teeth_03
Re: XBMC for Raspbian wheezy including airplay,nfs,dvdcss...
Tue Oct 16, 2012 11:48 pm
I just did a manual install of Raspbian/Update/Upgrade/Libraries//Libraries Fix/10-4 image of XBMC on a new 8GB Samsung Class 10 SD Card, and im getting issues playing videos. I had 1 video play fine, but most of them will play sound, but not display video. What i get is a gray screen with a pink square near the center then it starts to turn weirder from there. The whole interface seems to run slower than before.
The system seemed to work fine when using LXDE to get the system setup, so I don't think its the SD card.
Could the newest firmware be causing issues still?
nIerSify
Wed Oct 17, 2012 8:39 am
Hard to say what your problem is. I don´t think thats a sd-card issue too, maybe you are right that it is related with the latest firmware. Did you take a look into the log file already?
It could also be a problem with your tv options. For a few weeks i installed the version on the clean raspbian installation but the resolution was totally wrong. It was 720 * 576 pixels...
Best regards
nIerSify
http://selfprogramming.bplaced.net
nIerSify
Wed Oct 24, 2012 6:32 am
i´ve posted some basic information how to enable automount in raspbian.If you are interested take a look at here: http://selfprogramming.bplaced.net/inde ... /comments/
Best regards
nIerSify
mybox
Wed Oct 24, 2012 7:35 am
I followed the steps mentioned in the link below to install debs for taglib_20121005-1_armhf.deb & libshairport_1-1202030-1_armhf.deb
There is no /usr/local/lib/libtag.so.1.12.0 file in this folder for me to do a symlink. There are 2 files python2.7 python3.2 in it.
Pls advise
nIerSify
Sat Oct 27, 2012 10:14 am
mybox wrote:Hi,
Pls advise
i´ve checked the installation process. After you installed the taglib library with "taglib_20121005-1_armhf.deb" there are definitely the files to symlink. I had another user mentioned the same problem and it turns out that he did a mistake when downloading the packages. He used wget and downloaded the xbmc.deb twice and saved one of that copies with the name:"taglib_20121005-1_armhf.deb". So he thought installing taglib but it was xbmc instead. Please check your downloads :)
Otherwise i recommand to download the complete raspbian image + xbmc from here:
https://sourceforge.net/projects/selfpr ... e/download
Greetings
Aydan
Mon Oct 29, 2012 8:19 pm
Hi nIerSify,
I used your image and got XBMC working, sortof.
I can stream from my UPNP server, but it crashes often.
Here's a serial log:
Uncompressing Linux... done, booting the kernel.
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.2.27+ ([email protected]) (gcc version 4.7.2 20120731 (prerelease) (crosstool-NG linaro-1.13.1+bzr2458 - Linaro GCC 2012.08) ) #250 PREEMPT Thu Oct 18 19:03:02 BST 2012
[    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[    0.000000] Machine: BCM2708
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 48768
[    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=1024 bcm2708.boardrev=0x2 bcm2708.serial=0xefa2094 smsc95xx.macaddr=B8:27:EB:FA:20:94 sdhci-bcm2708.emmc_clock_freq=100000000 vc_mem.mem_base=0xc000000 vc_mem.mem_size=0x10000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 192MB = 192MB total
[    0.000000] Memory: 188976k/188976k available, 7632k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xcc800000 - 0xe8000000   ( 440 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xcc000000   ( 192 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .text : 0xc0008000 - 0xc04c0e78   (4836 kB)
[    0.000000]       .init : 0xc04c1000 - 0xc04e0b10   ( 127 kB)
[    0.000000]       .data : 0xc04e2000 - 0xc050e1c0   ( 177 kB)
[    0.000000]        .bss : 0xc050e1e4 - 0xc05b5128   ( 668 kB)
[    0.000000] NR_IRQS:330
[    0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[    0.000000] timer_set_mode: unhandled mode:1
[    0.000000] timer_set_mode: unhandled mode:3
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.000947] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[    0.060148] pid_max: default: 32768 minimum: 301
[    0.060628] Mount-cache hash table entries: 512
[    0.061117] Initializing cgroup subsys cpuacct
[    0.061209] Initializing cgroup subsys devices
[    0.061246] Initializing cgroup subsys freezer
[    0.061277] Initializing cgroup subsys blkio
[    0.061420] CPU: Testing write buffer coherency: ok
