freefish
How to build plugin for lxpanel?
Wed Mar 08, 2017 2:50 am
I want to write a battery plugin for lxpanel,but I can't get build-dep for lxpanel
when i try to install lxpanel-dev
sudo apt-get install lxpanel-dev
Reading package lists... Done
Building dependency tree
E: Unable to locate package lxpanel-dev
where can i find lxpanel-dev?
https://wiki.lxde.org/en/How_to_write_p ... or_LXPanel
wget http://ftp.us.debian.org/debian/pool/ma ... _armhf.deb
sudo dpkg -i lxpanel-dev_0.9.3-1_armhf.deb
Selecting previously unselected package lxpanel-dev.
dpkg: regarding lxpanel-dev_0.9.3-1_armhf.deb containing lxpanel-dev:
lxpanel-dev breaks lxpanel (<< 0.8.2)
lxpanel (version 0.7.2-1+rpi19) is present and installed.
dpkg: error processing archive lxpanel-dev_0.9.3-1_armhf.deb (--install):
installing lxpanel-dev would break lxpanel, and
deconfiguration is not permitted (--auto-deconfigure might help)
saaaadkaaaa
Re: How to build plugin for lxpanel?
Sat Aug 04, 2018 5:34 pm
Seconding this question.
I have a battery which sends its status via USB, and I can access it from my terminal using: mybattery status
If possible I would even be happy modifying the existing battery plugin, but even after searching for over an hour I could not find the relevant files or instructions.
Return to “Raspbian”
