Raspbian has no printer support - sigh.
Well, all is not lost. You just need to go through a few hurdles.
sudo apt-get install cups printer-driver-gutenprint printer-driver-dymoIt may also be a good idea to add myself to the lpadmin group.
sudo usermod -a -G lpadmin karriAnd give a password for yourself to admin printers.
lppasswdYou could change the stock /etc/cups/cupsd.conf to this to get access.
# Log general information in error_log - change "warn" to "debug"
# for troubleshooting...
LogLevel warn
# Deactivate CUPS' internal logrotating, as we provide a better one, especially
# LogLevel debug2 gets usable now
MaxLogSize 0
# Only listen for connections from the local machine.
Listen localhost:631
Listen /var/run/cups/cups.sock
# Show shared printers on the local network.
Browsing On
BrowseLocalProtocols dnssd
BrowseRemoteProtocols dnssd
BrowseAddress @LOCAL
# Default authentication type, when authentication is required...
DefaultAuthType Basic
# Web interface setting...
WebInterface Yes
# Restrict access to the server...
<Location />
Order allow,deny
Allow all
</Location>
# Restrict access to the admin pages...
<Location /admin>
</Location>
# Restrict access to configuration files...
<Location /admin/conf>
</Location>
# Set the default printer/job policies...
<Policy default>
# Job/subscription privacy...
JobPrivateAccess default
JobPrivateValues default
SubscriptionPrivateAccess default
SubscriptionPrivateValues default
# Job-related operations must be done by the owner or an administrator...
<Limit Create-Job Print-Job Print-URI Validate-Job>
Order deny,allow
</Limit>
<Limit Send-Document Send-URI Hold-Job Release-Job Restart-Job Purge-Jobs Set-Job-Attributes Create-Job-Subscription Renew-Subscription Cancel-Subscription Get-Notifications Reprocess-Job Cancel-Current-Job Suspend-Current-Job Resume-Job Cancel-My-Jobs Close-Job CUPS-Move-Job CUPS-Get-Document>
Require user @OWNER @SYSTEM
Order deny,allow
</Limit>
# All administration operations require an administrator to authenticate...
<Limit CUPS-Add-Modify-Printer CUPS-Delete-Printer CUPS-Add-Modify-Class CUPS-Delete-Class CUPS-Set-Default CUPS-Get-Devices>
AuthType Default
Require user @SYSTEM
Order deny,allow
</Limit>
# All printer operations require a printer operator to authenticate...
<Limit Pause-Printer Resume-Printer Enable-Printer Disable-Printer Pause-Printer-After-Current-Job Hold-New-Jobs Release-Held-New-Jobs Deactivate-Printer Activate-Printer Restart-Printer Shutdown-Printer Startup-Printer Promote-Job Schedule-Job-After Cancel-Jobs CUPS-Accept-Jobs CUPS-Reject-Jobs>
AuthType Default
Order deny,allow
</Limit>
# Only the owner or an administrator can cancel or authenticate a job...
<Limit Cancel-Job CUPS-Authenticate-Job>
Order deny,allow
</Limit>
<Limit All>
Order deny,allow
</Limit>
</Policy>
# Set the authenticated printer/job policies...
<Policy authenticated>
AuthType Default
Order deny,allow
</Limit>
AuthType Default
Order deny,allow
</Limit>
<Limit CUPS-Add-Modify-Printer CUPS-Delete-Printer CUPS-Add-Modify-Class CUPS-Delete-Class CUPS-Set-Default>
AuthType Default
Order deny,allow
</Limit>
AuthType Default
Order deny,allow
</Limit>
AuthType Default
Order deny,allow
</Limit>
<Limit All>
Order deny,allow
</Limit>
</Policy>
It is done through your web browser at http://localhost:631/admin
A good tool for handling the labels is LibreOffice writer.
Choose New Label from the menu. You can also use the wizard for creating a list of addresses. And run the mailmerge at print time. This part depends a lot on what kind of printer you have and what kind of labels you are using. So I won't go into all the hairy details.
Merry X-mas
