dbip
Kernel different to directory structure
Sun Jan 15, 2017 7:00 pm
Hi there,
First, my kernel:
Linux server 4.4.34-v7+ #930 SMP Wed Nov 23 15:20:41 GMT 2016 armv7l GNU/Linux
Then, the problem, when trying to load the sound module with
sudo modprobe snd-bcm2835
I get the error below:
modprobe: ERROR: ../libkmod/libkmod.c:557 kmod_search_moddep() could not open moddep file '/lib/modules/4.4.34-v7+/modules.dep.bin'
I checked the directory tree and I don't have such 4.4.34 directory but these ones:
4.4.38-v7+
Is there anything wrong with the installation of raspbian? I can't get the sound to work, and after spending so many hours I am quite afraid the problem comes from here, as "lsmod" doesn't list anything at all and can't get the module to load.
Thanks.
d.
FlexibleSigmoid
Re: Kernel different to directory structure
Mon Jan 16, 2017 2:29 am
The kernel and modules have been updated (most likely via apt-get) and the "old" modules have been deleted in the process, however the running kernel remains.
Reboot and load the new kernel to match the modules to the new kernel version and you should be all set.
dbip
Mon Jan 16, 2017 8:11 am
FlexibleSigmoid,
Thanks for your answer. I've checked the repository looking for kernel 4.4.38 so I can make it match the directory structure but there's no such version .38, command "sudo apt-cache search linux-image" returns:
linux-headers-3.10-3-rpi - Header files for Linux 3.10-3-rpi
linux-headers-3.12-1-rpi - Header files for Linux 3.12-1-rpi
linux-headers-3.16.0-4-rpi - Header files for Linux 3.16.0-4-rpi
linux-headers-3.18.0-trunk-rpi - Header files for Linux 3.18.0-trunk-rpi
linux-headers-3.18.0-trunk-rpi2 - Header files for Linux 3.18.0-trunk-rpi2
linux-headers-3.6-trunk-rpi - Header files for Linux 3.6-trunk-rpi
linux-headers-4.4.0-1-rpi - Header files for Linux 4.4.0-1-rpi
linux-headers-4.4.0-1-rpi2 - Header files for Linux 4.4.0-1-rpi2
linux-image-3.10-3-rpi - Linux 3.10 for RaspberryPI
linux-image-3.12-1-rpi - Linux 3.12 for RaspberryPI
linux-image-3.16.0-4-rpi - Linux 3.16 for RaspberryPI
linux-image-3.18.0-trunk-rpi - Linux 3.18 for RaspberryPI
linux-image-3.18.0-trunk-rpi2 - Linux 3.18 for RaspberryPI2
linux-image-3.6-trunk-rpi - Linux 3.6 for RaspberryPI
linux-image-4.4.0-1-rpi - Linux 4.4 for RaspberryPI
linux-image-4.4.0-1-rpi2 - Linux 4.4 for RaspberryPI2
linux-image-rpi - Linux for RaspberryPI (meta-package)
linux-image-rpi-rpfv - This metapackage will pull in the raspbian kernel for the raspberry pi 1
linux-image-rpi2-rpfv - This metapackage will pull in the raspbian kernel for the raspberry pi 2
raspberrypi-kernel - Raspberry Pi bootloader
May you tell me how to make it match?
Thanks!
Mon Jan 16, 2017 11:39 am
To get a coherent source tree us rpi-source.
https://github.com/notro/rpi-source
Return to “Raspberry Pi OS”