[    0.061766] hw perfevents: enabled with v6 PMU driver, 3 counters available
[    0.062982] devtmpfs: initialized
[    0.073378] NET: Registered protocol family 16
[    0.074067] bcm2708.uart_clock = 0
[    0.075695] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.075751] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.075789] mailbox: Broadcom VideoCore Mailbox driver
[    0.075895] bcm2708_vcio: mailbox at f200b880
[    0.076002] bcm_power: Broadcom power driver
[    0.076041] bcm_power_open() -> 0
[    0.076067] bcm_power_request(0, 8)
[    0.576747] bcm_mailbox_read -> 00000080, 0
[    0.576787] bcm_power_request -> 0
[    0.576813] Serial: AMBA PL011 UART driver
[    0.576971] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[    0.886732] console [ttyAMA0] enabled
[    0.912227] bio: create slab <bio-0> at 0
[    0.917459] SCSI subsystem initialized
[    0.921457] usbcore: registered new interface driver usbfs
[    0.927186] usbcore: registered new interface driver hub
[    0.932773] usbcore: registered new device driver usb
[    0.938825] Switching to clocksource stc
[    0.943072] FS-Cache: Loaded
[    0.946253] CacheFiles: Loaded
[    0.962982] NET: Registered protocol family 2
[    0.967815] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.975889] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.983384] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[    0.990026] TCP: Hash tables configured (established 8192 bind 8192)
[    0.996445] TCP reno registered
[    0.999614] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    1.005529] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    1.012317] NET: Registered protocol family 1
[    1.017507] RPC: Registered named UNIX socket transport module.
[    1.023629] RPC: Registered udp transport module.
[    1.028352] RPC: Registered tcp transport module.
[    1.033104] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.039852] bcm2708_dma: DMA manager at cc808000
[    1.044652] bcm2708_gpio: bcm2708_gpio_probe c04e9c18
[    1.050112] vc-mem: phys_addr:0x00000000 mem_base=0x0c000000 mem_size:0x10000000(256 MiB)
[    1.059411] audit: initializing netlink socket (disabled)
[    1.064963] type=2000 audit(0.750:1): initialized
[    1.181123] VFS: Disk quotas dquot_6.5.2
[    1.185370] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.192919] FS-Cache: Netfs 'nfs' registered for caching
[    1.199188] msgmni has been set to 369
[    1.205054] io scheduler noop registered
[    1.209022] io scheduler deadline registered (default)
[    1.214464] io scheduler cfq registered
[    1.251003] Console: switching to colour frame buffer device 160x64
[    1.275406] kgdb: Registered I/O driver kgdboc.
[    1.289864] brd: module loaded
[    1.298182] loop: module loaded
[    1.302237] vcos: [1]: vchiq_init_state: slot_zero = 0xffd80000, is_master = 0
[    1.309959] vcos: [1]: vchiq_init_state: called
[    1.315460] vcos: [1]: vchiq: initialised - version 2 (min 2), device 252.0
[    1.323383] usbcore: registered new interface driver smsc95xx
[    1.329352] cdc_ncm: 04-Aug-2011
[    1.332772] usbcore: registered new interface driver cdc_ncm
[    1.338644] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.549702] Core Release: 2.80a
[    1.553068] Setting default values for core params
[    1.558018] Finished setting default values for core params
[    1.768880] Using Buffer DMA mode
[    1.772303] Periodic Transfer Interrupt Enhancement - disabled
[    1.778304] Multiprocessor Interrupt Enhancement - disabled
[    1.784051] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.788527] Dedicated Tx FIFOs mode
[    1.792363] dwc_otg bcm2708_usb: DWC OTG Controller
[    1.797495] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[    1.804990] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[    1.810683] Init: Port Power? op_state=1
[    1.814832] Init: Power Port (0)
[    1.818279] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.825295] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.832698] usb usb1: Product: DWC OTG Controller
[    1.837549] usb usb1: Manufacturer: Linux 3.2.27+ dwc_otg_hcd
[    1.843470] usb usb1: SerialNumber: bcm2708_usb
[    1.848994] hub 1-0:1.0: USB hub found
[    1.859213] hub 1-0:1.0: 1 port detected
[    1.870631] usbcore: registered new interface driver uas
[    1.882450] Initializing USB Mass Storage driver...
