pi_lover
Firejail .... Illegal instruction
Sat Aug 19, 2017 3:58 am
Using Raspbian Jessie, Installed firejail from Jessie Backports coz firejail is not available in the Jessie repos.
When I do firejail <application> I get
$ firejail chromium-browser
Illegal instruction
How to fix this ?
rpdom
Re: Firejail .... Illegal instruction
Sat Aug 19, 2017 4:12 am
Which file did you download and what model Pi are you trying to run it on?
The Debian version will not run on a Pi Zero or Pi 1.
pi_lover
Sat Aug 19, 2017 7:05 pm
I downloaded firejail from Jessie backports. I am running it on Pi 2 B+.
pi_lover
Sat Aug 19, 2017 7:38 pm
Also I amgetting this warning while installing firejail.
$ sudo apt-get install firejail
Reading package lists... Done
Building dependency tree
The following package was automatically installed and is no longer required:
  freeglut3 liblz4-1 libsoxr0 python-avahi python-gdbm python-gtkglext1
  python-lz4 python-lzo python-netifaces python-opengl
Use 'apt-get autoremove' to remove it.
Recommended packages:
  xpra xserver-xephyr
  firejail
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/214 kB of archives.
After this operation, 552 kB of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
  firejail
Install these packages without verification? [y/N]
pi_lover
Mon Aug 21, 2017 2:04 am
Any ideas ?
Return to “Raspberry Pi OS”
