Raspbian lite remove boot services
Posted: Tue Jun 27, 2017 2:12 pm
by smanish83
I am new to Raspbian/linux. I am trying to start raspberry pi (Raspbian lite) with PIXEL UI within 10 seconds. By executing
"dmesg" I received startup log.
[ 0.247360] Key type id_resolver registered
[ 0.247365] Key type id_legacy registered
[ 0.249788] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.249891] io scheduler noop registered
[ 0.249897] io scheduler deadline registered (default)
[ 0.250165] io scheduler cfq registered
[ 0.255841] BCM2708FB: allocated DMA memory fa910000
[ 0.255866] BCM2708FB: allocated DMA channel 0 @ bb80f000
[ 0.270032] Console: switching to colour frame buffer device 100x30
[ 0.278441] bcm2835-rng 3f104000.rng: hwrng registered
[ 0.278544] vc-cma: Videocore CMA driver
[ 0.278549] vc-cma: vc_cma_base = 0x00000000
[ 0.278555] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.278559] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.278769] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 0.294236] brd: module loaded
[ 0.303120] loop: module loaded
[ 0.303132] Loading iSCSI transport class v2.0-870.
[ 0.303650] usbcore: registered new interface driver smsc95xx
[ 0.303664] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.529712] Core Release: 2.80a
[ 0.529720] Setting default values for core params
[ 0.529749] Finished setting default values for core params
[ 0.730134] Using Buffer DMA mode
[ 0.730139] Periodic Transfer Interrupt Enhancement - disabled
[ 0.730144] Multiprocessor Interrupt Enhancement - disabled
[ 0.730149] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.730162] Dedicated Tx FIFOs mode
[ 0.730500] WARN::dwc_otg_hcd_init:1034: FIQ DMA bounce buffers: virt = 0xba904000 dma = 0xfa904000 len=9024
[ 0.730524] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.730530] dwc_otg: Microframe scheduler enabled
[ 0.730577] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x8058e63c
[ 0.730587] WARN::hcd_init_fiq:460: FIQ ASM at 0x8058e9ac length 36
[ 0.730598] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb87a000
[ 0.730657] dwc_otg 3f980000.usb: DWC OTG Controller
[ 0.730691] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 0.730721] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 0.730768] Init: Port Power? op_state=1
[ 0.730773] Init: Power Port (0)
[ 0.730970] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.730981] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.730989] usb usb1: Product: DWC OTG Controller
[ 0.730997] usb usb1: Manufacturer: Linux 4.9.28-v7+ dwc_otg_hcd
[ 0.731004] usb usb1: SerialNumber: 3f980000.usb
[ 0.731838] hub 1-0:1.0: USB hub found
[ 0.731876] hub 1-0:1.0: 1 port detected
[ 0.732556] dwc_otg: FIQ enabled
[ 0.732561] dwc_otg: NAK holdoff enabled
[ 0.732565] dwc_otg: FIQ split-transaction FSM enabled
[ 0.732579] Module dwc_common_port init
[ 0.732812] usbcore: registered new interface driver usb-storage
[ 0.733032] mousedev: PS/2 mouse device common for all mice
[ 0.733995] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 0.734268] bcm2835-cpufreq: min=600000 max=1200000
[ 0.734655] sdhci: Secure Digital Host Controller Interface driver
[ 0.734659] sdhci: Copyright(c) Pierre Ossman
[ 0.734930] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[ 0.737159] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[ 0.737256] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.744542] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.744727] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.744919] usbcore: registered new interface driver usbhid
[ 0.744923] usbhid: USB HID core driver
[ 0.745730] vchiq: vchiq_init_state: slot_zero = 0xba980000, is_master = 0
[ 0.752358] Initializing XFRM netlink socket
[ 0.752380] NET: Registered protocol family 17
[ 0.752498] Key type dns_resolver registered
[ 0.753000] Registering SWP/SWPB emulation handler
[ 0.753692] registered taskstats version 1
[ 0.754030] vc-sm: Videocore shared memory driver
[ 0.754038] [vc_sm_connected_init]: start
[ 0.760670] [vc_sm_connected_init]: end - returning 0
[ 0.766667] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 0.768208] sdhost: log_buf @ ba907000 (fa907000)
[ 0.845541] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 0.847748] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 0.847756] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 0.912741] mmc0: host does not support reading read-only switch, assuming write-enable
[ 0.914703] mmc0: new high speed SDHC card at address 59b4
[ 0.915323] mmcblk0: mmc0:59b4 USD 14.7 GiB
[ 0.917071] mmcblk0: p1 p2
[ 0.925663] of_cfs_init
[ 0.925738] of_cfs_init: OK
[ 0.945713] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 0.945759] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 0.945982] Indeed it is in host mode hprt0 = 00021501
[ 0.953716] devtmpfs: mounted
[ 1.007128] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.007915] Freeing unused kernel memory: 1024K (80b00000 - 80c00000)
[ 1.008906] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.010468] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.013268] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.020640] random: fast init done
[ 1.104802] mmc1: new high speed SDIO card at address 0001
[ 1.145575] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.145708] Indeed it is in host mode hprt0 = 00001101
[ 1.281189] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 1.281563] systemd[1]: Detected architecture 'arm'.
