lohtse
Latest Update Pi B+ nolonger can access GPIO
Thu Mar 09, 2017 2:52 pm
Hi All
I have recently update the OS and firmware on our beloved Pi B+
We did the following
sudo apt-get update All was ok
sudo apt-get upgrade did reboot and all was ok
sudo rpi-update did reboot now only 3v power gpio pins is working!!!
We use the B+ as a weather monitor and clock so have several sensors and led screens attached all was working before rpi-update but now none work other than one 3v power gpio pin... I STRESS THEY HAVE ALL BEEN WORKING FINE and have been for over a month in the last hardware configuration..
does anyone have any ideas what's happened? why? and how to fix it???
thank you
regards
Lohtse
3x Pi-3 1 x Pi-2 1 x Pi-B+ 1 x Pi-B 2 xPi-Zero 1 x Pi Zero W and a massive ever growing box/room of bits and bobs for them!
Re: Latest Update Pi B+ nolonger can access GPIO
Thu Mar 09, 2017 3:02 pm
lohtse wrote:Hi All
thank you
regards
Lohtse
Please do not use rpi-update in Raspbian Jessie, it install a Testing Kernel which can and does break things.
Raspbian Jessie Kernel / Firmware is now via update / dist-upgrade....
This advice from DL shows how to unpick using rpi-update:
viewtopic.php?f=91&t=176752&p=1127327#p1127327
Updating Raspbian Jessie
sudo apt-get update
sudo apt-get dist-upgrade
Retired disgracefully.....
lohtse
Thu Mar 09, 2017 4:42 pm
fruitoftheloom wrote:
lohtse wrote:Hi All
thank you
regards
Lohtse
sudo apt-get update
Thank you for that.... life saver
Loving this forum due to folks like you
Return to “Raspbian”
