dcaccount
CPU temperature a system status monitor
Sat Mar 25, 2017 10:37 am
I have configured my Rpi3 as FTP server under RASPBIAN JESSIE LITE.
I would like to keep track or to monitor from time to time the CPU temperature and clock, being the Rpi3 hidden in a box.
Is there a piece of software to keep track or to report this information?
Thanks a lot,
daniele
Re: CPU temperature a system status monitor
Sat Mar 25, 2017 10:55 am
cat /sys/class/thermal/thermal_zone0/temp
You can read that in python
#!/usr/bin/python3
from time import sleep
while True:
  sleep(300)
  with open('/sys/class/thermal/thermal_zone0/temp') as temp:
    curCtemp = float(temp.read()) / 1000
    curFtemp = ((curCtemp / 5) * 9) + 32
    print ("C:", curCtemp, " F:", curFtemp)
This is a doctor free zone.
dcaccount
Sat Mar 25, 2017 11:11 am
DougieLawson wrote:cat /sys/class/thermal/thermal_zone0/temp
#!/usr/bin/python3
while True:
  sleep(300)
Thank you for advising.
You mean that the current temperature is stored in the file:
/sys/class/thermal/thermal_zone/temp?
Sat Mar 25, 2017 12:46 pm
dcaccount wrote:You mean that the current temperature is stored in the file:
It's not a real file. It's a direct interface to the internal temperature measuring system. It takes a reading every time you read the "file".
Sat Mar 25, 2017 2:22 pm
/sys, /proc and /dev are all virtual filesystems that are generated automagically by the Linux kernel.
no3rpi
Mon Apr 03, 2017 6:37 am
I made on my RPI3 a small bash script that is running every 15 min and save the CPU temp in a file located in a share that can be accessed remotely ( by www or samba/ftp... ).
Change your paths ( for save data and stored scripts ) as you need:
#!/bin/sh
CPUD=`/opt/vc/bin/vcgencmd measure_temp`
data=`date +"%d-%m-%y %T"`
echo $data $CPUD >> /var/www/html/status/cpu-temp.txt
#CPUT=${CPUD%.*}
#CPUT=${CPUT##*=}
#echo $CPUT
exit
and add to cron: crontab -e
#check & save cpu temp every 15 min
*/15 * * * * /root/scripts/cputemp.sh
edit:
if you want a permanent monitoring solution have a look at monit.
itsmedoofer
Mon Apr 03, 2017 11:28 am
If you have an Android device, there is a nice little App called RasPi Check that will query all this and more.... It's in the PlayStore...
Return to “Raspbian”
