Rascas
Re: Kodi on Raspbian Stretch
Thu Sep 21, 2017 12:06 am
Tvheadend is not available on debian/raspbian repos, you have to go to the tvheadend project page and follow their instructions to install their repo and then the server.
cjan
Thu Sep 21, 2017 3:04 am
ok, all setup done, thanks.
but, only play HD channels not SD, in jessie can play HD & SD both.
Rascas
Thu Sep 21, 2017 9:49 am
Did you enabled the extra codecs like explained in the first post ? And make sure you are using the default settings in Kodi of mmal enabled and omxplayer disabled. If after that they still don't work, it is mostly likely something about your TVHeadend server configuration, it is better to ask in their foruns.
cjan
Thu Sep 21, 2017 12:24 pm
ok, disable omxplayer, done & thanks.
gyoezoe
Thu Sep 21, 2017 3:40 pm
Hi, can someone help me to make my rpi3 - stretch - kodi system autostart with kodi at boot?
Thank You
cjan
Fri Sep 22, 2017 9:55 pm
one problem remained.
using start tvheadend.service not enable, but process still there after reboot.
cjan
Mon Sep 25, 2017 11:40 am
tvheadend got update, and problem solved.
pap75
Thu Oct 12, 2017 11:41 am
I have just installed kodi 17.4 on a fresh new raspbian stretch, but with a newly created user, not the default pi. It is not working.
I guess it could be due to groups to which the user must belong. It was mentioned, but it does not seem to have been posted here. Do we have to assume that groups are the same in previous versions?
Rascas
Thu Oct 19, 2017 10:42 am
I updated the first post with more information and it should anwser your questions.
cjan
Re: [Guide] Kodi on Raspbian Stretch
Tue Oct 24, 2017 12:01 am
there bug fix version 17.5 now.
*Fix playback of DVD file over network on Linux
lasakro
Tue Oct 24, 2017 3:09 am
What am I missing to get 17.4 out of full screen on Stretch? Gone are the 2 options under Display mode for Window or Full, only resolution. Backslash does nothing. BTW, I'm used to running Kodi on Ubuntu with AMD64 so maybe this option is disabled for the ARM to conserve resources?
Rascas
Tue Oct 24, 2017 9:44 am
You can't go to windowed mode in Kodi on the Raspberry Pi, either on Raspbian Stretch, Jessie or even LibreELEC and such, it is currently a limitation on the Raspberry Pi.
Rascas
Tue Oct 31, 2017 1:44 pm
Kodi 17.5 is now available on Stretch.
Make sure you do a upgrade/dist-upgrade to get the latest kernel/firmware, otherwise hevc videos will crash Kodi.
Pitel
Contact: Website Facebook Google+ Skype Twitter YouTube
Thu Nov 02, 2017 11:32 am
I've installed all the visualizations packages via apt (without -dev), but I can't see them in Kodi. Any idea why?
Rascas
Thu Nov 02, 2017 3:03 pm
Restart Kodi, go to Add-ons -> My add-ons -> Look and Feel -> Visualization and enable them.
Pitel
Thu Nov 02, 2017 7:11 pm
All right, now I can choose them. But I don't see any visualization. Is it some known bug?
Rascas
Thu Nov 02, 2017 8:00 pm
No. Visualizations are only for when you play music:
http://kodi.wiki/view/Music_playback#Visualizations
roman.ukhov
Fri Nov 03, 2017 8:58 am
Rascas wrote:
Tue Sep 05, 2017 2:55 am
If you want autostart Kodi at boot but also keep the Desktop Environment on the background, just edit the file ~/.config/lxsession/LXDE-pi/autostart and add a line in the end with:
@kodi
This doesn't work for me, as well as other options to start kodi from code. I can start kodi from terminal just typing "kodi" or running a shell script with "kodi" in it. But when I try to use that shell script to run kodi automatically at startup or from TV remote (both via CEC and lirc), it do not starting. What can be the reason of such behaviour?
Rascas
Fri Nov 03, 2017 2:18 pm
@kodi
If it starts from terminal, I see no reason for it not auto-starting, if correctly done. Those 2 options on the first post were obviously tested on a clean Raspbian Stretch install and confirmed to be working, but the option 2, was only tested with the default user "pi". Are you trying to run Kodi as a different user ? If so, there are also instructions on the first post on how to configure Kodi to run as a different user. Also note that ~/.config/lxsession/LXDE-pi/autostart is not a shell script but a LXDE configuration file for the respective user running it. Use that one and not the global one in /etc. If after all of this it still doesn't work, please post what you have in that file and also in ~/.cache/lxsession/LXDE-pi/run.log.
Running it from a TV remote with CEC or Lirc is a more complex thing, but should be doable also.
JakoobCZ
Sun Nov 05, 2017 3:07 pm
Great guide indeed and many thanks for it. I just had issues with the autostart by copying yours stuff.
