CianHa
Re: Updating to the 2012-09-18-wheezy-raspbian image
Sat Sep 22, 2012 8:25 pm
Have I killed my Pi?
Turbo enabled, 1GHz overclock. It ran fine for a while, (temps about 65C) until I rebooted, and it failed to restart. I get the Power LED, and OK flashes, but no progress beyond that...
http://twitvid.com/D1Y47
dom
Sat Sep 22, 2012 9:04 pm
CianHa wrote:Have I killed my Pi?
The Pi is not dead but the sdcard may be corrupted. It should work if you reimage it.
CianHa
Sat Sep 22, 2012 9:13 pm
Thanks Dom, after a few calming breaths I counted the 6 flashes, googled it, and discovered the start.elf was corrupted. Panic over!
Synthetic_Darkness
Sun Sep 23, 2012 12:36 pm
Update worked fine. Thanks to everyone involved.
Regarding the SD card corruption when selecting an overclocking option. I have narrowed it down to having the Ethernnet cable plugged in. Every time I had the ethernet cable plugged in and changed overclocking setting, using raspi-config, my config.txt file would become corrupt. I confirmed this was the issue by running "sync" and then "dmesg".
Anyone else having this issue, try changing overclock settings without having a network cable plugged in.
http://codefridge.com/ - where cool code comes to chill.
urra901109
Sun Sep 23, 2012 12:47 pm
hi guys
just a question.. if i use this method "sudo apt-get update && sudo apt-get install raspberrypi* raspi-config" does it include the "FIQ usb fix"? for now i think i might want to hold to adafruits occidentalis as the new 2012-09-19 image breaks my wifi.(micronext wd152b). but the usb fix is very tempting ~up to 20% performance increase.
DevelopNow
Sun Sep 23, 2012 2:40 pm
I have the same problem as "der-don".
When I set clock up to any value with
sudo raspi-config
after reboot min, current and max cpufreq in dmesg is still 700000.
I did all the described installation steps (update from Aug Weezy).
Does anyone has an idear or solution for that behaviour?
dom
Sun Sep 23, 2012 2:43 pm
DevelopNow wrote:I have the same problem as "der-don".
sudo raspi-config
Can you look at config.txt on a PC? Is arm_freq uncommented (without a preceding #) and set to a value bigger than 700?
Does it work if you edit it on PC and then boot Pi?
Ed Raket
Sun Sep 23, 2012 2:54 pm
sudo raspi-config
Maybe your config.txt got scrambled. can you type:
sudo nano /boot/config.txt
and check the last line for: @^@^@^@^@^@^@^ caracters, and the presence of the "arm_freq=" setting please?
kavi96
Sun Sep 23, 2012 3:08 pm
I can't work out how to set a static ip address for wlan0 after using the gui wifi setup. My /etc/network/interfaces looks like this:
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
I tried changing it to
auto lo
allow-hotplug wlan0
iface wlan0 inet static
address 192.168.0.200
netmask 255.255.255.0
gateway 192.168.0.1
But when I did that it wouldn't connect. What should I change to get a static ip?
DevelopNow
Sun Sep 23, 2012 4:20 pm
Thanks a lot for your fast feedback dom and Ed Raket.
Yes there were some strange characters/symbols in the file config.txt in the comment line above the line with the arm_freq=...
First I tried to remove the strange characters with nano. But after reboot there were even more strange characters. So I deleted the hole file
rm /boot/config.txt
After that I started the config tool again
sudo raspi-config
And activated the overclock.
Going out of the raspi-config tool, I said No to the reboot question, checked again the config.txt file.
cat /boot/config.txt
After my first try, the entrance arm_freq was missing, so I set again a differen overclock mode in the raspi-config tool. After that, all 4 entrance
arm_freq
core_freq
sdram_freq
overclock_voltage
were there. Now I rebooted manualy
sudo reboot
And finaly after reboot, I see in dmesg cpufreq max=950000 so overcklock should be active now!
ovacikar
Sun Sep 23, 2012 4:23 pm
I have the custom installer version of raspbian, to boot from sdcard and online install on a usb key.
But I am having trouble getting the upgrades and new packages, what am i doing wrong (PS: my apt.sources is the one from RaspbianFAQ) ?
uname -a
Linux rpi 3.2.27+ #165 PREEMPT Thu Sep 20 22:28:17 BST 2012 armv6l GNU/Linux
cat /etc/apt/sources.list
deb http://archive.raspbian.org/raspbian wheezy main contrib non-free rpi
deb-src http://archive.raspbian.org/raspbian wheezy main contrib non-free rpi
Hit http://archive.raspbian.org wheezy InRelease
Hit http://archive.raspbian.org wheezy/main Sources
Hit http://archive.raspbian.org wheezy/contrib Sources
Hit http://archive.raspbian.org wheezy/non-free Sources
Hit http://archive.raspbian.org wheezy/rpi Sources
Hit http://archive.raspbian.org wheezy/main armhf Packages
Hit http://archive.raspbian.org wheezy/contrib armhf Packages
Hit http://archive.raspbian.org wheezy/non-free armhf Packages
Hit http://archive.raspbian.org wheezy/rpi armhf Packages
Ign http://archive.raspbian.org wheezy/contrib Translation-en_US
Ign http://archive.raspbian.org wheezy/main Translation-en_US
Ign http://archive.raspbian.org wheezy/non-free Translation-en_US
Ign http://archive.raspbian.org wheezy/rpi Translation-en_US
Reading package lists... Done
Building dependency tree
E: Unable to locate package raspberrypi*
E: Couldn't find any package by regex 'raspberrypi*'
E: Unable to locate package raspi-config
Ed Raket
Sun Sep 23, 2012 4:24 pm
@ DevelopNow; Good to hear you got it going! may i ask what kind of SD card you use?
rleyden
Sun Sep 23, 2012 6:48 pm
After upgrading, two separate python gpio programs stopped working.
