mvdm
Run Command or script on Screen Blank
Sat Apr 08, 2017 10:04 am
I have been scouring the web to try and find this but I keep getting topics explaining how to stop the screen from blanking. I do want my screen to blank after 5 minutes of use and turn of my monitor. I also want to run a script so I can turn off my monitor (which doesn't seem to want to by it self when my pi blanks the screen) and then turn it on again after the blank.
Is there a place where I can specify this in a config file or do i need to disable screen blanking and write a script that listens for mouse or keyboard input over a period of time and do this that way?
I'm running on a RPI3, Jessie with Pixel, and using a Pi-Top.
Thanks in advance
KnarfB
Re: Run Command or script on Screen Blank
Sun Apr 09, 2017 12:58 pm
What did you try so far? Does xset help: http://www.shallowsky.com/linux/x-screen-blanking.html ? Frank
mvdm
Sun Jul 02, 2017 6:54 pm
I made the following python script that autostarts on my PiTop:
import os, subprocess, time
cmdMonitor = "xset q | grep -oP "'"Monitor is \K.*"'""
cmdSetBright = "brightness %d | grep -oP "'"Current brightness = \K.*"'""
cmdOffBright = "brightness off | grep -oP "'"Current brightness = \K.*"'""
#initialization
Monitor_old = "On"
global Brightness_Old
while 1:
    time.sleep(1)
    Monitor = subprocess.check_output(cmdMonitor, shell=True)
    Monitor = Monitor.translate(None, chr(10)+chr(5))
    if Monitor != Monitor_old:
        if 'Off' in Monitor:
            Brightness_Old = int(subprocess.check_output(cmdOffBright, shell=True))
        if 'On' in Monitor:
            subprocess.check_output(cmdSetBright % Brightness_Old, shell=True)
        Monitor_old = Monitor
I'ts not pretty, but it works. My solution was to continuously poll the status of the monitor to determine if the screensaver was on. I was hoping for something more interrupt or event driven, but beggars can be choosers.
Return to “Raspbian”
