Mettauk
Error on Update/Upgrade
Mon Mar 27, 2017 10:49 pm
When running
sudo apt-get update && sudo apt-get dist-upgrade
I get errors. I have tried Autoremove and Clean and don't know how to fix the following...
...Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
3 not fully installed or removed.
Need to get 41.9 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://archive.raspberrypi.org/debian/ jessie/main libwayland-egl1-mesa armhf 13.0.0-1+rpi1 [41.9 kB]
Fetched 41.9 kB in 0s (209 kB/s)
dpkg: error processing package libwayland-egl1-mesa:armhf (--configure):
 package is in a very bad inconsistent state; you should
 reinstall it before attempting configuration
dpkg: dependency problems prevent configuration of libgstreamer-plugins-bad1.0-0:armhf:
 libgstreamer-plugins-bad1.0-0:armhf depends on libwayland-egl1-mesa (>= 10.0.2) | libwayland-egl1; however:
  Package libwayland-egl1-mesa:armhf is not configured yet.
  Package libwayland-egl1 is not installed.
  Package libwayland-egl1-mesa:armhf which provides libwayland-egl1 is not configured yet.
dpkg: error processing package libgstreamer-plugins-bad1.0-0:armhf (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of gstreamer1.0-plugins-bad:armhf:
 gstreamer1.0-plugins-bad:armhf depends on libgstreamer-plugins-bad1.0-0 (= 1.4.4-2.1+deb8u1); however:
  Package libgstreamer-plugins-bad1.0-0:armhf is not configured yet.
dpkg: error processing package gstreamer1.0-plugins-bad:armhf (--configure):
 gstreamer1.0-plugins-bad:armhfE: Sub-process /usr/bin/dpkg returned an error code (1)
What do I need to enter to fix this??
As humans we have been the same for a very very long time, technology changes how we do... not who we are as people.
Return to “Raspberry Pi OS”