[    1.894020] usbcore: registered new interface driver usb-storage
[    1.906465] USB Mass Storage support registered.
[    1.917749] usbcore: registered new interface driver libusual
[    1.930350] mousedev: PS/2 mouse device common for all mice
[    1.943220] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[    1.949059] bcm2835-cpufreq: switching to governor powersave
[    1.961097] bcm2835-cpufreq: switching to governor powersave
[    1.973300] cpuidle: using governor ladder
[    1.989814] cpuidle: using governor menu
[    2.000049] sdhci: Secure Digital Host Controller Interface driver
[    2.012482] sdhci: Copyright(c) Pierre Ossman
[    2.023330] sdhci: Enable low-latency mode
[    2.033737] bcm_power_open() -> 1
[    2.045070] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[    2.059391] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[    2.071674] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.083910] Indeed it is in host mode hprt0 = 00021501
[    2.096063] usbcore: registered new interface driver usbhid
[    2.113919] usbhid: USB HID core driver
[    2.143872] TCP cubic registered
[    2.172863] Initializing XFRM netlink socket
[    2.186777] NET: Registered protocol family 17
[    2.203740] mmc0: new high speed SD card at address b368
[    2.223007] Registering the dns_resolver key type
[    2.243652] mmcblk0: mmc0:b368 SDC   3.86 GiB
[    2.254488] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    2.274904]  mmcblk0: p1 p2
[    2.284256] registered taskstats version 1
[    2.295822] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[    2.392929] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.407006] Indeed it is in host mode hprt0 = 00001101
[    2.633161] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[    2.646333] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.661046] hub 1-1:1.0: USB hub found
[    2.671705] hub 1-1:1.0: 3 ports detected
[    2.953102] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    3.063480] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    3.077086] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.093912] smsc95xx v1.0.4
[    3.168434] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:fa:20:94
[    3.197168] EXT4-fs (mmcblk0p2): recovery complete
[    3.229774] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    3.244630] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    3.258658] devtmpfs: mounted
[    3.268657] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[    3.282986] Freeing init memory: 124K
[    3.393862] usb 1-1.2: New USB device found, idVendor=0409, idProduct=005a
[    3.407626] usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.423135] hub 1-1.2:1.0: USB hub found
[    3.434348] hub 1-1.2:1.0: 4 ports detected
[    3.523067] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
[    3.634946] usb 1-1.3: New USB device found, idVendor=05e3, idProduct=0608
[    3.649423] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.663659] usb 1-1.3: Product: USB2.0 Hub
[    3.678649] hub 1-1.3:1.0: USB hub found
[    3.689858] hub 1-1.3:1.0: 4 ports detected
[    3.783209] usb 1-1.2.4: new low-speed USB device number 6 using dwc_otg
[    3.944177] usb 1-1.2.4: New USB device found, idVendor=0557, idProduct=2212
[    3.972228] usb 1-1.2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.989372] usb 1-1.2.4: Product: CS1642 V1.0.07ر
[    4.001108] usb 1-1.2.4: Manufacturer: ATEN
[    4.052636] input: ATEN CS1642 V1.0.07ر as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4:1.0/input/input0
[    4.077722] generic-usb 0003:0557:2212.0001: input: USB HID v1.00 Keyboard [ATEN CS1642 V1.0.07ر] on usb-bcm2708_usb-1.2.4/input0
[    4.121530] input: ATEN CS1642 V1.0.07ر as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4:1.1/input/input1
[    4.151203] generic-usb 0003:0557:2212.0002: input: USB HID v1.00 Mouse [ATEN CS1642 V1.0.07ر] on usb-bcm2708_usb-1.2.4/input1
[    4.253362] usb 1-1.3.4: new high-speed USB device number 7 using dwc_otg
[    4.365011] usb 1-1.3.4: New USB device found, idVendor=05e3, idProduct=0608
[    4.386506] usb 1-1.3.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    4.401772] usb 1-1.3.4: Product: USB2.0 Hub
[    4.420146] hub 1-1.3.4:1.0: USB hub found
[    4.433903] hub 1-1.3.4:1.0: 4 ports detected
[    5.053667] udevd[137]: starting version 175
[   10.500273] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   11.028369] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   11.763838] bcm2835 ALSA card created!
