According to the pi, the chipset is, Atheros AR9271.
[ 1610.485399] usb 1-1.2: USB disconnect, device number 4
[ 1610.677498] ath: Chip reset failed
[ 1610.677542] ath: Unable to reset hardware; reset status -22 (freq 2432 MHz)
[ 1610.795179] ath: Failed to wakeup in 500us
[ 1610.806552] ath: Failed to wakeup in 500us
[ 1610.978872] usb 1-1.2: ath9k_htc: USB layer deinitialized
[ 1611.218550] usb 1-1.2: new high speed USB device number 5 using dwc_otg
[ 1611.340058] usb 1-1.2: New USB device found, idVendor=0cf3, idProduct=9271
[ 1611.340094] usb 1-1.2: New USB device strings: Mfr=16, Product=32, SerialNumber=48
[ 1611.340113] usb 1-1.2: Product: USB2.0 WLAN
[ 1611.340137] usb 1-1.2: Manufacturer: ATHEROS
[ 1611.340153] usb 1-1.2: SerialNumber: 12345
[ 1611.896212] usb 1-1.2: ath9k_htc: Transferred FW: htc_9271.fw, size: 51272
[ 1612.132344] ath9k_htc 1-1.2:1.0: ath9k_htc: HTC initialized with 33 credits
[ 1612.345211] ath9k_htc 1-1.2:1.0: ath9k_htc: FW Version: 1.3
[ 1612.345239] ath: EEPROM regdomain: 0x809c
[ 1612.345260] ath: EEPROM indicates we should expect a country code
[ 1612.345277] ath: doing EEPROM country->regdmn map search
[ 1612.345292] ath: country maps to regdmn code: 0x52
[ 1612.345306] ath: Country alpha2 being used: CN
[ 1612.345319] ath: Regpair used: 0x52
[ 1612.353439] ieee80211 phy1: Atheros AR9271 Rev:1
[ 1612.355726] Registered led device: ath9k_htc-phy1
[ 1612.355778] usb 1-1.2: ath9k_htc: USB layer initialized
[ 1752.595343] smsc95xx 1-1.1:1.0: eth0: Failed to read register index 0x00000114
[ 2049.175660] usb 1-1.2: USB disconnect, device number 5
[ 2050.155225] ath: Chip reset failed
[ 2050.155269] ath: Unable to reset hardware; reset status -22 (freq 2432 MHz)
[ 2050.272506] ath: Failed to wakeup in 500us
[ 2050.283980] ath: Failed to wakeup in 500us
[ 2050.430088] usb 1-1.2: ath9k_htc: USB layer deinitialized
[ 2050.669530] usb 1-1.2: new high speed USB device number 6 using dwc_otg
[ 2050.791040] usb 1-1.2: New USB device found, idVendor=0cf3, idProduct=9271
[ 2050.791075] usb 1-1.2: New USB device strings: Mfr=16, Product=32, SerialNumber=48
[ 2050.791095] usb 1-1.2: Product: USB2.0 WLAN
[ 2050.791119] usb 1-1.2: Manufacturer: ATHEROS
[ 2050.791135] usb 1-1.2: SerialNumber: 12345
[ 2051.428351] usb 1-1.2: ath9k_htc: Transferred FW: htc_9271.fw, size: 51272
[ 2051.664467] ath9k_htc 1-1.2:1.0: ath9k_htc: HTC initialized with 33 credits
[ 2051.898854] ath9k_htc 1-1.2:1.0: ath9k_htc: FW Version: 1.3
[ 2051.898895] ath: EEPROM regdomain: 0x809c
[ 2051.898908] ath: EEPROM indicates we should expect a country code
[ 2051.898924] ath: doing EEPROM country->regdmn map search
[ 2051.898939] ath: country maps to regdmn code: 0x52
[ 2051.898954] ath: Country alpha2 being used: CN
[ 2051.898966] ath: Regpair used: 0x52
[ 2051.921584] ieee80211 phy2: Atheros AR9271 Rev:1
[ 2051.923442] Registered led device: ath9k_htc-phy2
[ 2051.923476] usb 1-1.2: ath9k_htc: USB layer initialized
Edit2:decided to try something, plugged the wifi adapter in direct and it's "holding up" for now, it hiccuped once, but it's a lot more stable than it was before. It was plugged in via the small cord it came with originally.
