dom
Re: Updating to the 2012-09-18-wheezy-raspbian image
Fri Sep 21, 2012 9:48 pm
der-don wrote:I measure it using cpufreq-info (you have to install cpufrequtils to use that). It shows the minimum frequency, the maximum frequency and the current frequency and they're all set to 700 MHz. And I measured speed with this command: time echo "scale=2000; a(1)*4" | bc -l It took about 29 seconds on the default RasPi and about 20 with 900 MHz. Now it's taking ~28 sec. again :(
What does this report:
dmesg |grep cpufreq
Hikerd
Sat Sep 22, 2012 4:38 am
Could someone help me out with using Python? Just need a simple import of the CPU temp/Freq into a print command. I've got the concept but my syntax is incorrect and I can't find it using google/wiki... for the moment.
Thanks,
H
cloud_strife84
Sat Sep 22, 2012 8:42 am
How can I set manual ip address in this new distro?
slabua
Sat Sep 22, 2012 9:09 am
How about CEC support, upgrading from a July Raspbian image?
I read that CEC is supported since the August Raspbian image, do I need to install any further package?
Salvatore La Bua - www.slblabs.com
DICGIM - University of Palermo, Italy
Dweeber
Sat Sep 22, 2012 10:07 am
Hikerd wrote:Could someone help me out with using Python? Just need a simple import of the CPU temp/Freq into a print command. I've got the concept but my syntax is incorrect and I can't find it using google/wiki... for the moment.
Thanks,
H
Try over in the [url=ttp://www.raspberrypi.org/phpBB3/viewforum.php?f=32]Python Thread[/url]
Also helps to see what you tried.
Dweeber A.K.A. Kevin...
My RPI Info Pages including Current Setup - http://rpi.tnet.com
wallarug
Sat Sep 22, 2012 10:16 am
cloud_strife84 wrote:How can I set manual ip address in this new distro?
Same as in the old Raspbian distro.
Type:
sudo nano /etc/network/interfaces
into a terminal or command line. Then in that file change:
auto eth0
iface eth0 inet dhcp
to:
auto eth0
iface eth0 inet static
address 192.168.1.5
netmask 255.255.255.0
gateway 192.168.1.254
If this doesn't work try with indenting:
auto eth0
     address 192.168.1.5
Hope this helps.
Good Luck.
cloud_strife84
Sat Sep 22, 2012 10:21 am
Thanks for the reply! But i need to set up wifi and not ethernet
wallarug
Sat Sep 22, 2012 10:29 am
cloud_strife84 wrote:Thanks for the reply! But i need to set up wifi and not ethernet
Replace eth0 with wlan0 (or the number of the device that you are using.)
bloodline
Sat Sep 22, 2012 10:42 am
If I select Turbo mode in the raspi-config, even though it overvolts the core... I won't invalidate my warranty? Is this correct?
dom
Sat Sep 22, 2012 10:48 am
bloodline wrote:If I select Turbo mode in the raspi-config, even though it overvolts the core... I won't invalidate my warranty? Is this correct?
Yes.
dom
Sat Sep 22, 2012 10:51 am
Ed Raket wrote:I tried a new install on an other SD card i found, it is an older Sandisk "extreme III" 2gb... And the "scrambling" problem is gone! Turbo mode works fine, no corruption of the filesystem anymore :D
Maybe we should open a wiki section for "turbo mode compatible" SD card's?
There's more discussion on sdcard corruption here:
http://www.raspberrypi.org/phpBB3/viewt ... 27#p179227
Try leaving the overclock in place, but editing core_freq back to 250. Report any results on the linked thread.
bloodline
Sat Sep 22, 2012 11:52 am
Yes.
Excellent!
Seems my board won't cope with Turbo mode, it crashes after a few seconds of heavy CPU load... High (950Mhz) seems to be working so far... my Board is quite an early one (I got it on June the 1st) so it might not have the headroom of newer ones.
bloodline
Sat Sep 22, 2012 12:02 pm
The apt-get update and upgrade doesn't seem to give me the CPU temp and freq monitors on my desktop... where can I get them from?
dom
Sat Sep 22, 2012 1:38 pm
bloodline wrote:The apt-get update and upgrade doesn't seem to give me the CPU temp and freq monitors on my desktop... where can I get them from?
Did you run:
sudo apt-get update && sudo apt-get install raspberrypi* raspi-config
suggested in the first post? Did you then run rasp-config, enable overclock and reboot?
marosg
Sat Sep 22, 2012 2:02 pm
Hm, is that just me ? After apt-get upgrade I see the same problem which was here couple of months ago - after some time, deluged fails. I don't remember what was the solution last time. I was running deluged without a problem since start of August.