[   11.788092] bcm2835 ALSA chip created!
[   11.804605] bcm2835 ALSA chip created!
[   11.818300] bcm2835 ALSA chip created!
[   11.832119] bcm2835 ALSA chip created!
[   11.845750] bcm2835 ALSA chip created!
[   11.859388] bcm2835 ALSA chip created!
[   11.872765] bcm2835 ALSA chip created!
øø
Debian GNU/Linux wheezy/sid raspberrypi ttyAMA0
raspberrypi login: root
Password:
Last login: Mon Oct 29 20:44:02 CET 2012 on tty1
Linux raspberrypi 3.2.27+ #250 PREEMPT Thu Oct 18 19:03:02 BST 2012 armv6l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
[email protected]:~# htop
  CPU[||*                       6.6%]     Tasks: 26, 68 thr; 1 running
  Mem[|||##*****            17/184MB]     Load average: 0.33 0.19 0.07
  Swp[                        0/99MB]     Uptime: 00:01:39
  PID USER      PRI  NI  VIRT   RES   SHR S CPU% MEM%   TIME+  Command
 1984 root       20   0 27524  3688  2620 S  0.0  2.0  0:00.00 /usr/sbin/console
 1985 root       20   0 27524  3688  2620 S  0.0  2.0  0:00.00 /usr/sbin/console
 1986 root       20   0 27524  3688  2620 S  0.0  2.0  0:00.00 /usr/sbin/console
 1987 root       20   0 27524  3688  2620 S  0.0  2.0  0:00.00 /usr/sbin/console
 1988 root       20   0 27524  3688  2620 S  0.0  2.0  0:00.00 /usr/sbin/console
 1989 root       20   0 27524  3688  2620 S  0.0  2.0  0:00.00 /usr/sbin/console
 1990 root       20   0 27524  3688  2620 S  0.0  2.0  0:00.00 /usr/sbin/console
 1991 root       20   0 27524  3688  2620 S  0.0  2.0  0:00.00 /usr/sbin/console
 1992 root       20   0 27524  3688  2620 S  0.0  2.0  0:00.00 /usr/sbin/console
 1993 root       20   0 27524  3688  2620 S  0.0  2.0  0:00.00 /usr/sbin/console
 1994 root       20   0 27524  3688  2620 S  0.0  2.0  0:00.00 /usr/sbin/console
 1996 root       20   0 27524  3688  2620 S  0.0  2.0  0:00.00 /usr/sbin/console
 1997 root       21   1 27524  3688  2620 S  0.0  2.0  0:00.02 /usr/sbin/console
 1932 root       20   0 27524  3688  2620 S  0.0  2.0  0:00.21 /usr/sbin/console
 2001 root       20   0 22276  2924  2444 S  0.0  1.5  0:00.02 /usr/lib/policyki
 1999 root       20   0 22276  2924  2444 S  0.0  1.5  0:00.16 /usr/lib/policyki
 2008 root       27   7  5592  2764  1536 S  0.0  1.5  0:00.56 -bash
  CPU[|***                      8.6%]     Tasks: 26, 68 thr; 1 running
  Mem[|||##*****            17/184MB]     Load average: 0.30 0.19 0.07
  Swp[                        0/99MB]     Uptime: 00:01:45
 2017 root       27   7  4868  1608  1232 R  8.0  0.9  0:00.61 htop
    1 root       22   2  2136   732   624 S  0.0  0.4  0:01.75 init [2]
  137 root       20   0  2872  1284   752 S  0.0  0.7  0:00.47 udevd --daemon
  266 root       20   0  2868   988   448 S  0.0  0.5  0:00.00 udevd --daemon
  276 root       20   0  2868   988   448 S  0.0  0.5  0:00.00 udevd --daemon
 1340 root       20   0  1736   504   420 S  0.0  0.3  0:00.01 /usr/sbin/ifplugd
 1378 root       20   0  1736   512   420 S  0.0  0.3  0:00.06 /usr/sbin/ifplugd
 1652 root       20   0  4884  1996   284 S  0.0  1.1  0:00.00 dhclient -1 -v -p
 1680 root       20   0 27960  1564  1112 S  0.0  0.8  0:00.03 /usr/sbin/rsyslog
 1682 root       20   0 27960  1564  1112 S  0.0  0.8  0:00.00 /usr/sbin/rsyslog
