sadoldgeek
NFS mount gives segmentation error
Tue Oct 02, 2012 7:50 pm
Hello, I have tried to mount an NFS share on my Raspberry using the instructions at http://www.raspbian.org/RaspbianFAQ#How ... S_share.3F. The resulting output is: "Starting rpcbind daemon...Segmentation fault". The subsequent mount command itself doesn't produce any errors but the share will not mount. I know the share is good because I can mount it on my Mac and Ubuntu machines. Any thoughts on why the rpcbind service gives this error. (using Linux raspberrypi 3.1.9+ #272 PREEMPT Tue Aug 7 22:51:44 BST 2012 armv6l)
ski522
Re: NFS mount gives segmentation error
Tue Oct 02, 2012 11:35 pm
Seems like a lot of extra steps in those instructions. All you should need to do is:
sudo nano /etc/default/nfs-common
add the line "NEED_STATD=yes"
reboot PI or /etc/init.d/nfs-common restart
mount [IP Address]:/[directory] /[local directory]
sadoldgeek
Wed Oct 03, 2012 7:26 pm
Hi ski522, thanks for the response. I tried your suggestion. On executing line 3 I get the following output:
[email protected] ~ $ /etc/init.d/nfs-common restart
[ ok ] Stopping NFS common utilities: idmapd statd.
[....] Starting NFS common utilities: statd/etc/init.d/nfs-common: line 134: 1954 Segmentation fault /usr/sbin/rpcinfo -p > /dev/null 2>&1
[warn] Not starting: portmapper is not running ... (warning).
Return to “Raspbian”
