Gigabyte Brix via a USB switch** (and the monitor via an HDMI switch**) and, occasionally, just after "switch over", some key presses were "missed". (Most of the time I'm only using a wired network connection)
Trev.
** Somewhat similar to this older arrangement:
http://www.cpmspectrepi.uk/raspberry_pi ... tcher.html
but w/o the external power to the HDMI switch (that was needed for my "early" Pi's)
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
wally333
Wed Sep 13, 2017 7:55 pm
I've also observed it. But since I usually either boot to auto-login with the GUI, or tun off auto login and boot to a usually unused console (headless) and use ssh, I've never investigated further. I can add I've notices it with Pi3, pi2 and PiZero-W with stretch 2017-09-07 as I've decided to upgrade and sync all my Pi versions.
FTrevorGowen
Wed Sep 13, 2017 10:34 pm
@beta-tester, @biasha & @wally333 - what PSU are you using? (I'm using this official one: http://www.cpmspectrepi.uk/raspberry_pi ... _Models.29 which "pre-dates" the P3B) @biasha - your "more severe" issues may more likely to be power related, especially if your "extra" WiFi devices are "power hungry".
Trev.
beta-tester
Sat Sep 16, 2017 4:15 pm
Trev.
my issue on my RPi it is not PSU related. as PSU, i use >1.5A for RPi1 & PRi2 and >2.5A for RPi3 with no ripples/spikes on 5.1V on the hot end of the micro usb plug.
the issue i observed was tested on RPi with plugged ethernet cable only, nothing else was pluggged, on Stretch full&lite
(2017-08-16/2017-09-07).
on Jessie full&lite (<=2017-07-05), that issue does not exist.
it does not matter, if a usb keyboard is plugged or not.
only the network adapter has to be activated by a ethernet cable on a working switch as minimum, to reproduce that issue.
i didn't tested yet, if it will happen as well on a RPi3 with working WiFi only.
the cursor jump only happens only one single time at each boot into the console (with or without autologin). doesn't matter if Stretch full or lite version is installed, but it must be setted up to boot into the console.
but you are right. some of the other users issue reports here sounds more like PSU related problems.
PS.: i don't know, what the problem is to reproduce/test the issue:
1. simple flash Raspberry Stretch lite (2017-09-07) to a SD card,
2. plug that card to a RPi.
3. plug HDMI cable to RPi and the other end to TV.
4. plug ethernet cable to RPi and the other end to a working switch/router
5. power up the RPi.
6. wait til login message.
7. wait ~20 sec.
8. answer the question, is the cursor now in the first column of the line or not.
FTrevorGowen
Sat Sep 16, 2017 8:14 pm
beta-tester wrote: ...
7. wait ~20 sec.
Unfortunately (at least for me) it's an "intermittent problem" ie. difficult to reproduce consistently - ie. it hasn't happened during the last dozen or so boot-ups w/o any O.S. updates or connected hardware changes. But I am making greater effort to switch the keyboard/mouse USB and HDMI connection as soon as possible after power up (the PSU switch is at floor level whereas the USB and HSMI switches are on the desk, to the left of and behind the monitor - hence the second or two delay :o )
Trev.
beta-tester
Sun Sep 17, 2017 5:51 pm
@FTrevorGowen: sorry, it wasn't my intention to blame you im my previous "PS".
my hope was that somebody/the creator of the Raspbian Stretch image will see that post and see, verify and confirm that it is a real existing issue...
but to me, it seems, that none of the image creators seen that thread. :(
Sun Sep 17, 2017 6:05 pm
The problem will lie with the getty that's running on tty1.
/sbin/agetty --noclear tty1 linux
that gets started from /lib/systemd/system/getty@.service.
agetty is part of the util-linux package
The bug tracker for it is here: https://bugs.debian.org/cgi-bin/pkgrepo ... t=unstable
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
beta-tester
Sun Sep 17, 2017 9:22 pm
at the moment i can not find a bug report, that fits to my observed issue.
is there something, i can turn on or off to get rid of the cursor jump on the console?
FTrevorGowen
Sun Sep 17, 2017 9:38 pm
A "bit of an update" from my P.o.V.: As part of setting up/testing a "three Pi's vesa-mounted to one monitor setup" I've just downloaded and written an up-to-date stretch (full) image and booted it up on a powerbank-powered (no "thunderbolts") early Pi B2 (ie. older than a B+) with a wireless mini-keyboard and a WiFi dongle plugged into its USB ports. For that setup (so far) no "login cursor jump" has been observed.
