mad-hatter
"RANDR" missing
Thu Sep 06, 2012 11:39 am
2012-08-16-wheezy-raspbian
Running headless from Windows 7 - (tightvnc)
Various programs I install and start are complaining:
Xlib: extension "RANDR" missing on display ":1.0"
(GParted, QT3, synaptic and others)
Can somebody tell me what I need to install to get rid of this or what I've done wrong?
Regards
bredman
Re: "RANDR" missing
Thu Sep 06, 2012 1:12 pm
RANDR relates to the Resize AND Rotate functionality in X.
Are you using a non-standard display size in VNC? Try starting VNC without specifying a display size and let the RPi pick its own size, then it might not need the RANDR to resize the screen to suit VNC.
mad-hatter
Re: "RANDR" missing
Thu Sep 06, 2012 3:36 pm
Hello bredman,
This is my normal call :- "vncserver :1 -geometry 1265x930 -name Win7 -depth 24 -pixelformat rgb8888", fills screen.
I tried :- "vncserver :1 -name Win7 -depth 24 -pixelformat rgb8888", but display is only about 4/5ths screen size.
Same complaints about RANDR missing.
Could this be anything to do with the Pi memory split, 192MB for the CPU and 64MB for the GPU.
Regards
Mortimer
Re: "RANDR" missing
Thu Sep 06, 2012 5:08 pm
I get the same error popping up when opening up X windows sessions over SSH from my MacBook Pro (My Topic). It doesn't seem to stop it from working though.
sixbacon
Re: "RANDR" missing
Wed Jun 12, 2013 7:57 pm
I only got this problem after upgrading from tightVNC 2.6.4 to 2.7.7.
sixbacon
herwin
Re: "RANDR" missing
Tue Aug 13, 2013 11:35 pm
bredman wrote:RANDR relates to the Resize AND Rotate functionality in X.
yes, I also experienced the same thing, what’s the solution??
thanks
THOR_bot
Re: "RANDR" missing
Tue Mar 29, 2016 6:57 pm
Yes, where the solution is?
THOR_bot
Re: "RANDR" missing
Thu Mar 31, 2016 12:04 pm
Some body have the solution about this problem?
Plz
mbrown956
Re: "RANDR" missing
Thu Jul 14, 2016 10:10 pm
Tightvnc does not appear to support xrandr. Vnc4server does.
Uninstall tightvncserver and install vnc4server.
guillermoarreola
Re: "RANDR" missing
Wed Jan 25, 2017 11:55 pm
somebody knows how instal vnc4server ??
guillermoarreola
Re: "RANDR" missing
Thu Jan 26, 2017 12:02 am
mbrown956 wrote:Tightvnc does not appear to support xrandr. Vnc4server does.
somebody knows how to install vnc4server on a raspberry??
Mortimer
Re: "RANDR" missing
Fri Jan 27, 2017 6:41 am
Perhaps...
sudo apt-get vnc4server
mickymcline
Re: "RANDR" missing
Fri Oct 20, 2017 10:51 am
sudo apt-get install <app name to install>
Guneshs
Re: "RANDR" missing
Sun Dec 31, 2017 5:00 am
use "vnc4server"
There will be no errors . :D
Return to “Raspbian”
Who is online
Users browsing this forum: No registered users and 16 guests
