asandford
Firmware upgrades
Thu May 11, 2017 12:25 am
I'm running an old (4+ years) system which needs to be upgraded to jessie at some point.
I'd still like to receive firmware upgrades which should be OS independant, do I get them?
Re: Firmware upgrades
Thu May 11, 2017 12:27 am
Backup your SDCard to a bootable clone (since this could go badly wrong).
sudo rpi-update gets you to 4.9.27+ #997 with the latest firmware/bootcode and device tree stuff.
Note:Having anything remotely humorous in your signature is completely banned on this forum.
asandford
Thu May 11, 2017 12:35 am
DougieLawson wrote:Backup your SDCard to a bootable clone (since this could go badly wrong).
Do you think I don't know that already?
My sdcard is a 2GB card with the firmware on, my OS is on a 1TB HDD
Edit: I want stable, not bleeding edge
Thu May 11, 2017 12:37 am
If you don't upgrade to Jessie (and later to Stretch) then rpi-update and crossed fingers is your only option. Wheezy stopped getting firmware/kernel/bootcode fixes in Sept 2015.
asandford
Thu May 11, 2017 12:47 am
DougieLawson wrote:If you don't upgrade to Jessie (and later to Stretch) then rpi-update and crossed fingers is your only option. Wheezy stopped getting firmware/kernel/bootcode fixes in Sept 2015.
Yes, I know, but firmware and OS should be separated. There is no reason that if i don't run raspbian jessie that I don't get (OS neutral) firmware updates.
Thu May 11, 2017 12:51 am
asandford wrote: Yes, I know, but firmware and OS should be separated. There is no reason that if i don't run raspbian jessie that I don't get (OS neutral) firmware updates.
That's not possible, the two are deeply intertwined especially since the device tree stuff appeared. You can't boot a non-device tree kernel with device tree bootcode. You can't boot a device tree kernel with ancient non-device tree bootcode. That's why rpi-update delivers both pieces. I don't understand why the apt-get stuff is broken into two pieces.
asandford
Thu May 11, 2017 10:41 pm
DougieLawson wrote:[
I don't think it's impossible though. It's just a big middle finger to non-raspbian jessie users to merge the OS with the firmware. To an extent, the linux kernal should be indifferent to the distro being loaded - they should be seperate entities.
lahcejopa
Wed Oct 10, 2018 12:37 pm
I - for a change - run a Raspbian Buster on RPi2 pulling most of the packages from raspbian.raspberrypi.org/raspbian (my sources.list below) and some from the archive.raspberrypi.org/debian/ (mainly firmware-*, librasberrypi[0;-bin], raspberrypi-bootloader and raspberrypi-kernel).
The thing is that archive.raspberrypi.org/debian has no testing dist packages.
However these firmware/kernel available in the raspbian.raspberrypi.org/raspbian seem very different (as they have "nokernel" suffix). Is there a way to:
1) flawlessly move just to raspbian.raspberrypi.org/raspbian repo and
2) still have a recent firmware/kernel managed via .deb packets and not using rpi-update?
EDIT:
Forgot to past the sources.list file
deb http://raspbian.raspberrypi.org/raspbian testing main contrib non-free rpi #firmware
deb http://archive.raspberrypi.org/debian/ stretch main ui
Thanks,
Lahc
Return to “Raspbian”
