fwroller
No GUI Dialog - Set Keyboard / Localisation / Raspberry Pi Configuration
Fri Aug 18, 2017 2:51 am
Clicking the Set Keyboard button in the Localisation tab in the Raspberry Pi Configuration dialog does nothing in Raspbian Stretch with Desktop (2017-08-16). This is on a Raspberry Pi 3. Previous versions of Raspbian worked without any issues. It seems to be a regression. Has anyone else experienced this issue?
As a workaround, use raspi-config from the command line in a Terminal window.
I'm in the U.S. and wanted to change to a U.S. keyboard layout, which I was able to do from the command line but would prefer to use a GUI for convenience.
Re: No GUI Dialog - Set Keyboard / Localisation / Raspberry Pi Configuration
Fri Aug 18, 2017 9:02 am
In the BLOG comments around post 90, Simon Long mentions this issue and workaround:
https://www.raspberrypi.org/blog/raspbi ... /#comments
RPi 4B 4GB (SSD Boot)..
fwroller
Fri Aug 18, 2017 12:13 pm
Thank you! Now we know two workarounds and that a bug fix is on the way. :)
klricks
Fri Aug 18, 2017 1:19 pm
The keyboard setting issue has been fixed.
sudo apt-get update
sudo apt-get upgrade
alphanumeric
Fri Aug 18, 2017 2:03 pm
I had done an apt-get update and upgrade and still had the issue. Just did them again and its working now. Which is weird because it said 0 installed, 0 upgraded etc. :?
elkberry
Fri Aug 18, 2017 7:43 pm
Same over here. Luckily, the separate menu item for keyboard and mouse settings works and brings up the keyboard selector.
Did anyone at Raspbian test this release?
From ZX81 to Raspberry Pi, but wait ... where's the 7805 gone?
Return to “Raspberry Pi OS”
