tinkererscott
Re: STRECH and MQTT
Thu Nov 09, 2017 1:27 am
Hi Asandford,
I did a fresh install myself and the mosquitto package failed, which is the reason I tracked down this thread and posted. I am using version 2 of raspberry pi but I don't think that should matter.
I am not trying to install anything other than the stock / standard packages. What I am doing is using the HomeAssistant install scripts on top of Strech (with desktop).
I'll try it again this weekend.
Scott
Re: STRECH and MQTT
Thu Nov 09, 2017 7:49 am
Don't just say "it failed", tell us how it failed.
tinkererscott
Re: STRECH and MQTT
Thu Nov 09, 2017 6:38 pm
Sorry, I'm not an expert at Linux. This is one of the reasons I came here and am using the automated scripts. A big shout out to everyone who helps make them possible!
It looks like there is something up with this: libwebsockets3. I copy pasted what it showed on the screen in my original post on the 5th. It was kinda long so I'm not sure if you want me to paste it in again here or not. I'd be happy to provide any information which can help make it easier for me and for everyone else like me attempting to perform the automated installation process which all of you awesome folks are putting together and supporting.
Best,
Scott
asandford
Re: STRECH and MQTT
Fri Nov 10, 2017 12:22 am
Hi Asandford,
Scott
HomeAssistant has sd card images available, no need to install anything, just flash and go.
Re: STRECH and MQTT
Fri Nov 10, 2017 12:29 am
THIS: viewtopic.php?f=66&t=191027&start=25#p1230675 looks like the best work-around at the moment.
tinkererscott
Re: STRECH and MQTT
Sat Nov 11, 2017 6:27 pm
I went back and started over making sure to do the dist-upgrade instead of just the regular upgrade and it worked.
I also tried the hassiban SSD image and can't get it on the network :(
https://home-assistant.io/hassio/installation/
Honestly, I like the idea of being able to use Strech instead of the less robust OS option.
Scott
asandford
Re: STRECH and MQTT
Mon Nov 13, 2017 2:01 am
Scott
It's not too difficult to get to the <this will take 25 minutes screen>
Fresh install using 2017-09-07-raspbian-stretch.img
Enable ssh by whatever means suits you.
Switch to root
sudo su -
Update and upgrade (for me this was 127 packages and 231Mb, maybe time for a new image to be released):
apt update;apt dist-upgrade  -y
<some time later>
Here's the fun part, change the hostname (to hassio, and reboot):
raspi-config
After reboot, we're back:
login as: pi
pi@hassio.local's password:
Linux hassio 4.9.59-v7+ #1047 SMP Sun Oct 29 12:19:23 GMT 2017 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Mon Nov 13 01:35:19 2017
SSH is enabled and the default password for the 'pi' user has not been changed.
This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
pi@hassio:~ $
Switch to root
sudo su -
Install mqtt if you need to:
apt install -y mosquitto mosquitto-clients
Ok, now for the Home Assistant stuff. If you don't want the sd card image, the go for the "Alternative: install on generic Linux server"
The pre-reqs are:
docker
bash
socat
jq
curl
avahi-daemon
dbus-daemon
We have most of these.
To install docker:
curl -sSL https://get.docker.com | sh
Install the others:
apt install -y socat jq
Now we're ready to install HA:
curl -sL https://raw.githubusercontent.com/home-assistant/hassio-build/master/install/hassio_install | bash -s -- -m raspberrypi3
[INFO] Install supervisor docker
[INFO] Install generic HostControl
[INFO] Install startup scripts
[INFO] Init systemd
Created symlink /etc/systemd/system/multi-user.target.wants/hassio-supervisor.service → /etc/systemd/system/hassio-supervisor.service.
[INFO] Start services
root@hassio:~#
Test by going to here
tinkererscott
Re: STRECH and MQTT
Tue Nov 14, 2017 3:45 am
Thanks for the run down. It is working.
Scott
oldfart
Re: STRECH and MQTT
Mon Nov 20, 2017 10:07 pm
Trying to install mosquitto on a fresh stretch install
installed openssl
described here
_https://raspberrypi.stackexchange.com/questions/66782/how-to-install-openssl-1-0-2-on-raspberry-pi3
now have
sudo find / -name libssl.so*
/home/pi/openssl/libssl.so.1.1
/usr/lib/arm-linux-gnueabihf/libssl.so.1.1
/usr/lib/arm-linux-gnueabihf/libssl.so.1.0.2
/usr/local/lib/libssl.so.1.1
amended the files to rebuild the deb file as described here
_
https://www.eclipse.org/forums/index.php?t=msg&th=1089302&goto=1773991&
so the lib file is libssl1.0.2 (>= 1.0.2)
run mosquitto, and error
mosquitto
mosquitto: error while loading shared libraries: libssl.so.1.0.0:
cannot open shared object file: No such file or directory
what now??
also how to install mosquitto-clients
no examples given
pulling out any hair I had left!!
tinkererscott
Re: STRECH and MQTT
Mon Nov 20, 2017 10:15 pm
Look at asandford's post right before my last one.
If you follow what he did it should work.
I think one of the keys is that he updates everything right after the install using:
The dist part is important and the reboot might be as well.
Once all that's done, go for mosquitto, should work fine.