 1683 root       20   0 27960  1564  1112 S  0.0  0.8  0:00.00 /usr/sbin/rsyslog
 1674 root       20   0 27960  1564  1112 S  0.0  0.8  0:00.08 /usr/sbin/rsyslog
 1741 root       20   0  3784   788   624 S  0.0  0.4  0:00.01 /usr/sbin/cron
 1758 messagebu  20   0  3168  1044   756 S  0.0  0.6  0:00.05 /usr/bin/dbus-dae
 1790 avahi      20   0  3372  1624  1360 S  0.0  0.9  0:00.08 avahi-daemon: run
 1791 avahi      20   0  3372   532   304 S  0.0  0.3  0:00.00 avahi-daemon: chr
 1851 ntp        20   0  5500  1496  1120 S  0.0  0.8  0:00.06 /usr/sbin/ntpd -p
F1Help  F2Setup F3SearchF4FilterF5Tree  F6SortByF7Nice -F8Nice +F9Kill  F10Quit
htop 1.0.1 - (C) 2004-2011 Hisham Muhammad
Released under the GNU GPL. See 'man' page for more info.
CPU usage bar: [low-priority/normal/kernel/virtualiz               used%]
Memory bar:    [used/buffers/cache                            used/total]
Swap bar:      [used                                          used/total]
Type and layout of header meters are configurable in the setup screen.
In monochrome, meters are displayed through different chars, in order: |#*@$%&
 Status: R: running; S: sleeping; T: traced/stopped; Z: zombie; D: disk sleep
 Arrows: scroll process list             F5 t: tree view
 Digits: incremental PID search             u: show processes of a single user
   F3 /: incremental name search            H: hide/show user threads
   F4 \: incremental name filtering         K: hide/show kernel threads
  Space: tag processes                      F: cursor follows process
      U: untag all processes              + -: expand/collapse tree
   F9 k: kill process/tagged processes      P: sort by CPU%
   ] F7: higher priority (root only)        M: sort by MEM%
   [ F8: lower priority (+ nice)            T: sort by TIME
                                         F4 I: invert sort order
   F2 S: setup                           F6 >: select sort column
 ? F1 h: show this help screen              l: list open files with lsof
  F10 q: quit                               s: trace syscalls with strace
                                            L: trace library calls with ltrace
  CPU[||######################100.0%]     Tasks: 32, 93 thr; 3 running
  Mem[|||||||###************40/184MB]     Load average: 1.13 0.45 0.18
  Swp[                        0/99MB]     Uptime: 00:03:56
 2054 root       20   0  303M 36712 19316 R 89.0 19.4  0:52.57 /usr/lib/xbmc/xbm
 2017 root       27   7  4868  1640  1248 R  9.0  0.9  0:09.95 htop
 2066 root       20   0  303M 36712 19316 R  2.0 19.4  0:02.48 /usr/lib/xbmc/xbm
 2025 pi         20   0  6168  3340  1536 S  0.0  1.8  0:01.08 -bash
 1924 root       20   0  3784  1716  1316 S  0.0  0.9  0:00.42 /sbin/getty --noc
 2081 root       21   1  303M 36712 19316 S  0.0 19.4  0:00.36 /usr/lib/xbmc/xbm
 1930 root       20   0  3784  1716  1316 S  0.0  0.9  0:00.35 /bin/login --
 1932 root       20   0 27588  3784  2696 S  0.0  2.0  0:00.32 /usr/sbin/console
 1999 root       20   0 22728  3284  2672 S  0.0  1.7  0:00.27 /usr/lib/policyki
 2069 root       20   0 14528  3184  2704 S  0.0  1.7  0:00.27 /usr/lib/udisks/u