[ 1.375905] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.375918] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.376744] hub 1-1:1.0: USB hub found
[ 1.376825] hub 1-1:1.0: 5 ports detected
[ 1.387574] NET: Registered protocol family 10
[ 1.389080] systemd[1]: Inserted module 'ipv6'
[ 1.390727] systemd[1]: Set hostname to <raspberrypi>.
[ 1.390948] systemd[1]: Initializing machine ID from random generator.
[ 1.391171] systemd[1]: Installed transient /etc/machine-id file.
[ 1.705569] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 1.772624] systemd[1]: Cannot add dependency job for unit regenerate_ssh_host_keys.service, ignoring: Unit regenerate_ssh_host_keys.service failed to load: No such file or directory.
[ 1.776141] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 1.776480] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 1.776555] systemd[1]: Starting Remote File Systems (Pre).
[ 1.835911] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 1.835925] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.838999] smsc95xx v1.0.5
[ 1.942041] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:18:c9:74
[ 1.959154] fuse init (API version 7.26)
[ 2.035602] usb 1-1.4: new low-speed USB device number 4 using dwc_otg
[ 2.182996] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c31c
[ 2.183016] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.183032] usb 1-1.4: Product: USB Keyboard
[ 2.183044] usb 1-1.4: Manufacturer: Logitech
[ 2.203925] input: Logitech USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:046D:C31C.0001/input/input0
[ 2.266712] hid-generic 0003:046D:C31C.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-3f980000.usb-1.4/input0
[ 2.294589] input: Logitech USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:046D:C31C.0002/input/input1
[ 2.299902] systemd-udevd[146]: starting version 215
[ 2.355954] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-3f980000.usb-1.4/input1
[ 2.700841] rpi-ft5406 rpi_ft5406: Probing device
[ 2.708749] input: FT5406 memory based driver as /devices/virtual/input/input2
[ 2.908847] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.037317] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 4.237436] usbcore: registered new interface driver brcmfmac
[ 4.377300] brcmfmac: Firmware version = wl0: May 27 2016 00:13:38 version 7.45.41.26 (r640327) FWID 01-df77e4a7
[ 4.706507] systemd-journald[142]: Received request to flush runtime journal from PID 1
[ 5.519493] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 5.519542] brcmfmac: power management disabled
[ 6.316543] uart-pl011 3f201000.serial: no DMA platform data
[ 6.357491] Adding 102396k swap on /var/swap. Priority:-1 extents:6 across:307196k SSFS
[ 6.684911] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 6.807752] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 6.808168] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 11.023685] Bluetooth: Core ver 2.22
[ 11.023776] NET: Registered protocol family 31
[ 11.023782] Bluetooth: HCI device and connection manager initialized
[ 11.023802] Bluetooth: HCI socket layer initialized
[ 11.023816] Bluetooth: L2CAP socket layer initialized
[ 11.023852] Bluetooth: SCO socket layer initialized
[ 11.199133] Bluetooth: HCI UART driver ver 2.3
[ 11.199146] Bluetooth: HCI UART protocol H4 registered
[ 11.199152] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 11.199310] Bluetooth: HCI UART protocol Broadcom registered
[ 13.576977] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.576987] Bluetooth: BNEP filters: protocol multicast
[ 13.577007] Bluetooth: BNEP socket layer initialized
[ 38.241078] random: crng init done
Currently i do not want Bluetooth services to start at the startup. I assume [ 13.577007] Bluetooth: BNEP socket layer initialized service is taking long time to start and raspberry pi is displaying blank screen during this transaction. I tried rcconf - Debian Runlevel configuration tool to remove Bluetooth service from startup unsuccessfully.
Any thoughts
Thank you
Re: Raspbian lite remove boot services
Posted: Tue Jun 27, 2017 3:55 pm
by topguy
Posted: Tue Jun 27, 2017 4:11 pm
by runboy93
Tweaking :)
Try some tweaks from my signature, very basic ones.
I started test noop I/O scheduler on my RPi 3, as soon as I see difference with default, I will include it on my list.
Posted: Tue Jun 27, 2017 5:18 pm
by smanish83
Thank you for reply :D . I am still getting blank screen and delayed :oops:
[ 7.195984] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 19.286286] Bluetooth: Core ver 2.22
[ 19.286374] NET: Registered protocol family 31
[ 19.286377] Bluetooth: HCI device and connection manager initialized
[ 19.286393] Bluetooth: HCI socket layer initialized
[ 19.286404] Bluetooth: L2CAP socket layer initialized
[ 19.286429] Bluetooth: SCO socket layer initialized
[ 19.351197] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 19.351204] Bluetooth: BNEP filters: protocol multicast
[ 19.351215] Bluetooth: BNEP socket layer initialized
[ 46.493248] random: crng init done
Which process is this?
