seth.raspi
apt-get 404...
Mon Aug 14, 2017 9:10 pm
I just got a pi and did my updates and upgrades. Everything was fine for a day or so, then I wanted to install/update python to use the gpio functions. I was getting 404s, so ran update again:
Ign http://mirrordirector.raspbian.org jessie InRelease
Ign http://archive.raspberrypi.org jessie InRelease
Ign http://mirrordirector.raspbian.org jessie Release.gpg
Ign http://archive.raspberrypi.org jessie Release.gpg
Err http://archive.raspberrypi.org jessie/main armhf Packages
  404  Not Found
Err http://archive.raspberrypi.org jessie/ui armhf Packages
  404  Not Found
Ign http://archive.raspberrypi.org jessie/main Translation-en_GB
Ign http://archive.raspberrypi.org jessie/ui Translation-en_GB
Err http://mirrordirector.raspbian.org jessie/main armhf Packages
  404  Not Found
Err http://mirrordirector.raspbian.org jessie/contrib armhf Packages
  404  Not Found
Err http://mirrordirector.raspbian.org jessie/non-free armhf Packages
  404  Not Found
Err http://mirrordirector.raspbian.org jessie/rpi armhf Packages
  404  Not Found
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/main/binary-armhf/Packages  404  Not Found
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/contrib/binary-armhf/Packages  404  Not Found
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/non-free/binary-armhf/Packages  404  Not Found
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/rpi/binary-armhf/Packages  404  Not Found
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/jessie/main/binary-armhf/Packages  404  Not Found
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/jessie/ui/binary-armhf/Packages  404  Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
Servers down or some other error?
Thanks! Seth
Re: apt-get 404...
Mon Aug 14, 2017 9:35 pm
Those links work fine from here. You seem to have a network problem.
Re: apt-get 404...
Tue Aug 15, 2017 1:11 am
Try sudo apt-get update then try again.
If that doesn't work you have a network problem.
seth.raspi
Re: apt-get 404...
Tue Aug 15, 2017 12:17 pm
All my fault. iptables rules had been applied to all interfaces, etc.
in3vrr
Re: apt-get 404...
Sun Sep 10, 2017 5:02 pm
I have the same problem !!!
With RPI3 Raspbian Jessie
Kernell 4.4.26-v7+ #915 SMP Thu Oct 20 17:08:44 BST 2016 armv7l GNU/Linux
After "sudo apt-get update" I have these errors:
404 Not Found [IP: 93.93.130.214 80]
404 Not Found [IP: 93.93.128.193 80]
W: Failed to fetch http://archive.raspberrypi.org/debian/d ... f/Packages 404 Not Found [IP: 93.93.130.214 80]
W: Failed to fetch http://mirrordirector.raspbian.org/rasp ... f/Packages 404 Not Found [IP: 93.93.128.193 80]
sudo ping www.google.com works !
sudo ping 93.93.130.214 works !
sudo ping archive.raspberrypi.org works !
On SD I have 8GB available
even with "sudo apt-get clean" does not change anything
Anyone can tell me how to fix this problem
Thank you
Bob
in3vrr
Re: apt-get 404...
Wed Sep 13, 2017 7:19 pm
....cut....
Thank you
Bob
Maybe can I fix this problem by modifying sources.list (sudo nano /etc/apt/sources.list)????
This is my sources.list:
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://archive.raspbian.org/raspbian/ jessie main contrib non-free rpi
What changes should I do?
I have two RPI3, the first one with ADSL and the second (on a remote site) with router + USB 4G key.
The strange thing is this:
1) The RPI3-first with ADSL 'sudo apt-get update' works
2) The RPI3-second with the 4G USB Stick has the problem described in my post above
The two sources.list files are the same
As already written, with RPI3-second there are no problems because:
Perhaps 'sudo apt-get update' does not find the right directories?
How does the system work?
There are some raspberry/Jessie 'guru' who know how to fix this problem ???
Thank you
Bob
in3vrr
Re: apt-get 404...
Sun Sep 17, 2017 8:28 am
..... CUT
....CUT
My two RPI3s are located on two different sites about 500km away
I tried to do ping on both and these are the results:
"sudo ping mirrordirector.raspbian.org" both point to the same IP: 93.93.128.193
"sudo ping archive.raspberrypi.org" IP 93.93.128.133 the RPI that with "sudo apt-get update" works; IP 93.93.130.104 the RPI that with "sudo apt-get update" does NOT work
Perhaps to divide traffic on different servers this thing is also correct....