 2065 root       20   0  303M 36712 19316 S  0.0 19.4  0:00.21 /usr/lib/xbmc/xbm
 1758 messagebu  20   0  3284  1160   800 S  0.0  0.6  0:00.16 /usr/bin/dbus-dae
 1790 avahi      20   0  3372  1640  1376 S  0.0  0.9  0:00.14 avahi-daemon: run
 1378 root       20   0  1736   512   420 S  0.0  0.3  0:00.14 /usr/sbin/ifplugd
[email protected]:~# dmesg
[    0.000000] On node 0 totalpages: 49152
[    0.000000] free_area_init_node: node 0, pgdat c050db28, node_mem_map c05b6000
[    0.000000]   Normal zone: 384 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 48768 pages, LIFO batch:15
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    1.792316] dwc_otg: Microframe scheduler enabled
[    1.870237] dwc_otg: FIQ enabled
[    1.870256] dwc_otg: NAK holdoff enabled
[    1.870278] Module dwc_common_port init
[    2.043590] Registered led device: mmc0::
[    2.095651] Registered led device: led0
[    3.989372] usb 1-1.2.4: Product: CS1642 V1.0.07\xffffffd8\xffffffb1\xffffffb1
[    4.052636] input: ATEN CS1642 V1.0.07\xffffffd8\xffffffb1\xffffffb1 as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4:1.0/input/input0
[    4.077722] generic-usb 0003:0557:2212.0001: input: USB HID v1.00 Keyboard [ATEN CS1642 V1.0.07\xffffffd8\xffffffb1\xffffffb1] on usb-bcm2708_usb-1.2.4/input0
[    4.121530] input: ATEN CS1642 V1.0.07\xffffffd8\xffffffb1\xffffffb1 as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4:1.1/input/input1
[    4.151203] generic-usb 0003:0557:2212.0002: input: USB HID v1.00 Mouse [ATEN CS1642 V1.0.07\xffffffd8\xffffffb1\xffffffb1] on usb-bcm2708_usb-1.2.4/input1
[   20.122352] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[   24.091085] Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:102396k SS
[email protected]:~# [  637.078686] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  637.095447] pgd = ca748000
[  637.108425] [00000000] *pgd=0a74c831, *pte=00000000, *ppte=00000000
[  637.123951] Internal error: Oops: 817 [#1] PREEMPT
Entering kdb (current=0xc3c20500, pid 2099) Oops: (null)
due to oops @ 0xc01ddae4
Pid: 2099, comm:             xbmc.bin
CPU: 0    Not tainted  (3.2.27+ #250)
PC is at __copy_from_user+0xc8/0x3a4
LR is at 0x0
pc : [<c01ddae4>]    lr : [<00000000>]    psr: 00000013
sp : c3c25eac  ip : 00000010  fp : 4f56ebf4
r10: 00000010  r9 : 4db24698  r8 : 00000000
r7 : faffffef  r6 : 6c070002  r5 : cb7411c0  r4 : 4f56ebc0
r3 : 00000000  r2 : fffffff0  r1 : 4f56ebd0  r0 : 00000000
Flags: nzcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
Control: 00c5387d  Table: 0a748008  DAC: 00000015
[<c0013e1c>] (unwind_backtrace+0x0/0xf0) from [<c03777b0>] (kdb_dumpregs+0x28/0x50)
[<c03777b0>] (kdb_dumpregs+0x28/0x50) from [<c00716b0>] (kdb_main_loop+0x504/0x758)
[<c00716b0>] (kdb_main_loop+0x504/0x758) from [<c0073c7c>] (kdb_stub+0x13c/0x368)
[<c0073c7c>] (kdb_stub+0x13c/0x368) from [<c006ac80>] (kgdb_handle_exception+0x1fc/0x69c)
[<c006ac80>] (kgdb_handle_exception+0x1fc/0x69c) from [<c001359c>] (kgdb_notify+0x24/0x40)
[<c001359c>] (kgdb_notify+0x24/0x40) from [<c037e380>] (notifier_call_chain+0x44/0x84)
[<c037e380>] (notifier_call_chain+0x44/0x84) from [<c037e3f8>] (__atomic_notifier_call_chain+0x38/0x4c)
