peba
HDMI modes broken after apt-get upgrade
Mon Sep 17, 2012 9:16 pm
After doing an apt-get update and apt-get upgrade (17.09.2012) most of the HDMI modes seem not to work as expected.
Symtoms:
Whatever hdmi mode and hdmi group selected in the config.txt the hdmi output mode is just 640x480 or it is 1600x1200.
Regards,
Peter
dom
Re: HDMI modes broken after apt-get upgrade
Mon Sep 17, 2012 9:28 pm
Will need more information.
zip up and attach your edid.dat:
/opt/vc/bin/tvservice -d edid.dat
and tell me which groups/modes you have tried.
peba
Tue Sep 18, 2012 4:41 pm
just tried hdmi group 2 and hdmi mode 24.
after reboot I get a resolution of 640x480.
Regards,
Peter
dom wrote:Will need more information.
edid.dat.zip
(232 Bytes) Downloaded 78 times
dom
Tue Sep 18, 2012 5:27 pm
Well, DMT mode=24 isn't reported as supported by your display.
You can add:
hdmi_ignore_edid=0xa5000080
if you believe it really is supported.
Parsing edid.dat...
HDMI:EDID version 1.3, 0 extensions, screen size 51x29 cm
HDMI:EDID features - videodef 0x80 !standby !suspend active off; colour encoding:RGB444|YCbCr444|YCbCr422; sRGB is default colourspace; preferred format is native; does not support GTF
HDMI:EDID found monitor S/N descriptor tag 0xff
HDMI:EDID found monitor range descriptor tag 0xfd
HDMI:EDID monitor range offsets: V min=0, V max=0, H min=0, H max=0
HDMI:EDID monitor range: vertical is 50-75 Hz, horizontal is 24-82 kHz, max pixel clock is 170 MHz
HDMI:EDID monitor range does not support GTF
HDMI:EDID found monitor name descriptor tag 0xfc
HDMI:EDID monitor name is VP2365WB
HDMI:EDID found preferred CEA detail timing format: 1920x1080p @ 60 Hz (16)
HDMI:EDID established timing I/II bytes are BF EF 80
HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 5, 640x480p @ 72 Hz in established timing I/II
HDMI:EDID found DMT format: code 6, 640x480p @ 75 Hz in established timing I/II
HDMI:EDID found DMT format: code 8, 800x600p @ 56 Hz in established timing I/II
HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 10, 800x600p @ 72 Hz in established timing I/II
HDMI:EDID found DMT format: code 11, 800x600p @ 75 Hz in established timing I/II
HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 17, 1024x768p @ 70 Hz in established timing I/II
HDMI:EDID found DMT format: code 18, 1024x768p @ 75 Hz in established timing I/II
HDMI:EDID found DMT format: code 36, 1280x1024p @ 75 Hz in established timing I/II
HDMI:EDID standard timings block x 8: 0xB300 A940 9500 9040 8180 8140 714F 0101
HDMI:EDID found DMT format: code 58, 1680x1050p @ 60 Hz (16:10) in standard timing 0
HDMI:EDID found DMT format: code 51, 1600x1200p @ 60 Hz (4:3) in standard timing 1
HDMI:EDID found DMT format: code 47, 1440x900p @ 60 Hz (16:10) in standard timing 2
HDMI:EDID found DMT format: code 42, 1400x1050p @ 60 Hz (4:3) in standard timing 3
HDMI:EDID found DMT format: code 35, 1280x1024p @ 60 Hz (5:4) in standard timing 4
HDMI:EDID found DMT format: code 32, 1280x960p @ 60 Hz (4:3) in standard timing 5
HDMI:EDID found DMT format: code 21, 1152x864p @ 75 Hz (4:3) in standard timing 6
HDMI:EDID moving support for CEA mode 16 to DMT mode 82 because sink does not support HDMI
HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
HDMI:EDID best score mode initialised to CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 18432)
HDMI:EDID DMT mode (4) 640x480p @ 60 Hz with pixel clock 25 MHz has a score of 18432
HDMI:EDID best score mode is now DMT (5) 640x480 @ 72 MHz with pixel clock 31 Hz (score 22118)
HDMI:EDID best score mode is now DMT (6) 640x480 @ 75 MHz with pixel clock 31 Hz (score 23040)
HDMI:EDID best score mode is now DMT (8) 800x600 @ 56 MHz with pixel clock 36 Hz (score 26880)
HDMI:EDID best score mode is now DMT (9) 800x600 @ 60 MHz with pixel clock 40 Hz (score 28800)
HDMI:EDID best score mode is now DMT (10) 800x600 @ 72 MHz with pixel clock 50 Hz (score 34560)
HDMI:EDID best score mode is now DMT (11) 800x600 @ 75 MHz with pixel clock 49 Hz (score 36000)
HDMI:EDID best score mode is now DMT (16) 1024x768 @ 60 MHz with pixel clock 65 Hz (score 47185)
HDMI:EDID best score mode is now DMT (17) 1024x768 @ 70 MHz with pixel clock 75 Hz (score 55050)
HDMI:EDID best score mode is now DMT (18) 1024x768 @ 75 MHz with pixel clock 78 Hz (score 58982)
HDMI:EDID best score mode is now DMT (21) 1152x864 @ 75 MHz with pixel clock 108 Hz (score 99649)
HDMI:EDID DMT mode (32) 1280x960p @ 60 Hz with pixel clock 108 MHz has a score of 98728
HDMI:EDID best score mode is now DMT (35) 1280x1024 @ 60 MHz with pixel clock 108 Hz (score 103643)
HDMI:EDID DMT mode (36) 1280x1024p @ 75 Hz with pixel clock 135 MHz has a score of 98304
HDMI:EDID best score mode is now DMT (42) 1400x1050 @ 60 MHz with pixel clock 121 Hz (score 113200)
HDMI:EDID DMT mode (47) 1440x900p @ 60 Hz with pixel clock 106 MHz has a score of 102760
HDMI:EDID best score mode is now DMT (51) 1600x1200 @ 60 MHz with pixel clock 162 Hz (score 140200)
HDMI:EDID DMT mode (58) 1680x1050p @ 60 Hz with pixel clock 146 MHz has a score of 130840
HDMI:EDID DMT mode (82) 1920x1080p @ 60 Hz with pixel clock 148 MHz has a score of 124416
HDMI:EDID preferred mode is updated to DMT (51) 1600x1200p @ 60 Hz with pixel clock 162000000 Hz
HDMI:EDID has only DVI support and no audio support
edid_parser exited with code 0
peba
Tue Sep 18, 2012 6:15 pm
Well, I tried a more common mode
DMT mode 16 which is 1024x768 @ 60 Hz which leaves me with a black screen after reboot
Thank you for your patience,
Peter
edid.dat.zip
(232 Bytes) Downloaded 76 times
Return to “Raspberry Pi OS”
