[quote="dom"]Can you PM me your config.txt file and the output of
cat /proc/cpuinfo[/quote]
Hi, here commes my config.txt
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# MPEG2-Decoder
Decode_MPG2=0x71bc7328
# for more options see
http://elinux.org/RPi_config.txt
and here comes my cpuinfo:
Processor : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS : 697.95
Features : swp half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2708
Revision : 0002
Serial : 000000004c94523e
Please take in care that because the omxplayer which comes with the Raspbian 2012-0918 did not show VOB-Videos i removed the omxplayer and have installed actually from omxplayer_0.2.1~git20120927~0dfcba62_armhf.deb. Same result!
Thanks for your reply, Heiner188
