andig2
[SOVLED] apt-get segfaults
Fri Jan 27, 2017 4:06 pm
[email protected]:~ $ sudo apt update
E: Method http has died unexpectedly!
E: Sub-process http received a segmentation fault.
[email protected]:~ $ sudo apt-get -v
apt 1.0.9.8.4 for armhf compiled on Dec 13 2016 22:26:22
Supported modules:
*Ver: Standard .deb
*Pkg:  Debian dpkg interface (Priority 30)
 Pkg:  Debian APT solver interface (Priority -1000)
 S.L: 'deb' Standard Debian binary tree
 S.L: 'deb-src' Standard Debian source tree
 Idx: Debian Source Index
 Idx: Debian Package Index
 Idx: Debian Translation Index
 Idx: Debian dpkg status file
 Idx: EDSP scenario file
[email protected]:~ $ uname -a
Linux keller 4.4.44-v7+ #950 SMP Sun Jan 22 16:20:42 GMT 2017 armv7l GNU/Linux
B.Goode
Re: apt-get segfaults
Fri Jan 27, 2017 4:13 pm
I almost certainly can't answer: but to put other people in a position where they might be able to -
Is there any context or 'back-story' to this?
Is it a fresh, out of the box, installation of Raspbian Jessie?
Previous posts suggest you have experience of modifying the sources from which apt retrieves its information. Is that the case here?
andig2
Fri Jan 27, 2017 4:50 pm
Not much of a back story. Several raspies running for ages. Moved my webserver to new raspi3 and just got warned that my letsencrypt certificates are expiring. Looking into the logfile I see certbot complains about missing apache modules (but doesn't say which). Trying to upgrade certbot and bamm. Before that the raspi was running untouched for weeks. So not a clean install :|
This is my apt config:
[email protected]:~ $ cat /etc/apt/sources.list
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
deb http://mirrordirector.raspbian.org/raspbian/ stretch main contrib non-free rpi
deb http://httpredir.debian.org/debian jessie-backports main contrib non-free
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://archive.raspbian.org/raspbian/ jessie main contrib non-free rpi
[email protected]:~ $ cat /etc/apt/preferences
Package: *
Pin: release n=jessie
Pin-Priority: 500
Package: *
Pin: release n=stretch
Pin-Priority: 10
andig2
Fri Jan 27, 2017 5:03 pm
I have no clue what the apt http module is, but apt itself seems to be the jessie package:
[email protected]:~ $ apt-cache policy apt
apt:
  Installed: 1.0.9.8.4
  Candidate: 1.4~beta2
  Version table:
     1.4~beta2 0
        500 http://mirrordirector.raspbian.org/raspbian/ stretch/main armhf Packages
 *** 1.0.9.8.4 0
        500 http://mirrordirector.raspbian.org/raspbian/ jessie/main armhf Packages
        100 /var/lib/dpkg/status
andig2
Fri Jan 27, 2017 5:11 pm
There is a report here https://bugs.launchpad.net/ubuntu/+sour ... ug/1457754 that indicates underlying curl/gnu tls or similar might be the issue. Need to figure out if/how I could downgrade those. :ugeek:
andig2
Fri Jan 27, 2017 5:43 pm
ok.... fixed by reinstalling apt (however these seem to be the same versions as originally present). Whatever :roll:
cd /tmp
wget -r -nH -nd -np http://mirrordirector.raspbian.org/raspbian/pool/main/a/apt/
sudo dpkg -i apt-utils_1.0.9.8.4_armhf.deb apt_1.0.9.8.4_armhf.deb libapt-inst1.5_1.0.9.8.4_armhf.deb libapt-pkg4.12_1.0.9.8.4_armhf.deb
ShiftPlusOne
Re: [SOVLED] apt-get segfaults
Fri Jan 27, 2017 5:52 pm
What SD card are you using?
Return to “Raspbian”