Solved by:
sudo nano /lib/systemd/system/kodi.service
and then paste
[Unit]
Description = Kodi Media Center
After = remote-fs.target network-online.target
Wants = network-online.target
[Service]
User = pi
Group = pi
Type = simple
ExecStart = /usr/bin/kodi
Restart = on-abort
RestartSec = 5
[Install]
WantedBy = multi-user.target
cjan
Tue Nov 07, 2017 6:41 am
audio problem, play youtube or dvb-t and hear a sound 'po' than no sound.
last kernel updated, here is log.
12:00:15.494 T:1657180928  NOTICE: Creating audio thread
12:00:15.494 T:1441837824  NOTICE: running thread: CVideoPlayerAudio::Process()
12:00:15.507 T:1657180928  NOTICE: Opening stream: 1 source: 256
12:00:15.507 T:1657180928  NOTICE: Creating video codec with codec id: 28
12:00:15.516 T:1441837824  NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
12:00:15.519 T:1657180928  NOTICE: Opening stream: 2 source: 256
12:00:16.239 T:1450775296 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
12:02:40.028 T:1441837824 WARNING: Previous line repeats 2 times.
12:02:40.029 T:1441837824   ERROR: CVideoPlayerAudio::DecodeFrame - Decode Error. Skipping audio packet (-1094995529)
12:05:38.007 T:1871704832   ERROR: Previous line repeats 1 times.
12:05:38.008 T:1871704832   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.audio_render wait event timeout
12:05:38.008 T:1871704832   ERROR: CAESinkPi::AddPackets timeout
12:05:39.034 T:1871704832   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.audio_render wait event timeout
12:05:39.034 T:1871704832   ERROR: CAESinkPi::AddPackets timeout
12:05:39.238 T:1441837824   ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
12:05:40.060 T:1871704832   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.audio_render wait event timeout
12:05:40.060 T:1871704832   ERROR: CAESinkPi::AddPackets timeout
12:05:41.052 T:1441837824   ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
12:05:41.086 T:1871704832   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.audio_render wait event timeout
12:05:41.086 T:1871704832   ERROR: CAESinkPi::AddPackets timeout
12:05:42.112 T:1871704832   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.audio_render wait event timeout
12:05:42.113 T:1871704832   ERROR: CAESinkPi::AddPackets timeout
12:05:42.138 T:1871704832   ERROR: CActiveAESink::OutputSamples - failed
12:05:42.160 T:1441837824   ERROR: CVideoPlayerAudio::DecodeFrame - Decode Error. Skipping audio packet (-1094995529)
12:05:43.222 T:1871704832   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.audio_render wait event timeout
12:05:43.223 T:1871704832   ERROR: CAESinkPi::AddPackets timeout
12:05:44.038 T:1441837824   ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
12:05:44.249 T:1871704832   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.audio_render wait event timeout
12:05:44.249 T:1871704832   ERROR: CAESinkPi::AddPackets timeout
12:05:45.275 T:1871704832   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.audio_render wait event timeout
12:05:45.275 T:1871704832   ERROR: CAESinkPi::AddPackets timeout
12:05:45.649 T:1441837824   ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
12:05:46.301 T:1871704832   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.audio_render wait event timeout
12:05:46.301 T:1871704832   ERROR: CAESinkPi::AddPackets timeout
12:05:47.327 T:1871704832   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.audio_render wait event timeout
...etc
Rascas
Wed Nov 08, 2017 8:22 pm
...etc
A full debug log is required to check problems:
http://kodi.wiki/view/Log_file
cjan
Wed Nov 15, 2017 5:46 am
Kodi v17.6 final: The very last, released.
xean
Wed Nov 15, 2017 11:18 pm
I've followed your guide, and it works great, but I'd like to execute kodi only if HDMI cable is connected at boot. This way, I can power RPi and use it like a headless server, and only execute kodi if I want to plug it into the tv.
How can I do that? I've searched about tvservice but I don't really know how to relate it with the boot service.
Thank you
tom3f
Sun Nov 26, 2017 2:09 pm
Hello i installed rasbian stretch lite from noobs. Then installed latest Kodi by apt-get update; apt-get install kodi. I created new user named tomas. Added these groups : adm, tty, disk, dialout, cdrom, sudo, audio, video, plugdev, games, users, input, netdev, spi, i2c, gpio.
Added Kodi.service for systemctl as you suggested in first post and used group and user named tomas.
After reboot Kodi works. But I can only exit. Missing shutdown and reboot from menu. And other most important problem. Kodi doesn't mount/display USB drive when I connect it. When i remove USB drive from USB, I see notification about removal in kodi. But I don't see content of USB drive or usb drive at all in menu. How can I achieve that? On Ubuntu there is no problem with Kodi and mounting USB. After plug in I see new drive in movies and music section. Thank you.
Return to “Raspbian”