Scott
oldfart
Re: STRECH and MQTT
Mon Nov 20, 2017 10:32 pm
found an answer that works
https://community.home-assistant.io/t/mosquitto-not-installed-by-mqtt-raspbian-stretch/27058/8
tinkererscott
Re: STRECH and MQTT
Mon Nov 20, 2017 10:43 pm
Good luck. I'm not brave enough to 'override the dependencies issues'.
oldfart
Re: STRECH and MQTT
Mon Nov 20, 2017 10:51 pm
easy
just first answer n
second y
that easy!
same for the mosquitto-clients:-
n
n
y
all working now (only took 2 days)
asandford
Re: STRECH and MQTT
Fri Nov 24, 2017 3:38 am
easy
just first answer n
second y
that easy!
n
n
y
If you need to override dependencies, you're doing it wrong (unless you know exaclty what you're doing, and if you have to ask; you don't). It might (and most probably will) cause issues in the future, and probably in very unexpected ways. Bottom line - don't mess with apt, and don't expect apt to track and update packages that you have installed/compiled independently of it.
oldfart
Re: STRECH and MQTT
Fri Nov 24, 2017 10:27 am
Well
If there was another way to install mqtt - I would have!!
Tried most of the blog tutorials - none worked
I looked around the internet for probably a week, trying to find a definitive method.
And - YES - I do know what I'm doing with Linux.
This is a problem that needs a solution prior to the change of Home Assistant to Python 3.5 (or indeed 3.6)
There were errors in the given examples, and being mostly copies of someones earlier work, were no use.
Even when the errors in the code were corrected, there were still errors.
I don't count having to put in symbolic links as a proper solution. its a bodge.
Just my view of course.
Re: STRECH and MQTT
Fri Nov 24, 2017 12:30 pm
Have you tried aptitude or synaptic? Both of those APT installers have clever magic to attempt to resolve package conflicts.
oldfart
Re: STRECH and MQTT
Fri Nov 24, 2017 2:57 pm
yes - that's what my post above refers to
Re: STRECH and MQTT
Fri Nov 24, 2017 3:16 pm
Add this
/etc/apt/sources.list.d/temp.list
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
deb http://archive.raspberrypi.org/debian/ jessie main ui
run
sudo apt update
sudo apt install mosquitto
Then remove that temp.list file.
asandford
Re: STRECH and MQTT
Sun Nov 26, 2017 1:20 am
Well
I did a fully worked out install just a few posts back.
-no symlinks
-no bodges to apt's lists
-no contrived workarounds, just
sudo apt update; apt dist-upgrade -y; reboot
sudo apt install -y mosquitto mosquitto-clients
As I've proved previously, that works!
Did you try (if you tried for a week to find a solution that I posted in this very thread, then your google is broken)?
Re: STRECH and MQTT
Sun Nov 26, 2017 8:09 am
I installed mosquitto on another Raspberry running Stretch yesterday.
The base mosquitto 1.4.10 is available with stock standard Raspbian apt-get.
It was mosquitto-clients that failed to install due to the ssl library problem.
I'll upgrade to 1.4.14 later (when we're done with our hackathon).
sudo aptitude install mosquitto-client
worked out the dependencies and got it working. I had to chose the third option aptitude gave me. I'll edit this post with details of what got installed later.
mattmiller
Re: STRECH and MQTT
Mon Dec 04, 2017 9:18 pm
JFI
I just tried installing mosquitto on the 2017-11-29 Stretch release using standard apt-get install
Both mosquitto and mosquitto-clients seemed to install without error and I could subscribe and publish to a test topic
It installed the 1.4.10 version
jsaldivias
Re: STRECH and MQTT
Tue Jan 02, 2018 1:10 pm
ShiftPlusOne wrote:
Thu Aug 17, 2017 2:13 pm
What do you see if you run 'aptitude search ~o'
ShiftPlusOne
Good Morning. Could you please help me find a solution? I installed Mosquitto in my RPi 3 and is working fine. It is working as a broker. The only thing is that I have to type:
sudo /etc/init.d/mosquitto start
every time I want to start.
I wish I could set it up so it can start by its own. I have read several dozens of posts during the last month but I fail to understand or apply what they said solved this matter for other people. And I am quite sure the solution is a simple one. Would you please help me on this?
topguy
Re: STRECH and MQTT
Tue Jan 02, 2018 1:34 pm
It is not a good idea to hijack older threads. This thread is a ******* mess by now.
What does this command give you ?
pi@raspberrypi:~ $ sudo systemctl status mosquitto
● mosquitto.service - LSB: mosquitto MQTT v3.1 message broker
   Loaded: loaded (/etc/init.d/mosquitto)
   Active: active (running) since Wed 2017-12-13 16:05:16 CET; 2 weeks 5 days ago
   CGroup: /system.slice/mosquitto.service
           └─417 /usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf
rob1048
Re: STRECH and MQTT
Sat Jan 06, 2018 1:23 am
I originally followed the steps from https://medium.com/@rossdanderson/insta ... 341fe88981 but used stretch instead of jessie. The installation failed. I got it working be removing mosquitto-stretch.list and running "sudo apt-get update" and then installing mosquitto with the following command: "sudo apt-get install mosquitto". In effect, I just reverted back to the base apt-get repositories that was installed with stretch and installed mosquitto.
asandford
Re: STRECH and MQTT
Sun Jan 07, 2018 12:53 am
Which is what I said back in November last year
Return to “Raspberry Pi OS”
