mapomme1108
Hauppauge WinTV NOVA stick does not find channels
Sat Nov 05, 2016 6:32 pm
I have installed TVHeadend on the latest Raspbian
I want to use it with a Hauppauge WinTV NOVA Stick tuner.
The tuner is detected by TVHeadend but when I scan, TVHeadend does not find any channels.
The tuner works fine on a Windows PC.
I don't know what I can do.
Thanks per advanced for your help.
ismael280373
Re: Hauppauge WinTV NOVA stick does not find channels
Fri Nov 11, 2016 6:26 pm
Hi.
Do you use the stick with a cable antenna?? A cable antenna usually helps to find channels for first time. Once channels are stored the cable is convenient but not madatory.
GOD BLESS THE BLUES!!
kghunt
Wed Dec 14, 2016 1:36 pm
I know this is an old case but I have this exact setup working. i did find that I need to do a "force scan" and then all the channels came through.
Hauppauge TV
Tue Dec 20, 2016 1:40 pm
Did you install the required firmware for the NOVA-T stick?
cd /lib/firmware
sudo wget http://linuxtv.org/downloads/firmware/dvb-usb-dib0700-1.20.fw
( from https://linuxtv.org/wiki/index.php/Haup ... VA-T-Stick )
Return to “Raspbian”
