nIerSify
Re: XBMC for Raspbian wheezy including airplay,nfs,dvdcss...
Fri Oct 05, 2012 6:26 am
Important notice: There is a problem with taglib, so that xbmc won´t start. Message that shows up:
/usr/lib/xbmc/xbmc.bin: error while loading shared libraries: libtag.so.1: cannot open shared object file: No such file or directory
Also airplay is not working from the start. To fix these issues follow these steps:
Download taglib: http://sourceforge.net/projects/selfpro ... b/download and libshairport : http://sourceforge.net/projects/selfpro ... b/download
Then:
sudo dpkg -i taglib_20121005-1_armhf.deb
sudo dpkg -i libshairport_1-1202030-1_armhf.deb
Taglib wont create the symbolic links, so that xbmc wont find the lib although it is installed. So we have to do it manually:
cd /usr/lib/
sudo ln -s libtag.so.1.12.0 libtag.so.1
sudo ln -s libtag.so.1 libtag.so
After you installed the required libraries you can install xbmc. It should then start properly
Best regards
nIerSify
http://selfprogramming.bplaced.net
r0nnie
Fri Oct 05, 2012 12:54 pm
i always have a hard time getting your debs working :(
i installed every thing like you have said but still cant get it running
[email protected] ~ $ cd /usr/lib/
[email protected] /usr/lib $ sudo ln -s libtag.so.1.12.0 libtag.so.1
[email protected] /usr/lib $ sudo ln -s libtag.so.1 libtag.so
[email protected] /usr/lib $ sudo /usr/lib/xbmc/xbmc.bin
all i want to do is stretch 4:3 vids to 16:9 lol
r0nnie
Fri Oct 05, 2012 1:45 pm
r0nnie wrote:i always have a hard time getting your debs working :(
i removed libtag.so.1 from /usr/lib
then done this cmd instead
cd /usr/lib
sudo ln -s /usr/local/lib/libtag.so.1.12.0 libtag.so.1
and seems to be working with stretch but when starting/stopping vids i see the terminal screen is this normal?
thanks
nIerSify
Fri Oct 05, 2012 1:56 pm
cd /usr/lib
thanks
I had a typo in the path for setting the symbolic links. The updated fix is posted on the blog: http://selfprogramming.bplaced.net/inde ... /comments/.
Sorry for that :? ...
I did´t get it why sometimes shows the terminal screen when playing or stopping videos. I will investigate that....
Best regards
nIerSify
r0nnie
Fri Oct 05, 2012 2:03 pm
nIerSify wrote:
I had a typo in the path for setting the symbolic links. The right path is /usr/local/lib. Sorry for that :? ...
Best regards
nIerSify
well seeing the terminal screen isnt much of a problem, im just happy to have stretch working now!! :mrgreen:
thanks for this !
AndroidPI
Sat Oct 06, 2012 3:01 pm
Working nice.
jsandrade
Wed Oct 10, 2012 1:47 am
Hello nIerSify,
You made a great job, thank you!
I have problems with AirPlay, I enabled it on XBMC settings however my idevices dont recognize any airplay device. Last weekend I tested this feature pretty good on raspbmc. I tried to create, links for libshairport as you described to libtag like:
cd /usr/local/lib
sudo ln -s libshairport.so.0.0.0 libshairport.so.1
sudo ln -sf libshairport.so.1 libshairport.so
cd /usr/lib/
ln -s /usr/local/lib/libshairport.so.1 ./libshairport.so.1
But it didnt worked, I am using arm128 on start.elf
Any help is appreciated.
nIerSify
Wed Oct 10, 2012 11:57 am
jsandrade wrote:Hello nIerSify,
cd /usr/local/lib
cd /usr/lib/
Hi, :)
can you please post or upload your xbmc.log? Its located under /root/.xbmc/temp/xbmc.log.
Normally you don´t need to create symlinks for libshairport. The installation should be enough for xbmc to recognize this library. I think your log file will solve the issue.... ;)
Best regards
nIerSify
jsandrade
Wed Oct 10, 2012 3:24 pm
Hi, :)
Best regards
nIerSify
Thanks for your quick reply, nIerSify.
