can't get VNC server enabled on boot
Posted: Sat Sep 01, 2012 12:43 am
by mushuuu
Hey, i tried to manage to get tightvncserver started on boot but i failed, here's what i did :
created VNC.sh :
#/bin/bash
vncserver :1 -geometry 800x600 -depth 16 -pixelformat rgb565
modified /etc/rc.local : added :
/home/pi/Desktop/VNC.sh
but my vnc viewer won't connect until i start vncserver manually. Any idea to get it working folks?
Thanks in advance.
Re: can't get VNC server enabled on boot
Posted: Sat Sep 01, 2012 5:38 am
by LetHopeItsSnowing
I dont know why your script isn't working but I've had problems getting stuff started using local.rc, and found init.d scripts more a reliable way of starting services, they also ensure services are shutdown correctly too.
See http://stuffaboutcode.blogspot.com/2012 ... p.html?m=1 for info on how to startup services using init.d scripts.
LHIS
Posted: Sat Sep 01, 2012 8:30 am
by mushuuu
Alright i followed the tutorial,
I came up with this :
#!/bin/sh
# /etc/init.d/vnc
vncserver :1 -geometry 1024x600 -depth16 -pixelformat rgb565
case "$1" in
 start)
  echo "Starting VNC server"
  vncserver :1 -geometry 1024x600 -depth 16 -pixelformat rgb565
 stop)
  echo "Stopping VNC Server"
  vncserver -kill :1
  echo "Usage : /etc/init.d/vnc {start|stop}"
  exit 1
esac
exit 0
Integrated it in the system with :
sudo update-rc.d vnc defaults
Made sure it worked well with start/stop.
Tried to add a number after "defaults", same result.
But my VNC client still won't connect when my raspi reboot.
Posted: Sat Sep 01, 2012 6:40 pm
by mushuuu
I edited my script with
touch /home/pi/Desktop/testatlaunch
instead of the vncserver and stuff line and it worked.
Therefore i'm pretty sure that my problem is related with the fact that Raspi doesn't start "by default" with a desktop enabled.
I used raspi-config to have a dekstop on boot already, so the solution is not here.
I also tried to update-rc.d it with "defaults 99" at the end, same result.
Any advice ?
Posted: Sun Sep 02, 2012 7:54 am
by Wendo
You shouldn't have to give vncserver any command line options.
I've got it happily running at startup on raspbian, startup script below
#! /bin/sh
### BEGIN INIT INFO
# Provides:          tightvncserver
# Required-Start:    $syslog
# Required-Stop:     $syslog
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: vnc server
# Description:
### END INIT INFO
# Carry out specific functions when asked to by the system
case "$1" in
  start)
    su pi -c '/usr/bin/vncserver'
    echo "Starting VNC server "
  stop)
    pkill vncserver
    echo "VNC Server has been stopped (didn't double check though)"
    echo "Usage: /etc/init.d/blah {start|stop}"
    exit 1
esac
exit 0
Posted: Sun Sep 02, 2012 6:23 pm
by mushuuu
Solved, guess i was too much noob to debian to succeed by myself.
I love you so much,
Thank you.
Posted: Tue Jan 07, 2014 9:03 pm
by munklefish
Please elaborate on how you resolved this.