[<c037e3f8>] (__atomic_notifier_call_chain+0x38/0x4c) from [<c037e424>] (atomic_notifier_call_chain+0x18/0x20)
[<c037e424>] (atomic_notifier_call_chain+0x18/0x20) from [<c037e464>] (notify_die+0x38/0x44)
more>
Only 'q' or 'Q' are processed at more prompt, input ignored
[<c037e464>] (notify_die+0x38/0x44) from [<c00114d8>] (die+0xb0/0x37c)
[<c00114d8>] (die+0xb0/0x37c) from [<c03770d4>] (__do_kernel_fault.part.3+0x54/0x74)
[<c03770d4>] (__do_kernel_fault.part.3+0x54/0x74) from [<c037e0cc>] (do_page_fault+0x1a4/0x36c)
[<c037e0cc>] (do_page_fault+0x1a4/0x36c) from [<c0008328>] (do_DataAbort+0x34/0x98)
[<c0008328>] (do_DataAbort+0x34/0x98) from [<c037c918>] (__dabt_svc+0x38/0x60)
Exception stack(0xc3c25e60 to 0xc3c25ea8)
5e60: 00000000 4f56ebd0 fffffff0 00000000 4f56ebc0 cb7411c0 6c070002 faffffef
5e80: 00000000 4db24698 00000010 4f56ebf4 00000010 c3c25eac 00000000 c01ddae4
5ea0: 00000013 ffffffff
[<c037c918>] (__dabt_svc+0x38/0x60) from [<c01ddae4>] (__copy_from_user+0xc8/0x3a4)
kdb>
I was streaming mpeg2 files recorded from satelite from my server and it got more and more laggy and finally it stopped completely.
I have overclocking disabled because it was blocking with it.
Rgards
Aydan
FairFight
Wed Oct 31, 2012 10:43 pm
I have tried to install your 20121015 image - seems to work fine, but AirPlay does not work on it - I am able to see the device through AirPlay, but it does not play any sound when connected.
Do you have any idea why?
coldguy
Thu Nov 01, 2012 3:33 am
I'm having the same problem with AirPlay; the Pi shows up in the music app on my iPhone, I can select it, but no sound comes out. On my desktop it makes iTunes show the AirPlay menu, but it doesn't show up in the menu. The image works great otherwise, though.
mybox
Thu Nov 01, 2012 4:55 am
I noticed the xbmc gui symptom when playing video, example, a 4:3 video on a 16:9 monitor, the background (black rectangle on the left & right) is display with the console text. After end play or stop half way, the video frame is turn off & the whole screen is occupied with the console terminal for few seconds before xbmc render back the standard gui.
It is quite eye-sore to see this console terminal screen after video ends..... even though I can fit the screen while playing, but not ending or stopping where xbmc is suppose to render fast enough to draw back the full gui.
Any advise ?
FairFight
Thu Nov 01, 2012 10:04 am
I cant get it to play mkv files either. It just shows a black screen and no sound - however the time is rolling.
Anybody know how to fix that?
gossen
Fri Nov 09, 2012 5:34 pm
I have installed the 20121015 image, but AirPlay does not work on it. I can see the device on my iPhone but i get no sound from Spotify. Youtube with sound is working. Any ideas? Thanks in advance.
nIerSify
Fri Nov 09, 2012 8:41 pm
airplay does work in this image, but it has no airtunes support yet. Maybe there is the problem not getting the music to work....
Im right about to finish my bachelor thesis. I will look deeper into this after the end of november.
Best regards
Metatronin
Sun Nov 11, 2012 5:22 pm
mybox wrote:Hi,
Any advise ?