My log file:
# cat /root/.xbmc/temp/xbmc.log
22:48:20 T:1074348576  NOTICE: -----------------------------------------------------------------------
22:48:20 T:1074348576  NOTICE: Starting XBMC (12.0-ALPHA7 Git:20121003-5e4b59d), Platform: Linux (wheezy/sid, 3.2.27+ armv6l). Built on Oct  4 2012
22:48:20 T:1074348576  NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
22:48:20 T:1074348576  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
22:48:20 T:1074348576  NOTICE: special://masterprofile/ is mapped to: /root/.xbmc/userdata
22:48:20 T:1074348576  NOTICE: special://home/ is mapped to: /root/.xbmc
22:48:20 T:1074348576  NOTICE: special://temp/ is mapped to: /root/.xbmc/temp
22:48:20 T:1074348576  NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
22:48:20 T:1074348576  NOTICE: Local hostname: raspberrypi
22:48:20 T:1074348576  NOTICE: Log File is located: /root/.xbmc/temp/xbmc.log
22:48:21 T:1074348576  NOTICE: load settings...
22:48:21 T:1074348576  NOTICE: special://profile/ is mapped to: special://masterprofile/
22:48:21 T:1074348576  NOTICE: loading special://masterprofile/guisettings.xml
22:48:21 T:1074348576  NOTICE: Getting hardware information now...
22:48:21 T:1074348576  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
22:48:21 T:1074348576  NOTICE: Loaded playercorefactory configuration
22:48:21 T:1074348576  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
22:48:21 T:1074348576  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
22:48:21 T:1074348576  NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
22:48:21 T:1074348576  NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
                                            <advancedsettings>
                                              <video>
                                                <defaultplayer>omxplayer</defaultplayer>
                                                <defaultdvdplayer>omxplayer</defaultdvdplayer>
                                              </video>
                                              <audio>
                                                <streamsilence>false</streamsilence>
                                              </audio>
                                            </advancedsettings>
22:48:21 T:1074348576  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
22:48:21 T:1074348576  NOTICE: Default DVD Player: omxplayer
22:48:21 T:1074348576  NOTICE: Default Video Player: omxplayer
22:48:21 T:1074348576  NOTICE: Default Audio Player: omxplayer
22:48:21 T:1074348576  NOTICE: Disabled debug logging due to GUI setting. Level -1.
I also noticed that I cant control xbmc menu using app on my idevices with zeroconf enabled and also http.
I dont see <enableairtunesdebuglog>1</enableairtunesdebuglog> on it, so I decided to retry using a fresh installation of raspbian. as I have used xbmc-20121004_1rpb-1_armhf.deb on my dev environment, and it had a compiled XBMC manually last sunday.
I will bring news by friday or saturday because tonight I have soccer/football game at stadium.
Greetings from Brazil (yep, I posted on your blog) ;)
Regards,
Jorge
nIerSify
Wed Oct 10, 2012 4:05 pm
jsandrade wrote:
Hi, :)
Best regards
nIerSify
My log file:
                                            <advancedsettings>
                                              <video>
                                              </video>
                                              <audio>
                                              </audio>
                                            </advancedsettings>
Regards,
Jorge
i don´t see an error in the log file, so that airplay wouldn´t work. Please enable the debug function of xbmc under settings-system....and upload the log after trying to play something via airplay :)
Best regards
nIerSify
Aydan
Wed Oct 10, 2012 9:12 pm
nIerSify wrote: I will add the dependencies in the .deb package next time...
Thanks for that hint :)
Best regards
nIerSify
Hi nIerSify,
did you get the dependency issue sorted?
Regards
Aydan
Aydan
Wed Oct 10, 2012 10:01 pm
I just tried installing xbmc_20121004-1_armhf.deb with the following result:
[email protected]:~/build# dpkg -i xbmc_20121004-1_armhf.deb
Vormals nicht ausgewähltes Paket xbmc wird gewählt.
(Lese Datenbank ... 65717 Dateien und Verzeichnisse sind derzeit installiert.)
