amyren
keyboard layout
Fri Sep 14, 2012 5:19 pm
I have set in raspi-config to use norwegian keyboard layout, and also norwegian as default system layout.
I now get norwegian letters and the correct layout from the commandline, before launching x.
But when starting the x-environment the keyboard layout is back to standard UK layout.
I have checked the /etc/default/keyboard file and it does show "no"
Is there another setting for the keyboard layout in the lxde environment, or is something messed up in my setup?
Sleep Mode zZ
Re: keyboard layout
Fri Sep 14, 2012 6:23 pm
I had the same problem. A solution that seems to be working:
Create a file called .xsessionrc in your home directory. In it you can use the command setxkbmap to set the layout you need.
My line:
setxkbmap fi,us -option grp:ctrl_shift_toggle
Maybe setxkbmap <layout_name> would be enough. (Sorry, I don't know the Norwegian layout name.)
amyren
Re: keyboard layout
Fri Sep 14, 2012 6:36 pm
Thanks, I will try that
btw, I noticed in your line you have fi,us
I guess the fi is to get the keymap for Finland, but why the ",us". Can you have two keymaps active?
Sleep Mode zZ
Re: keyboard layout
Fri Sep 14, 2012 6:52 pm
amyren wrote:Thanks, I will try that
I can change between them from an applet in the lxde-panel.
(Actually I don't think I need the us layout. I will probably remove it and also the option that presumably gives a way to toggle between the layouts. I found the xsetkbmap command just today and copied someone elses settings, so I'm not an expert...)
amyren
Re: keyboard layout
Sat Sep 15, 2012 2:27 pm
It worked fine, I just tried with "setxkbmap no" and everything like it should be.
MeeM
Re: keyboard layout
Sat Nov 22, 2014 7:20 am
I've tried various options with this command and have had no luck. My hash key still shows as a UK pound symbol on screen, making it hard for me to write C code. Any ideas?
I'm using a Microsoft Arc keyboard which otherwise works fine with my Pi in command line and GUI mode. I've tried "setxkbmap us" but to no avail.
Any help appreciated.
diederik
Re: keyboard layout
Sat Nov 22, 2014 1:53 pm
# dpkg-reconfigure keyboard-configuration
as root or prepend it with sudo.
https://wiki.debian.org/Keyboard
klricks
Re: keyboard layout
Sat Nov 22, 2014 2:43 pm
MeeM wrote:I've tried various options with this command and have had no luck. My hash key still shows as a UK pound symbol on screen, making it hard for me to write C code. Any ideas?
(For Raspbian OS)
sudo raspi-config
- Choose Internationalization menu
- Choose keyboard setup menu.
- If your exact keyboard is not on the list then choose one of the generic 101, 102 or 104 keyboards.
The following steps are Important! If need US then you must choose US. Don't leave it set to UK.......
- The default Keyboard Layout is [ English (UK) ]
- You may need to scroll down and select [Other] to get back to the country of origin menu
- From country of origin menu select [English (US) ]
- Then from Keyboard layout: menu, scroll to top of list and select - [ English (US) ]. Do not choose anything else unless you know exactly what you are doing!
- Complete the other menus then reboot.
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
Return to “Raspbian”
Who is online
Users browsing this forum: No registered users and 8 guests
