PuppetHoundZ
Raspbian Security Question w/ SSH off.
Tue Apr 25, 2017 12:09 am
So I've been reading around the forum and the internet about Linux and Safety and the internet.
My main goal is using Raspberry Pi as a portable Laptop using SmartiPi Touch and official screen. So my main use of the Raspberry Pi 2B v1.1 is web browsing, typing up documents, printing documents (using Cups connected wifi printer) and streaming music and video from YouTube and Spotify.
I mostly use chromium browser and I have UBlock Origin Installed with all the Malware blockers on that plug-in.
I have SSH Disabled and occasionally use VNC that is pre-installed on the Raspbian system for remote control with my iPhone sometimes.
I also have changed my default password to a different one.
Is it necessary to activate the firewall and fail2ban as well? Or is that merely if I use SSH or VNC?
Basically I'm using the thing like a Linux Computer Laptop.
Here is what I learned:
IF you inside your own network no worries on firewall and fail2ban.
But you do want to activate password protection of the sudo command. PS Thanks gkreidl for this cool security tip and steps.
To do this:
sudo nano /etc/sudoers.d/010_pi-nopasswd
shows (default):
pi ALL=(ALL) NOPASSWD: ALL
Modify to:
pi ALL=(ALL) PASSWD: ALL
and save it.
klricks
Re: Raspbian Security Question w/ SSH off.
Tue Apr 25, 2017 12:25 am
IMO if your RPi is behind the firewall on your router then changing the password is enough. Even that is mostly to prevent physical access.
If you open ports to the public Internet for SSH, Web server etc then is when you need fail2ban.
PuppetHoundZ
Tue Apr 25, 2017 1:21 am
klricks wrote:IMO if your RPi is behind the firewall on your router then changing the password is enough. Even that is mostly to prevent physical access.
That's great to know. Thanks. :D
What if I use public wifi (like mcdonalds) and have my raspberry Pi setup the same way as I mention above, Should I use firewall with failtoban?
Or should I just make sure I'm using ssl
gkreidl
Tue Apr 25, 2017 2:40 am
The most important thing has not been mentioned here, yet: Change your sudo settings so that sudo requires a password.
If you a are successfully attacked by an exploit (web page, flash etc), the attacker will not able to modify your root file system if sudo requires a password.
In more than 10 years of working with linux I have seen two successful attacks (not much compared to Windows), but both were restricted to user space and the crap could be easily removed.
Minimal Kiosk Browser (kweb)
PuppetHoundZ
Tue Apr 25, 2017 4:21 am
gkreidl wrote:The most important thing has not been mentioned here, yet: Change your sudo settings so that sudo requires a password.
Any good suggestions/directions on how to do that properly?
gkreidl
Tue Apr 25, 2017 5:39 am
PuppetHoundZ wrote: Any good suggestions/directions on how to do that properly?
shows (default):
Modify to:
and save it.
Tue Apr 25, 2017 12:57 pm
shows (default):
Modify to:
and save it.
Hi gkreidl, would you might taking a look at this draft document for Pi security, in to which I have just added your useful information.
https://github.com/raspberrypi/document ... ecurity.md
“My wife said to me `...you’re not even listening`.
I thought, that’s an odd way to start a conversation.."
gkreidl
Tue Apr 25, 2017 2:10 pm
Looks fine. But perhaps you should add, in which case these options make sense. You don't need a firewall, for example, if you're behind a router, and fail2ban is only useful if you run any kind of server (including ssh, if it is accessible outside of the local network).
Tue Apr 25, 2017 2:13 pm
Will do, thanks.
PuppetHoundZ
Tue Apr 25, 2017 3:17 pm
shows (default):
Modify to:
and save it.
I followed your directions
But instead did sudo pcmanfm went to the file opened it and modified it as you directed.
Then....
Wow that's awesome! Every time I use sudo I have to use my password just like ubuntu.
Pretty cool and thanks.
PuppetHoundZ
Sun May 14, 2017 6:20 pm
Hi all as a update on how things are going with this cool password setup for sudo.
The only way for raspi config GUI to work is to go into command line and type:
sudo rc_gui
If you open raspi config gui any other way it will open but the settings are not editable because it's not opened as sudo.
It would be nice to have a prompt for a password when clicking on the rc_gui link in the start menu.
Also it would nice if raspi-config could be upgraded with a security tab that allow users to add this nice sudo password prompt for those learning Linux this is a great stepping stone to have user learn as part of programming.
Return to “Raspbian”