Entpacken von xbmc (aus xbmc_20121004-1_armhf.deb) ...
dpkg: Abhängigkeitsprobleme verhindern Konfiguration von xbmc:
 xbmc hängt ab von libplist1; aber:
  Paket libplist1 ist nicht installiert.
 xbmc hängt ab von libmicrohttpd10; aber:
  Paket libmicrohttpd10 ist nicht installiert.
 xbmc hängt ab von libtinyxml2.6.2; aber:
  Paket libtinyxml2.6.2 ist nicht installiert.
 xbmc hängt ab von libyajl2; aber:
  Paket libyajl2 ist nicht installiert.
 xbmc hängt ab von libssh-4; aber:
  Paket libssh-4 ist nicht installiert.
 xbmc hängt ab von libmysqlclient18; aber:
  Paket libmysqlclient18 ist nicht installiert.
 xbmc hängt ab von libfribidi0; aber:
  Paket libfribidi0 ist nicht installiert.
 xbmc hängt ab von liblockdev1; aber:
  Paket liblockdev1 ist nicht installiert.
dpkg: Fehler beim Bearbeiten von xbmc (--install):
 Abhängigkeitsprobleme - verbleibt unkonfiguriert
Trigger für hicolor-icon-theme werden verarbeitet ...
Trigger für desktop-file-utils werden verarbeitet ...
Fehler traten auf beim Bearbeiten von:
 xbmc
and
[email protected]:~/build# apt-get -f install
gives me this:
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut
Statusinformationen werden eingelesen... Fertig
Abhängigkeiten werden korrigiert... Fertig
Die folgenden Pakete werden ENTFERNT:
  xbmc
0 aktualisiert, 0 neu installiert, 1 zu entfernen und 0 nicht aktualisiert.
1 nicht vollständig installiert oder entfernt.
Nach dieser Operation werden 73,0 MB Plattenplatz freigegeben.
Möchten Sie fortfahren [J/n]? n
After satisfying dependencies with aptitude there's one still missing:
xbmc-bin
Where do I get that?
Regards
Aydan
Aydan
Wed Oct 10, 2012 10:17 pm
It seems that all dependencies are met somehow, but i still can't start it.
form the shell I get:
/usr/lib/python2.7/dist-packages/gtk-2.0/gtk/__init__.py:57: GtkWarning: could not open display
  warnings.warn(str(e), _gtk.Warning)
Error: unable to open display
FEH.py: cannot connect to X server
and from within X it complains about a missing GL driver.
nIerSify
Thu Oct 11, 2012 11:37 am
Aydan wrote:It seems that all dependencies are met somehow, but i still can't start it.
the required libraries are now dependencies for xbmc installation. Take a look at this page: http://selfprogramming.bplaced.net/inde ... -for-xbmc/ to install the required libraries. You will need to install these libraries before you install xbmc.
After that you will need to correct the symlinks for the libraries. See here: http://selfprogramming.bplaced.net/inde ... /comments/
After that xbmc should start. Ensure to connect your display via hdmi. I didn´t test it with tv-out.
Best regards
nIerSify
Aydan
Thu Oct 11, 2012 12:30 pm
nIerSify wrote:You will need to install these libraries before you install xbmc.
Normally you install a deb and then afterwards do apt-get -f install to fix missing dependencies.
This should also configure the package which was missing the dependencies.
Another drawback of manually installing dependencies is that those packages are marked as installed manually and don't get removed if you remove xbmc.
nIerSify wrote:After that you will need to correct the symlinks for the libraries. See here: http://selfprogramming.bplaced.net/inde ... /comments/
This should be done by a configure script which is automatically run at the end of the installation.
Ideally you'd only have to do two things:
dpkg -i xbmc*.deb
apt-get -f install
I'm just pointing this out as hints for future improvements and ease of installation.
Regards
Aydan
nIerSify
Thu Oct 11, 2012 3:44 pm
I will try to make the installation process easier next time. I see that the installation process as it is now is not very handy ;)
I will compile a newer version in the next two weeks or maybe earlier if i got the time and try to improve the installation process as you mentioned.
By the way does it work for you?
