furriephillips
Why is Jessie asking for a password?
Sun Nov 06, 2016 10:14 pm
I have been banging my head against this problem for a few days, now.
Downloaded https://downloads.raspberrypi.org/raspbian_latest and wrote the .img to a 32GB MicroSD card. I mounted the card on my Backbox laptop & altered /boot/ config.txt & cmdline.txt (as per the instructions on http://blog.gbaman.info/?p=791), unmounted the card, plugged it into my Raspberry Pi Zero & plugged the Pi0's USB port into my laptop. I tweaked the laptop's network config, to share its connection with the Pi0 & can see that the Pi0 gets an IP address: -
% ifconfig enp0s20u1
enp0s20u1 Link encap:Ethernet  HWaddr 5e:95:da:6b:6a:52
          inet addr:10.42.0.1  Bcast:10.42.0.255  Mask:255.255.255.0
          inet6 addr: fe80::1b10:3e40:e674:b15a/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:245 errors:0 dropped:0 overruns:0 frame:0
          TX packets:415 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:22393 (22.3 KB)  TX bytes:66388 (66.3 KB)
When I try to ssh to this IP, I get permission denied messages (using the pi:raspberry combo & even when using known incorrect passwords): -
% ssh [email protected]
[email protected]'s password:
Permission denied, please try again.
Permission denied (publickey,password).
I even tried mounting the SD card and adding my ssh key to the pi user's ~pi/.ssh/authorized_keys, as I have in my existing Pis, to no avail.
I hope I don't get too much flack for thread stealing, but I think it's the same scenario, or as near as dammit, so may help.
Cheers,
ChrisP
rpdom
Re: Why is Jessie asking for a password?
Mon Nov 07, 2016 6:52 am
furriephillips wrote:I have been banging my head against this problem for a few days, now.
That address isn't the Pi. It is your laptop. The Pi is at the other end of the connection and will have a different address, also starting with 10.42.0. Try ssh [email protected] for a start. (I approve of the choice of a .42 subnet :-) ).
You will! That's one of the main forum rules here. I'll tag it and ask the mods to split it off into its own thread.
It's easier to just start a new post if you are unsure.
Return to “Raspbian”