A real hacky fix is to start an mp3 file and go full screen to the openGL screen thing that bounces to the music(then quit the song and go to your video). It seems that doing that kicks out the the display buffers so the backgound is black when playing videos.
mr_wberrypi
Fri Nov 16, 2012 4:14 pm
Hi, now finally having a working pi (my first pi had to be returned..) the B model with the extended memory. Have Raspbian installed, have ssh and vnc (mac screensharing) into the pi and also installed xbmc. Which is also working, using a mini usb wifi dongle. So I managed to get soem youtube movies playing. And have the control trough xbmc remote app. Good so far.
Only thing what's still not working is Airplay. Would be nice to have that working as well. We have a few iphones and ipods around.
So I know it should be a simple setting in the system part of xbmc. But having searched all the tabs I am very sure it is not around at my xbmc. So, did I end up with the wrong version of xbmc?
How can I get this service or add-on running in my xbmc without having to reinstall it allover again. Thanks.
My second question: As mentioned I have (tightvnc) Vnc. When sharing a screen I only get the rasbian desktop (which is nice by the way). Is it also possible having a VNC with the xbmc screen?
Thanks in advance for the advise.
I used the instructions (first part) from this post here: http://www.raspberrypi.org/phpBB3/viewt ... 13#p133213 and installed soem missing libs. and Amavi-deomon.
mr_wberrypi
Sun Nov 18, 2012 8:43 am
Still did not manage to get this going. Your help will be appreciated.
mr_wberrypi wrote:Hi, now finally having a working pi (my first pi had to be returned..) the B model with the extended memory. Have Raspbian installed, have ssh and vnc (mac screensharing) into the pi and also installed xbmc. Which is also working, using a mini usb wifi dongle. So I managed to get some youtube movies playing. And have the control trough xbmc remote app. Good so far.
I used the instructions (first part) from this post here: http://www.raspberrypi.org/phpBB3/viewt ... 13#p133213 and installed some missing libs. and Amavi-deomon.
nIerSify
Thu Nov 29, 2012 9:01 pm
mr_wberrypi wrote:Hi, now finally having a working pi (my first pi had to be returned..) the B model with the extended memory. Have Raspbian installed, have ssh and vnc (mac screensharing) into the pi and also installed xbmc. Which is also working, using a mini usb wifi dongle. So I managed to get soem youtube movies playing. And have the control trough xbmc remote app. Good so far.
which version of xbmc are you using? In case you use the version i have compiled, airport should work after installing the avahi-daemon. See here: http://selfprogramming.bplaced.net/inde ... /comments/
Best regards
nIerSify
Dougo007
Raspbian XBMC (keyboard issue)
Tue Dec 04, 2012 5:09 am
If I'm in the wrong topic, remove this.
I followed this guide and it runs just fine: http://michael.gorven.za.net/blog/2012/08/06
But my keyboard acts as a giant remote control.
Is there a way to change it back to a keyboard so I can use letters in the search box?
P.S. If I broke any other forum rules; let me know because I have a habit of not knowing what they are and then I get a lot of people upset with me.
nIerSify
Sat Dec 29, 2012 9:26 am
i have compiled a new version of xbmc (frodo) which is available for download :)
See http://selfprogramming.bplaced.net/inde ... /comments/
Greetings
franastor
Thu Jan 31, 2013 8:13 pm
hi, any problem with the installations, but when y try reproduced any video only i cap listen but i cant see it.
the log :
WARNING: OpenVideoStream - Unsupported stream 0. Stream disabled
CDVDMessageQueue(video)::Put MSGQ_NOT_INITIALIZED
any solution??
sorry for my bad English
franastor
Thu Jan 31, 2013 11:05 pm
more info.
Befor install it, i cant play video omxplayer -o hdmi name.avi, after i cant play.
franastor
Fri Feb 01, 2013 9:04 am
Solved.
I changed memory split to 128 , reboot , and enjooy!!!!!
nIerSify
Tue Mar 26, 2013 4:17 pm
I have finished the compilation of XBMC 12.1 Frodo for the raspberry pi. For download and install instructions take a look at here http://selfprogramming.bplaced.net/inde ... /comments/
Best regards
Return to “Raspbian”