Trev.
Sun Sep 17, 2017 9:41 pm
Simply create a bug report.
MQTT Evangelist
FTrevorGowen
Mon Sep 18, 2017 3:31 pm
Further update on my obs.
1) @beta-tester can you confirm that you didn't have "auto-login" enabled (from your O.P. you appear not to).
2) I now suspect I'm seeing a different issue in that when I find the cursor to be at pos0 an unwanted "auto-login" has happened. Exactly how that's being triggered I'm not sure but may be related to whether I shutdown from the command-line direct (whether running startx --> desktop and subsequently returning there or not) or from a remote login.) Depending upon whether I'm testing "stuff hanging from the GPIO's" I may log into a Pi (currently usually my P3B) fully (ie. command-line --> startx --> desktop) or just to command-line, and then "KVM" switch back to a Gigabyte Brix and re-connect via a PuTTY SSH session. In the latter case I'm often also remotely logged in to another Pi (a P2B) which is running the wiki from which I generate my webpages and during editing sessions therein may need to transfer 'photos from the Brix and console text from the P3B session etc. I usually "KVM" switch back to the P3B to shut it down but occasionally do so from the PuTTY session. I'm wondering if the latter is the "trigger" for what I've noted.
Trev.
beta-tester
Mon Sep 18, 2017 3:54 pm
but i still don't know, if it is an issue of Debian in general or if it is only an issue in Raspbian distro. if only Raspbian is affected then it makes no sense to open a (faulty) bug report on Debian.
it does not matter, if auto-login is enables or not.
i tried both.
without auto-login, then the cursor jumps to first column in front of the login message "raspberry login:".
if i use auto-login, then the cursor jumps to first column in front of "pi@raspberry:~ $"
Mon Sep 18, 2017 4:51 pm
What possible changes would Raspbian need to the upstream package? If it's a bug, it's a bug in DebIan.
MQTT Evangelist
HawaiianPi
Mon Sep 18, 2017 11:50 pm
The bug seems pretty benign, as it doesn't affect the actual login process. I just booted my Raspbian Stretch Lite SD card and waited for the cursor to jump to the beginning of the line, then I entered my login name and password as always, and even though it looked odd on the screen, the login worked as expected.
So you can pretty much ignore it as far as I can tell.
beta-tester
Tue Sep 19, 2017 6:12 pm
yes, i know, that it is more an "cosmetically" issue.
but it looks so ugly.
i want to know the reason why it happens and where exactly it cames from to get rid of that issue.
or better to tell it somebody who is responseble for that issue.
shatteredsword
Fri Nov 03, 2017 5:26 pm
this bug is still around and honestly the only reason i haven't moved to Stretch.
It also doesn't just do it at login, sometimes it will jump in the middle of typing a command.
HawaiianPi
Sat Nov 04, 2017 4:57 am
Are you all still experiencing this after fully updating the OS?
There was a pretty big update/upgrade recently, and I haven't seen the cursor jump since then.
Tested on Raspberry Pi Zero v1.3 and Pi3B
2017-09-07 Raspbian Stretch Lite
sudo apt-get update && sudo apt-get dist-upgrade -y
Tested with SSH and a serial console cable and observed no cursor jump in Windows 10 WSL terminal. Also, no cursor jump in PuTTY terminal (SSH) or Raspbian Stretch Linux terminal on my Pi3 (SSH from Pi3 to Pi Zero).
Rebooted a bunch of times to see if it was a fluke, but it seems to be fixed.
beta-tester
Sat Nov 04, 2017 12:47 pm
i did the upgrade, and indeed i go a new bootloader and kernel "...raspberrypi-kernel (1.20171029-1) over (1.20170811-1)..."
but i still have the exact same issue.
RPI1, Raspbian Stretch Lite, directly connected to TV via HDMI.
booting RPi, showing up "raspberry login:", after some seconds the cursor jumps to the first column of the same row.
sometimes the cursor only jumps to the first column, sometimes the cursor jumps to the first column and deletes everything between previous position and first column position.
beta-tester
Fri Dec 01, 2017 10:36 am
not fixed with the actual Raspbian Stretch Lite from 2017-11-29
downloads.raspberrypi.org/raspbian_lite/images/raspbian_lite-2017-12-01/2017-11-29-raspbian-stretch-lite.zip.
still an issue!