I have a 1-wire temperature probe and I was using the ablib.py provided by Acme systems. Apparently, the os.path call didn't return correctly and I got "1-wire bus not found". I could manually find the path to the sensor so I just patched the correct path into ablib.py. That worked but certainly isn't elegant.
Secondly, I added a MCP3008 ADC chip following Adafruit's tutorial. This no longer works either. The line "import RPi.GPIO as GPIO" gives an error "No module named RPi.GPIO". I tried re-installing ( "pip install rpi.gpio" , successful) but python still can't find the module.
If this is due to the upgrade someone else must has experienced this, however I couldn't find mention of it elsewhere in the forums. Please point me in the right direction.
mister_wavey
Sun Sep 23, 2012 6:55 pm
I had this too with python2. I downloaded and installed the RPi.GPIO package manually to fix it. http://pypi.python.org/pypi/RPi.GPIO/#downloads if you want to do the same.
simplesi
Sun Sep 23, 2012 7:10 pm
I upgraded one system and have installed the latest on another card and both carried on working fine with the Rpi.GPIO library in Python 2.
However, I get the no module named Rpi.GPIO if I upgrade to using 0.4.0.a_1 - but it works fine again on downgrading back to the previous 0.3 version
regards
Simon
Seeking help with Scratch and I/O stuff for Primary age children
http://cymplecy.wordpress.com/ @cymplecy on twitter
rleyden
Sun Sep 23, 2012 7:46 pm
mister_wavey wrote:I had this too with python2. I downloaded and installed the RPi.GPIO package manually to fix it. http://pypi.python.org/pypi/RPi.GPIO/#downloads if you want to do the same.
This was very helpful. I'm still confused about whether I'm using python2 or python3 (mentioned in the included install.txt). I tried both. After doing the python3 install, I have progress. I no longer get the "RPi.GPIO not found" error. However, I get a new error "RuntimeWarning: This channel is already in use.". This occurs in my code where the pins are assigned.
# SPI port on the ADC to the Cobbler
SPICLK = 18
SPIMISO = 23
SPIMOSI = 24
SPICS = 25
# set up the SPI interface pins
GPIO.setup(SPIMOSI, GPIO.OUT)
GPIO.setup(SPIMISO, GPIO.IN)
GPIO.setup(SPICLK, GPIO.OUT)
GPIO.setup(SPICS, GPIO.OUT)
The program ignores the "in use warning" but doesn't see any output.
Do I have to re-assign the pins?
DevelopNow
Sun Sep 23, 2012 8:17 pm
@Ed Roket: I'm using a 4 GB "MAX 133x" SD Card. It's an 'old' card that I used before in my camera. It is for sure 2 to 3 years old.
Is there an SD Card recomendation list?
simplesi
Sun Sep 23, 2012 8:25 pm
@croston has posted a short term fix if your using 0.4.0.a_1
sudo touch /usr/lib/python2.7/dist-packages/RPi/__init__.py
Just tried it on mine and I'm back working again :)
regards
Simon
Ed Raket
Sun Sep 23, 2012 9:38 pm
DevelopNow wrote:@Ed Roket: I'm using a 4 GB "MAX 133x" SD Card. It's an 'old' card that I used before in my camera. It is for sure 2 to 3 years old.
Yes... and no, there is this list of compatible SD cards: http://elinux.org/RPi_VerifiedPeriphera ... g_SD_Cards but... the specific problem popped up with the latest version of Raspbian, so this list is not relevent anymore. So, i suppose we make a new list for (out of the box) compatible hardware (anyway SD cards) for the latest version of raspbian ;)
chillywillycd
Mon Sep 24, 2012 3:14 am
I have assumed that if I'm running as a user other than 'pi' that i'd want to execute
 adduser <myuser> netdev
is that correct?
Thanks!
--chillywilly
Dweeber
Mon Sep 24, 2012 4:52 am
rpi-update is not in the new image?
Used to be located in /usr/bin/rpi-update
Is this a change?
Dweeber A.K.A. Kevin...
My RPI Info Pages including Current Setup - http://rpi.tnet.com
Synthetic_Darkness
Mon Sep 24, 2012 5:52 am
Dweeber wrote:rpi-update is not in the new image?
Is this a change?
I dont think that rpi-update was ever included in the image. I could be wrong though.
der-don
Mon Sep 24, 2012 6:08 am
DevelopNow wrote:Thanks a lot for your fast feedback dom and Ed Raket.
rm /boot/config.txt
sudo raspi-config
arm_freq
core_freq
sdram_freq
overclock_voltage
sudo reboot
Did the same thing now. I deleted the config.txt and ran the raspi-config again. First I tried to set the speed to 900 MHz. A new config.txt was written, with this content:
core_freq=500
sdram_freq=500
over_voltage=6
Then, without booting, I ran the raspi-config again and set the speed to 1000 MHz. After that, the config.txt looked like this:
core_freq=500
sdram_freq=500
over_voltage=6
arm_freq=1000
After a reboot, the PI is running at up to 1000 MHz. :)
Ed Raket
Mon Sep 24, 2012 6:25 am
@DevelopNow
@der-don
Great that you guys got things working by re-writing the "config.txt"! Could you check in a day or two if those settings/that file remains intact? (unscrambled)
kavi96
Mon Sep 24, 2012 6:34 am
kavi96 wrote:I can't work out how to set a static ip address for wlan0 after using the gui wifi setup. My /etc/network/interfaces looks like this:
auto lo
allow-hotplug wlan0
auto lo
allow-hotplug wlan0
gateway 192.168.0.1
Any ideas on how to get this working?
Return to “Raspberry Pi OS”
