can you please post or upload your xbmc.log? Its located under /root/.xbmc/temp/xbmc.log.
Normally you don´t need to create symlinks for libshairport. The installation should be enough for xbmc to recognize this library. I think your log file will solve the issue....
Best regards
nIerSify
Thanks for your quick reply, nIerSify.
My log file:
# cat /root/.xbmc/temp/xbmc.log
22:48:20 T:1074348576 NOTICE: -----------------------------------------------------------------------
22:48:20 T:1074348576 NOTICE: Starting XBMC (12.0-ALPHA7 Git:20121003-5e4b59d), Platform: Linux (wheezy/sid, 3.2.27+ armv6l). Built on Oct 4 2012
22:48:20 T:1074348576 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
22:48:20 T:1074348576 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
22:48:20 T:1074348576 NOTICE: special://masterprofile/ is mapped to: /root/.xbmc/userdata
22:48:20 T:1074348576 NOTICE: special://home/ is mapped to: /root/.xbmc
22:48:20 T:1074348576 NOTICE: special://temp/ is mapped to: /root/.xbmc/temp
22:48:20 T:1074348576 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
22:48:20 T:1074348576 NOTICE: Local hostname: raspberrypi
22:48:20 T:1074348576 NOTICE: Log File is located: /root/.xbmc/temp/xbmc.log
22:48:21 T:1074348576 NOTICE: load settings...
22:48:21 T:1074348576 NOTICE: special://profile/ is mapped to: special://masterprofile/
22:48:21 T:1074348576 NOTICE: loading special://masterprofile/guisettings.xml
22:48:21 T:1074348576 NOTICE: Getting hardware information now...
22:48:21 T:1074348576 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
22:48:21 T:1074348576 NOTICE: Loaded playercorefactory configuration
22:48:21 T:1074348576 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
22:48:21 T:1074348576 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
22:48:21 T:1074348576 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
22:48:21 T:1074348576 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<advancedsettings>
<video>
<defaultplayer>omxplayer</defaultplayer>
<defaultdvdplayer>omxplayer</defaultdvdplayer>
</video>
<audio>
<streamsilence>false</streamsilence>
</audio>
</advancedsettings>
22:48:21 T:1074348576 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
22:48:21 T:1074348576 NOTICE: Default DVD Player: omxplayer
22:48:21 T:1074348576 NOTICE: Default Video Player: omxplayer
22:48:21 T:1074348576 NOTICE: Default Audio Player: omxplayer
22:48:21 T:1074348576 NOTICE: Disabled debug logging due to GUI setting. Level -1.
I also noticed that I cant control xbmc menu using app on my idevices with zeroconf enabled and also http.
I dont see <enableairtunesdebuglog>1</enableairtunesdebuglog> on it, so I decided to retry using a fresh installation of raspbian. as I have used xbmc-20121004_1rpb-1_armhf.deb on my dev environment, and it had a compiled XBMC manually last sunday.
I will bring news by friday or saturday because tonight I have soccer/football game at stadium.
Greetings from Brazil (yep, I posted on your blog)
Regards,
Jorge
