jmmoraux
Run one of these binaries
Tue Oct 02, 2012 3:54 pm
Maybe you already knwo this project :
http://www.distributed.net/Download_clients
Is there a way to run one of these binaries on Raspbian ?
Dont mind of performance, only for fun.
VAXXi
Re: Run one of these binaries
Tue Oct 02, 2012 4:39 pm
There's already an ARM/ELF build on that page; you've tried it and it does not work ? Although indeed it says in the footer: 17. minimum CPU of MIPS R6000
Sander
Tue Oct 02, 2012 8:21 pm
jmmoraux wrote:Maybe you already knwo this project :
Have you tried yourself?
I tried for you:
wget http://http.distributed.net/pub/dcti/current-client/dnetc-linux-arm-eabi.tar.gz
tar xvzf dnetc-linux-arm-eabi.tar.gz
cd dnetc519-linux-arm-eabi/
./dnetc
... and it works:
pi@raspberrypi ~/kul/dnetc519-linux-arm-eabi $ ./dnetc
distributed.net client for Linux Copyright 1997-2011, distributed.net
ARM assembly by Peter Teichmann
Please visit http://www.distributed.net/ for up-to-date contest information.
Start the client with '-help' for a list of valid command line options.
dnetc v2.9110-519-CTR-11111118 for Linux (Linux 3.2.27+).
Please provide the *entire* version descriptor when submitting bug reports.
The distributed.net bug report pages are at http://bugs.distributed.net/
* The client is not configured with your email address (distributed.net ID)
* Work done cannot be credited until it is set. Please run 'dnetc -config'
[Oct 02 20:16:38 UTC] Automatic processor detection found 1 processor.
[Oct 02 20:16:39 UTC] Connected to euro.v29.distributed.net:2064...
[Oct 02 20:16:39 UTC] The keyserver says: "Welcome to Downunder!"
[Oct 02 20:16:39 UTC] Retrieved project state data from server. (cached)
[Oct 02 20:16:47 UTC] OGR-NG: Retrieved packet 24 of 24 (100.00%)
[Oct 02 20:16:55 UTC] RC5-72: Retrieved stats unit 24 of 24 (100.00%)
[Oct 02 20:16:55 UTC] Connection closed.
[Oct 02 20:16:55 UTC] Automatic processor type detection did not
                      recognize the processor (tag: "armv6-compatible processor rev 7 (v6l),
                      id 0x4100b767")
[Oct 02 20:16:55 UTC] OGR-NG: Running micro-bench to select fastest core...
[Oct 02 20:17:20 UTC] OGR-NG: using core #3 (FLEGE 2.0 ARMv5).
[Oct 02 20:17:20 UTC] OGR-NG: Loaded 27/20-2-7-35-12-4
[Oct 02 20:17:20 UTC] OGR-NG: 23 packets remain in buff-in.og2
[Oct 02 20:17:20 UTC] OGR-NG: 0 packets are in buff-out.og2
[Oct 02 20:17:20 UTC] 1 cruncher has been started.
[Oct 02 20:19:04 UTC] OGR-NG:27/20-2-7-35-12-4+1-26-6-30 [426,556,330]
EDIT:
Cool: my overclocking kicks in: the Raspi is running at 900 MHz while distributed.net is running:
pi@raspberrypi ~ $ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq
900000
pi@raspberrypi ~ $
HTH
jmmoraux
Thu Oct 04, 2012 1:50 pm
Yep, i've tried first, but not the good one
Tried ELF binary and dont work
Doesn't try eabi because think it was a sof float binary.
Tried yesterday and also work fine.
Any of you wanna run this project on RPI ?
screspo
Tue Dec 08, 2015 10:34 am
I have just followed all the steps and worked correctly, but when it comes to running the client it answers as it could not find the file -bash: ./dnetc: No Such file or directory
Any idea?
I have a Raspberry with a couple of years old running xbian (latest version) , I don't know what model is it, a friend just gave it to me.
Regards,
Santi
Santi
http://alteageek.com
Return to “Raspberry Pi OS”
