gkreidl
Broken dependencies of dev packages
Wed Dec 14, 2016 8:35 am
After installing the latest updates a number of dev packages have broken dependencies:
libxfont-dev: Depends on: libxfont1 (=1:1.5.1-1), but 1:1.5.2-1 will be installed
libva-dev: Depends on: libva1 (=1.4.1-1), but 1.7.2-1 will be installed
As a result other dev-packages are also broken, because they depend on libxfont-dev, e. g. xserver-xorg-dev
Compiling packages depending on those dev packages, e. g. VLC, is not possible at the moment.
Minimal Kiosk Browser (kweb)
Re: Broken dependencies of dev packages
Wed Dec 14, 2016 11:14 am
Thanks for the report, I'll flag it up.
Wed Dec 14, 2016 11:22 am
OK, this is a known issue and is being worked on right now. Hopefully will be a fix by end of today.
Sorry for the inconvenience.
gkreidl
Wed Dec 14, 2016 11:25 am
I've already opened an issue at github.
Wed Dec 14, 2016 2:27 pm
Problem fixed, tested at RPF, just waiting for it to be propagated to the repos.
spl23
Wed Dec 14, 2016 4:23 pm
Files should be in the repos by now - please let us know if there are any missing.
Thanks for reporting the issue.
gkreidl
Wed Dec 14, 2016 6:25 pm
I had to manually install or update some dev packages but everything worked fine then.
Return to “Raspbian”