Best regards
nIerSify
Aydan
Thu Oct 11, 2012 3:48 pm
nIerSify wrote:By the way does it work for you?
Not yet ;)
I didn't put a whole lot of time in it anyway.
I was checking if the dependency thing had been solved, mostly.
I'll check if I have all dependencies installed and run a reconfigure for XBMC.
Regards
Aydan
jsandrade
Fri Oct 12, 2012 12:46 pm
Best regards
nIerSify
Hi nIerSify,
My iphone and ipad only discovered airplay feature when i installed avahi-daemon following instructions on http://wiki.xbmc.org/index.php?title=AirPlay. So, I recommed you to add this on your tutorial.
I am worried about CPU usage too high with this combination raspbian + XBMC, It gets around 90% all the time by xbmc.bin, also on menu mode. Is there any workaround to decrease it?
thanks again,
Jorge
kadams2929
Sat Oct 13, 2012 12:44 am
nlerSify,
Could you please post your latest working image that includes your 20121004 .deb file on http://selfprogramming.bplaced.net ?
Keep up the good work and good luck with your thesis!
Metatronin
Sat Oct 13, 2012 4:33 am
Latest build works great on both hdmi and composite out(with headphone jack for sound).
nIerSify
Sat Oct 13, 2012 5:41 am
jsandrade wrote: Hi nIerSify,
thanks again,
Jorge
normally you don´t need to install the avahi-daemon. Airplay comes with xbmc. The airplay function is the only feature i cannot really test. I have no ipad or another apple device because i am using android most of the time. There is only one player supporting airplay for android and that thing has worked with the latest xbmc build. Maybe you want to download the complete raspbian + xbmc image on my site tomorrow to test it with your devices. :)
I will upload a new image containing the latest raspbian image and the latest xbmc-build on my site on sunday (14.10.2012) Basically tomorrow ;) ...
P.S
I included a facebook-like-button for anyone who wants to share it.... :)
Best regards
nIerSify
elatllat
Sun Oct 14, 2012 5:56 pm
nIerSify wrote:...I will upload a new image containing the latest raspbian image and the latest xbmc-build ...
If anyone decides to maintain an apt source for xbmc please list it here:
http://elinux.org/RPi_applications
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
nIerSify
Mon Oct 15, 2012 11:05 am
Hi :)
i will upload a new image of raspbian (version: 2012-09-18) and the latest xbmc build (xbmc_20121004-1_armhf.deb). It contains the latest raspbian image from here. The required libraries have been installed in order to get xbmc working. I also added a script to /etc/init.d/ for starting xbmc. Please note that this script starts xbmc as root. You may want to change the script according to your favor.
To start xbmc on boot:
cd /etc/init.d/
sudo update-rc.d xbmc defaults
To disable xbmc on boot:
cd /etc/init.d/
sudo update-rc.d xbmc remove
To resize the sd-card or to overclock the raspberry pi, you can use raspi-config.I also disabled the option to directly boot to the desktop. You can enable this feature in the raspi-config menu aswell.
Username: pi
Password: raspberry
This image supports the following features:
  • Compiled XBMC from mainline tree
    Airplay
    CEC
    dvdcss
    libblueray
    optical-drive
    omxplayer as default
I will post a download link, when the upload has finished ;)
@Jorge
You were right on installing the avhi-daemon in order to get airplay working :) . My android application was using upnp for streaming video and audio. After i installed the daemon and disabling upnp, airplay was working as expected. Thank you very much :D
I have posted the site you mentioned on my blog....
Best regards
nIerSify
jsandrade
Mon Oct 15, 2012 6:17 pm
nIerSify wrote:
@Jorge
Best regards
nIerSify
nIerSify,
All credit is yours, continue with your nice package and good tutorials.
I am still looking for a workaround about high CPU usage.
Cheers,
Jorge
nIerSify
Mon Oct 15, 2012 7:05 pm
The file is uploaded and can be download by following this link:http://selfprogramming.bplaced.net/?page=downloads. The file´s name is: raspbian_wheezy_20121015+xbmc.exe. Its a self-extracting archive so that you don´t need to install additional software anymore ;)
Best regards
nIerSify
Return to “Raspbian”
