PuppetHoundZ
Google Play Music Works on Raspbian Chromium.
Fri May 12, 2017 8:55 pm
This is probably common knowledge.
Google play music works on Raspbian Chromium.
Just log into your account and stream. The website has full html5 support in Chromium. Plus you can download and upload your music (not recommends as it's slow).
Try it out in Chromium here:
https://play.google.com/music/
It uses around 400mb ram on Raspberry Pi 2B 1.1. And initially it takes around 20 seconds to boot up the site. Once it's up and running it will play music smoothly.
If you have any tips share them below.
ismael280373
Re: Google Play Music Works on Raspbian Chromium.
Mon Jun 05, 2017 5:16 pm
My Rory Gallagher's discography is not uploading from my pi... Blame on you Google Music.
GOD BLESS THE BLUES!!
PuppetHoundZ
Tue Jun 06, 2017 8:42 pm
ismael280373 wrote:My Rory Gallagher's discography is not uploading from my pi... Blame on you Google Music.
I find that uploading music even on a regular pc takes up a lot of CPU power. So I wouldn't recommend uploading music using a Pi. It would cause the Pi probably to freeze up due to the ram limitation.
I find the player and meta data editing to work really good on the Pi2B
Steven_Taylor
Fri May 01, 2020 8:01 pm
Yes this is true it really works on Rasbian i hope Apple music works with Raspian soon but meanwhile musconv helps me to integrate between both platforms when i want to.
Return to “Raspberry Pi OS”
