Reinstalling Raspbian
Posted: Thu Aug 10, 2017 1:09 pm
by glazura
I had a couple of problems with my raspbian distribution and I want to reinstall. My problem is that I am unable to format my sd card.
I've tried using the SD Association's tool, I tried formatting with diskpart, with gparted on linux, even tried writing /dev/zero to the sd using dd, and nothing works. All of these tools tell me that they've successfully formatted the card, however no changes are made. After trying all these tools, I'm still able to boot Raspbian from the sd, like nothing happened. I've read that I could try formatting using a camera, however, I have no camera to try that.
How can I format the card completely in order to install Raspbian again on it?
Thank you in advance
Re: Reinstalling Raspbian
Posted: Thu Aug 10, 2017 1:18 pm
by klricks
If you install the standalone image Rasbian Desktop (not NOOBs) using Etcher or dd then formatting is not required.
Posted: Thu Aug 10, 2017 1:20 pm
by glazura
Yes, but it appears that the sd card's partition table cannot be edited, while the partition contents appear to be editable. If i flash the raspbian image using etcher or dd, do these tools not modify the card's partition table?
Posted: Thu Aug 10, 2017 1:41 pm
by RaTTuS
sounds like your sdcard has gone read only .... get a new one
Posted: Thu Aug 10, 2017 1:57 pm
by glazura
That would explain my issues with raspbian in the first place, namely installing stuff that doesn't work or editing things that don't remain edited.
Do you think I could be eligible for warranty or a refund, considering i've altered the sd's partition table?
Posted: Thu Aug 10, 2017 7:37 pm
by klricks
Somewhere I read that some manufactures would not warranty cards used as a OS drive in a computer device.
Posted: Thu Aug 10, 2017 9:47 pm
by davesteele
If you use an SD card adapter for your micro SC card, the write-protect toggle may have flipped.
Posted: Fri Aug 11, 2017 8:59 am
by RaTTuS
ignore the write protect tab - this is not check on raspberries
you just need to get a couple of new sdcards when you get them even from reputable distributors test them with h2testw https://www.heise.de/download/product/h2testw-50539 to prove to you that they are not fake .
dunno about warranty - depends on company , where you are in the world, the manufacturer , the reveller etc.