But could this be one of the causes of "sudo apt-get update" failure?
Any suggestions for solving these problems?
Thank you
Bob
luoxq
Re: apt-get 404...
Sun Apr 28, 2019 2:43 pm
404 mean file not found, not a connection problem.
THIS IS NOT A NETWORK PROBLEM!
I am suffering this, must be some file missing or settings problems.
luoxq
Re: apt-get 404...
Sun Apr 28, 2019 2:45 pm
Perhaps a CDN problem. Can anyone post a working ip address of this mirror and archive hostname?
jimbo678
Re: apt-get 404...
Fri Jul 26, 2019 7:43 am
I edited this file, commenting the existing line and adding another. Now get a different error to the one above.
#deb http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi
deb http://mirror.ox.ac.uk/sites/archive.ra ... e/raspbian stretch main contrib non-free rpi
pi@raspberrypi:~$ sudo apt-get update
Hit http://mirror.ox.ac.uk stretch Release.gpg
Hit http://archive.raspberrypi.org wheezy Release.gpg
Hit http://mirror.ox.ac.uk stretch/main armhf Packages
Hit http://mirror.ox.ac.uk stretch/contrib armhf Packages
Hit http://archive.raspberrypi.org wheezy/main armhf Packages
Hit http://mirror.ox.ac.uk stretch/non-free armhf Packages
Hit http://mirror.ox.ac.uk stretch/rpi armhf Packages
Ign http://archive.raspberrypi.org wheezy/main Translation-en_GB
Ign http://mirror.ox.ac.uk stretch/contrib Translation-en_GB
Ign http://mirror.ox.ac.uk stretch/main Translation-en_GB
Ign http://mirror.ox.ac.uk stretch/non-free Translation-en_GB
Ign http://mirror.ox.ac.uk stretch/rpi Translation-en_GB
Ignoring Provides line with DepCompareOp for package kodi-api-guilib
Ignoring Provides line with DepCompareOp for package kodi-api-pvr
Ignoring Provides line with DepCompareOp for package libapt-inst
Ignoring Provides line with DepCompareOp for package libapt-pkg
Ignoring Provides line with DepCompareOp for package libparse-cpan-meta-perl
Ignoring Provides line with DepCompareOp for package libespeak-dev
Ignoring Provides line with DepCompareOp for package libespeak1
Ignoring Provides line with DepCompareOp for package libgpgme11-dev
Ignoring Provides line with DepCompareOp for package libjpeg62
Ignoring Provides line with DepCompareOp for package lsb
Ignoring Provides line with DepCompareOp for package lsb-core
Ignoring Provides line with DepCompareOp for package php-psr-http-message-implementation
Ignoring Provides line with DepCompareOp for package php-psr-log-implementation
Ignoring Provides line with DepCompareOp for package php-seclib
Ignoring Provides line with DepCompareOp for package php-sabre-http
Ignoring Provides line with DepCompareOp for package php-math-biginteger
Ignoring Provides line with DepCompareOp for package pkg-config
Ignoring Provides line with DepCompareOp for package pypy-cffi
Ignoring Provides line with DepCompareOp for package pypy-cffi-backend-api-max
Ignoring Provides line with DepCompareOp for package pypy-cffi-backend-api-min
Ignoring Provides line with DepCompareOp for package python-cffi-backend-api-max
Ignoring Provides line with DepCompareOp for package python-cffi-backend-api-min
Ignoring Provides line with DepCompareOp for package sagenb-export
Ignoring Provides line with DepCompareOp for package python3-cffi-backend-api-max
Ignoring Provides line with DepCompareOp for package python3-cffi-backend-api-min
You may want to run apt-get update to correct these problems
not a reference at /usr/bin/apt-show-versions line 218
E: Problem executing scripts APT::Update::Post-Invoke-Success 'test -x /usr/bin/apt-show-versions || exit 0 ; apt-show-versions -i'
E: Sub-process returned an error code
pi@raspberrypi:~$
aBUGSworstnightmare
Re: apt-get 404...
Fri Jul 26, 2019 10:51 am
Try
sudo apt update
sudo apt upgrade
Return to “Raspberry Pi OS”
