Brownrecluse
Kodi won't recognize controller
Sun Mar 26, 2017 9:19 pm
Hi I recently installed Kodi on raspbian jessie and I cannot get Kodi to see the wired xbox 360 controller. I previously used the controller with kodi on a retropie install. Any help would be appreciated.
cat /proc/bus/input/devices shows the controller.
Rascas
Re: Kodi won't recognize controller
Mon Mar 27, 2017 2:24 am
With only that information is difficult to check your problem, but you will need Kodi 17 for xbox 360 controllers to work. RetroPie's Kodi support that.
PS: Don't know how you installed Kodi 17 on Raspbian, but if you didn't through RetroPie, you may need to install te binary addon for joystick support:
sudo apt-get install kodi-peripheral-joystick
You can take a look of additional packages available by doing:
apt-cache search kodi
And install what you want
ibshar
Thu Apr 19, 2018 3:34 pm
Thanks man, I just got a gamepad and was struggling to get it working with Kodi, finally got it to work thanks to your post.
Return to “Raspberry Pi OS”