bloodline
Sat Sep 22, 2012 2:12 pm
Did you run:
Yes, I have realised I just needed to add them to my dock pannel... :)
Right... now I think I might be getting SD-Card write corruption... time to do some more testing... :)
der-don
Sat Sep 22, 2012 2:22 pm
dmesg |grep cpufreq
pi@raspberrypi ~ $ dmesg |grep cpufreq
[ 1.958928] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[ 1.964768] bcm2835-cpufreq: switching to governor powersave
[ 1.977757] bcm2835-cpufreq: switching to governor powersave
[ 21.208659] bcm2835-cpufreq: switching to governor ondemand
[ 21.208687] bcm2835-cpufreq: switching to governor ondemand
[ 25.219175] bcm2835-cpufreq: switching to governor ondemand
[ 25.219212] bcm2835-cpufreq: switching to governor ondemand
[ 28.647181] bcm2835-cpufreq: switching to governor ondemand
[ 28.647217] bcm2835-cpufreq: switching to governor ondemand
As I mentioned, it should use the 1 GHz Turbo mode.
dom
Sat Sep 22, 2012 2:46 pm
der-don wrote:[ 1.958928] bcm2835-cpufreq: min=700000 max=700000 cur=700000
max should be more than 700000 for overclocking. Have you selected an overclock option from raspi-config?
You could just edit /boot/config.txt and ensure arm_freq=900 (or similar).
dliloch
Sat Sep 22, 2012 3:10 pm
It's "working" as you will see from my measurements .. but real world stuff like midori I get
zero performance improvement... is the latency too large? something is preventing the governor from
recognizing that it should switch up..
pi@raspberrypi ~ $ stress -c 1 & sleep 3; echo "CPU freq: "; cat /sysdevices/system/cpu/cpu0/cpufreq/scaling_cur_freq ; cpufreq-info; killall stress
[1] 2561
stress: info: [2561] dispatching hogs: 1 cpu, 0 io, 0 vm, 0 hdd
CPU freq:
950000
cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009
Report errors and bugs to cpufreq@vger.kernel.org, please.
analyzing CPU 0:
  driver: BCM2835 CPUFreq
  CPUs which run at the same hardware frequency: 0
  CPUs which need to have their frequency coordinated by software: 0
  maximum transition latency: 355 us.
  hardware limits: 700 MHz - 950 MHz
  available cpufreq governors: conservative, ondemand, userspace, powersave, performance
  current policy: frequency should be within 700 MHz and 950 MHz.
                  The governor "ondemand" may decide which speed to use
                  within this range.
  current CPU frequency is 950 MHz.
[1]+  Terminated              stress -c 1
pi@raspberrypi ~ $ uname -a
Linux raspberrypi 3.2.27+ #160 PREEMPT Mon Sep 17 23:18:42 BST 2012 armv6l GNU/Linux
mikerr
Sat Sep 22, 2012 4:20 pm
While playing, open another SSH terminal (or console window)
and run this in it:
watch  "/opt/vc/bin/vcgencmd measure_temp && cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq"
Nice to watch the guv'nor at work:
Every 2.0s: /opt/vc/bin/vcgencmd measure_temp && ca... Sat Sep 22 17:19:50 2012
temp=46.0'C
1000000
milhouse
Sat Sep 22, 2012 4:27 pm
I created a simple script to monitor the overclock settings, you can download it with:
wget http://www.nmacleod.com/public/bcmstat.sh
chmod +x bcmstat.sh
It takes an optional delay parameter (seconds), eg.
./bcmstat.sh 5
to display details every 5 seconds (default is 2).
In Raspbian it requires you to install gawk (apt-get install gawk) as the default awk is from the dinosaur era. Works fine as-is in OpenELEC.
dliloch
Sat Sep 22, 2012 4:52 pm
solved... downloaded the new 9/18/2012 image of raspbian and before I "modified" anything
I set the clock to HI 950mhz.. works perfect... so I don't know what I did to mess it up but
I will start putting in my apps now one by one and test after each one .. midori works great and
the applet does indeed show it @950mhz while coming up. Midori is now usable .. great job!!!
I am also copying a huge file from my old SD to the new sd.. I hover over the freq applet which does change on hover .. and it will not go beyond 700mhz .. now the cpu is pegged here according to the usage indicator .. so I am wondering if IO bound workloads are excluded somehow.. due to the large amount of relative wait time ??
went over to midori to see if I clicked it would it increase the speed .. system crashed ..
more than crashed .. SD image corrupted.. so refreshed image .. I really think there is an
issue with I/O and the overclocking ... I will try a slower speed next ...
der-don
Sat Sep 22, 2012 5:08 pm
Yes, I did that. It worked for the first time when I increased frequency to 900 MHz. Now, not even that increase works. Now I edited the /boot/config.txt using "sudo nano /boot/config.txt" and changed the value to 900. But after a reboot, the change is gone and there's a # at the beginning of the line again. What else do I have to do to edit the file?
I already checked if my SD-Card has it's write protection set to locked, but it's not locked.
dom
Sat Sep 22, 2012 5:16 pm
der-don wrote:Yes, I did that. It worked for the first time when I increased frequency to 900 MHz. Now, not even that increase works. Now I edited the /boot/config.txt using "sudo nano /boot/config.txt" and changed the value to 900. But after a reboot, the change is gone and there's a # at the beginning of the line again. What else do I have to do to edit the file?
Can you try editing the file on a windows or linux machine and see if that works.
mikerr
Sat Sep 22, 2012 6:38 pm
der-don wrote: And I measured speed with this command:
17 seconds with Turbo.
Return to “Raspberry Pi OS”
