kneekoo
Debian 9 Stretch announced, Raspbian's future
Sun May 28, 2017 5:51 pm
Great news! :D
The release date of Debian 9 "Stretch" has been announced for June 17, and Release Candidate 4 is available for testing.
Debian 9 comes with kernel 4.9, which means we will get some exciting new stuff by default:
- a fully open Raspberry Pi 3D driver stack
- better HDMI hotplug detection for Pi2/3
- DPI panel support
- Raspberry Pi Zero support
It's just a short list with the things I noticed in the feature announcement on phoronix, so feel free to correct/update this list if you know more. :) If you want to try kernel 4.9, there's a thread related to kernel 4.9 testing, where you can report any issues you encounter.
The purpose of this thread is to talk about the next iteration of Raspbian. I'd like to know what is likely to be expected in Raspbian when the new version (based on Debian 9 Stretch) will be ready, and how else can we help apart from the kernel testing. :)
Cheers! :D
runboy93
Re: Debian 9 Stretch announced, Raspbian's future
Sun May 28, 2017 6:07 pm
I wonder why there has not been Raspbian May image yet (4.9.xx kernel by default)
buja
Sun May 28, 2017 6:16 pm
Good news indeed, and not the first topic to bring it.
But I must have missed something: kernel 4.9.
At least two of my Pi's are already running kernel 4.9 according to the output of uname: "Linux raspberrypi 4.9.24-v7+ #993 SMP Wed Apr 26 18:01:23 BST 2017 armv7l GNU/Linux".
Is that because of a apt-get dist-upgrade?
Sun May 28, 2017 6:24 pm
buja wrote:At least two of my Pi's are already running kernel 4.9 according to the output of uname: "Linux raspberrypi 4.9.24-v7+ #993 SMP Wed Apr 26 18:01:23 BST 2017 armv7l GNU/Linux".
Yes.
Sun May 28, 2017 8:40 pm
kneekoo wrote:Great news! :D
- DPI panel support
Cheers! :D
Did you not see this very recent post ??
viewtopic.php?f=63&t=184740&p=1168408#p1168358
Retired disgracefully.....
This at present is my daily "computer" https://www.asus.com/us/Chrome-Devices/Chromebit-CS10/
kneekoo
Sun May 28, 2017 11:48 pm
@buja: You're right. I just noticed that my RasPi Zero W is on 4.9:
Linux raspberrypi 4.9.24+ #993 Wed Apr 26 17:56:54 BST 2017 armv6l GNU/Linux
@fruitoftheloom: Thanks for pointing that out. I missed it, although I have to admit I only looked in this forum category because I assumed this is where the topic would be discussed. :)
dolphs
Fri Jun 02, 2017 5:26 am
Hi - are there already Raspbian lite images available for download which hold Debian9?
DirkS
Fri Jun 02, 2017 9:39 am
dolphs wrote:Hi - are there already Raspbian lite images available for download which hold Debian9?
No: https://www.raspberrypi.org/downloads/raspbian/
Fri Jun 02, 2017 9:53 am
Not yet as has been discussed.
Though you can update a Raspbian Jessie Lite to Raspbian Stretch Lite.....
update your /etc/apt/sources.list replacing "jessie" with "stretch", then run apt-get update && apt-get upgrade ;)
Last edited by fruitoftheloom on Fri Jun 02, 2017 10:54 am, edited 1 time in total.
Milliways
Fri Jun 02, 2017 9:58 am
Yes.
No! it comes with a normal apt upgrade
kusti8
Fri Jun 02, 2017 10:45 am
Yes.
They're the same thing. 4.9 is already shipped through the Raspberry Pi repo.
buja
Sat Jun 03, 2017 10:36 am
Contradictory information :lol:
I did apt-get upgrade on my weather station Pi (1B) and after a reboot it now runs kernel 4.9.24+
(edit: update changed to upgrade)
No, there is no officially released Raspbian Stretch yet.
Raspbian follows Debian, the normal order of things is that after Debian has released its new stable version (9 Stretch), the Raspbian developers (Plugwash & friends?) update Raspbian with the new Debian packages and then release Raspbian Stretch.
Simple as this sounds, it's probably quite a bit of work, so it may take some time.
I'm sure it will be announced on this forum and the blog when Raspbian Stretch is available, followed by complaints that the server is not available due to massive downloads. ;)
Sat Jun 03, 2017 10:39 am
buja wrote:Contradictory information :lol:
I did apt-get update on my weather station Pi (1B) and after a reboot it now runs kernel 4.9.24+.
update doesn't install anything new. You must have done an upgrade or dist-upgrade to get the new kernel.
buja
Sat Jun 03, 2017 10:43 am
Yes, you are right: apt-get upgrade (slip of the keyboard).
buja
Sat Jun 03, 2017 9:22 pm
https://www.debian.org/releases/stretch/releasenotes
Not an answer to the question.
Martin Frezman
Sat Jun 03, 2017 9:54 pm
Indeed. Pretty much universally true when people make "URL-only" posts.
If this post appears in the wrong forums category, my apologies.
Sun Jun 04, 2017 7:46 am
Martin Frezman wrote: Indeed. Pretty much universally true when people make "URL-only" posts.
Neither is back-biting.
The answer is "no".
Skippy7
Sun Jun 18, 2017 7:18 am
Had a spare SD card so I tried this for fun and wifi on the Pi Zero W stops working after a reboot.
SPOOCQ
Sun Jun 18, 2017 7:48 pm
If the W has the same Radio-Chipset as the Pi3 (which, IIRC, it has) you can try the following:
wget 'http://archive.raspberrypi.org/debian/p ... i4_all.deb'
sudo dpkg -i firmware-brcm80211_0.43+rpi4_all.deb
This will download the firmware files needed and afterwards your wifi should work again - at least it did on my Pi3 running Stretch (after a reboot)
Skippy7
Mon Jun 19, 2017 1:56 am
SPOOCQ wrote:If the W has the same Radio-Chipset as the Pi3 (which, IIRC, it has) you can try the following:
Thanks that worked looks like it installs the wrong firmware in the upgrade.
SPOOCQ
Mon Jun 19, 2017 3:14 pm
Oh - and don't forget to block updating of the firmware blobs:
apt-mark hold firmware-brcm80211
Return to “Raspbian”