Fri Dec 01, 2017 11:13 am
still an issue!
What part of having to press [ENTER] is an issue?
MQTT Evangelist
beta-tester
Fri Dec 01, 2017 11:27 am
when the RPi is booting from the SD card, the issue still appears.
but when the same RPi is network-booting to the same Raspbian Stretch Lite 2017-11-29, then that issue does not appear.
i tested it on an RPi3 and RPi2 ... all shows that issue
and the RPi3 i tested also without SD card and only network-booting... then it does not show that issue.
i tested all the RPis with the same HDMI TV (1920x1080), same keyboard, same powersupply (rated for RPi3), same SD card* connected.
*) no SD card for network-booting
PS.: the cursor even jumps when auto login is enabled in raspi-config.
so i still think it is network related or some services- when network cable is not connected the cursor does not jump - and in case of RPI3 network-booting with network cable connected, maybe a service is started in another order so that issue will not appear there even with network cable connected.
still an issue!
what kind of comment is this???
when there is an issue, then it should be fixed.
ans it is an issue. when the cursor jump will erase the line where is was... so you don't see the login prompt.
Fri Dec 01, 2017 12:06 pm
Learn to press [ENTER] once to move the cursor and stop moaning about things that are irrelvant.
Or hack at the systemd getty service file to change the options that getty runs with and solve the trivial problem yourself.
root@apollo:/lib/systemd/system # cat getty@.service
#  This file is part of systemd.
#  systemd is free software; you can redistribute it and/or modify it
#  under the terms of the GNU Lesser General Public License as published by
#  the Free Software Foundation; either version 2.1 of the License, or
#  (at your option) any later version.
[Unit]
Description=Getty on %I
Documentation=man:agetty(8) man:systemd-getty-generator(8)
Documentation=http://0pointer.de/blog/projects/serial-console.html
After=systemd-user-sessions.service plymouth-quit-wait.service
After=rc-local.service
# If additional gettys are spawned during boot then we should make
# sure that this is synchronized before getty.target, even though
# getty.target didn't actually pull it in.
Before=getty.target
IgnoreOnIsolate=yes
# IgnoreOnIsolate causes issues with sulogin, if someone isolates
# rescue.target or starts rescue.service from multi-user.target or
# graphical.target.
Conflicts=rescue.service
Before=rescue.service
# On systems without virtual consoles, don't start any getty. Note
# that serial gettys are covered by serial-getty@.service, not this
# unit.
ConditionPathExists=/dev/tty0
[Service]
# the VT is cleared by TTYVTDisallocate
ExecStart=-/sbin/agetty --noclear %I $TERM
Type=idle
Restart=always
RestartSec=0
UtmpIdentifier=%I
TTYPath=/dev/%I
TTYReset=yes
TTYVHangup=yes
TTYVTDisallocate=yes
KillMode=process
IgnoreSIGPIPE=no
SendSIGHUP=yes
# Unset locale for the console getty since the console has problems
# displaying some internationalized messages.
Environment=LANG= LANGUAGE= LC_CTYPE= LC_NUMERIC= LC_TIME= LC_COLLATE= LC_MONETARY= LC_MESSAGES= LC_PAPER= LC_NAME= LC_ADDRESS= LC_TELEPHONE= LC_MEASUREMENT= LC_IDENTIFICATION=
[Install]
WantedBy=getty.target
DefaultInstance=tty1
MQTT Evangelist
beta-tester
Fri Dec 01, 2017 1:12 pm
what the ...
it isn't irrelevant to report things that doesn't look right. even it seems to be a tiny little thing.
and as long nobody is fixing or giving at least a proper hint, where the issue is coming from, that long people should keeping report alive.
you know... no moaning... means... no development, no invention = stone age.
[Unit]
Before=getty.target
IgnoreOnIsolate=yes
# graphical.target.
# unit.
[Service]
Type=idle
Restart=always
RestartSec=0
UtmpIdentifier=%I
TTYPath=/dev/%I
TTYReset=yes
TTYVHangup=yes
KillMode=process
IgnoreSIGPIPE=no
SendSIGHUP=yes
[Install]
thank you giving that hint.
until now it wasn't clear to me, where this issue is coming from and where to start.
Return to “Raspbian”
Who is online
Users browsing this forum: TinRobot and 10 guests
