PokeEngineer
OpenGL Driver screen issues
Sat Oct 01, 2016 3:54 am
I'm having some issues when enabling the OpenGL driver. When enabling then after rebooting, the edges of the screen spill over... Any ideas? (Guess I know why they call it "experimental"...)
Don't sweat it.
When in doubt, take a BYTE out of life.
8-)
al887
Re: OpenGL Driver screen issues
Sat Oct 01, 2016 9:52 am
Sounds like a driver problem.
Aleks J. Vinson
Certified Java Developer
http://www.java-forums.org
PokeEngineer
Tue Oct 04, 2016 9:13 pm
Can somebody actually help me?
(I'm not the best with patience...)
Don't sweat it.
8-)
treeHouse
Wed Oct 05, 2016 11:50 pm
What type of monitor and resolution?
Is it HDMI?
pfharlock
Sat Oct 08, 2016 2:03 pm
I'm having a similar issue, the experimental gl driver used to work great for me, when I updated to the latest raspbian with pixel any time I enable the driver the pi get's to the first few lines of the boot screen and then refuses to boot. I've also tried with a fresh image, same problem.
Good luck, when it was working I had good luck wtih the driver, allot of games played great under it.
PokeEngineer
Sat Oct 08, 2016 2:39 pm
It is a Vizio 22" HDTV Model M220VA in 1080p HD.
And yes, it is connected via HDMI.
Don't sweat it.
8-)
spl23
Sat Oct 08, 2016 8:30 pm
The GL driver currently ignores overscan/underscan settings, which is what is causing your problem. As we said, it's experimental - it's not finished yet! Work is ongoing to complete it, which will include having it respect overscan, but for the time being, your only option is to find a different monitor which will work properly with the fixed overscan in the GL driver, or to turn the GL driver off and use the Underscan option in Raspberry Pi Configuration to get your desktop to line up with the edges of your monitor.
We are working on improvements to the GL driver at the moment, but I'm afraid I can't as yet give any concrete timescale for when this will be fixed.
PokeEngineer
Sun Oct 09, 2016 1:23 am
Well, hopefully you get that fixed soon since I don't have the resources nor time to get a new monitor...
Don't sweat it.
8-)
PokeEngineer
Sun Oct 09, 2016 1:26 am
And to prevent it from refusing to boot when enabling, I had to not immediately reboot but to shutdown instead.
Don't sweat it.
8-)
cjan
Sun Oct 09, 2016 2:17 am
if you are in Pixel, try to disable Plymouth splash.
spl23
Sun Oct 09, 2016 10:18 am
RetroPieNerd wrote:Well, hopefully you get that fixed soon since I don't have the resources nor time to get a new monitor...
In that case, I would strongly recommend you just don't try to run the OpenGL desktop driver. We've never claimed that it is finished and ready to use - far from it - that's why it is very clearly labelled as "experimental".
At some point in the future, it will become the default desktop driver, but we are not at that point yet, and we have a very limited amount of software resource to throw at everything we need to do. The OpenGL driver is not a priority for the majority of users, as unless you need to run OpenGL software, it offers no benefit over the standard driver, and given the Pi's primary remit as an education / embedded platform, there aren't many applications people need to run that need OGL.
PeterO
Sun Oct 09, 2016 10:27 am
spl23 wrote: and given the Pi's primary remit as an education / embedded platform, there aren't many applications people need to run that need OGL.
You seem to be arguing against it, so why is the RPF spending effort on it at all ?
PeterO
ghans
Sun Oct 09, 2016 12:07 pm
AFAIK Broadcom (Avago) are financing it , not the Foundation.
ghans
PeterO
Sun Oct 09, 2016 12:12 pm
ghans wrote:AFAIK Broadcom (Avago) are financing it , not the Foundation.
ghans
Well I must admit I thought it was, but when Simon put "and we have a very limited amount of software resource to throw at everything we need to do. " I wondered if that situation had changed ?
PeterO
ghans
Sun Oct 09, 2016 12:20 pm
The foundation tries to make their official images to be at least semi-stable , but i guess
Mr.Anholt work and the rest of the Kernel move too fast ?
ghans
pfharlock
Sun Oct 09, 2016 1:13 pm
Well, just to say it, I appreciate everything the foundation is doing. Great work guys, please keep it up. I'm sure you guys will work out the kinks with the gl driver, I think it will be a great thing for the community when it's ready. Thanks for the suggestion about the splash screen, I will give that a try, now that you mention it, that seems like a likely source of the problem.
spl23
Mon Oct 10, 2016 10:44 am
PeterO
Because, as I said above:
spl23 wrote:At some point in the future, it will become the default desktop driver...
spl23
Mon Oct 10, 2016 9:23 pm
ghans
PeterO
The driver itself is being worked on by Broadcom. Its integration with the Raspbian image is being worked on by Raspberry Pi. Neither part is trivial in terms of effort required...
PokeEngineer
Mon Dec 19, 2016 2:25 am
Sorry I did not tell you this sooner, I was trying to play a little bit of Minecraft for Java based off these instructions.
Don't sweat it.
8-)
RichardRussell
Sat Feb 11, 2017 4:22 am
spl23 wrote:The GL driver currently ignores overscan/underscan settings, which is what is causing your problem.
In that case I think there's a misunderstanding about what 'overscan' and 'underscan' mean. My monitor displays nothing (black) when the GL Driver is enabled, which suggests that the HDMI signal is out-of-spec. But overscan/underscan shouldn't change the HDMI parameters (the 'raster' in traditional terminology) they should scale the video within the raster.
I could live with the picture being cropped, or having a black edge, but obviously having no picture at all makes the GL Driver unusable for me. I hope it may be possible to fix this fault soon.
Richard.
cjan
Sat Feb 11, 2017 5:44 am
have you try update to 4.9? there are big update firmware VC4 etc.
RichardRussell
Sat Feb 11, 2017 11:09 am
cjan wrote:have you try update to 4.9? there are big update firmware VC4 etc.
If 4.9 is only currently available as 'BRANCH=next' then no. A bit scary for me, but I might try it!
Richard.
Sat Feb 11, 2017 11:15 am
Most of the firmware updates are also done in the 4.4.48 master branch. You may not have to get the 4.9.9 kernel.
spl23
Sat Feb 25, 2017 7:46 pm
Richard.
I didn't say that the fact that the driver ignores over/underscan settings is what causes *your* problem - I said it was what was causing someone else's problem...
Over/underscan does not currently change the HDMI parameters at all, as there is at present no ability to change the over/underscan setting with the GL driver - the setting to adjust this for the standard driver is ignored by the GL driver - which means that if your monitor is not expecting the signal as produced by the driver, the picture will not fit onto the screen properly.
The experimental (and I stress that word again) driver is not as yet compatible with all monitor sizes and aspect ratios - for example, it produces a black screen on my PiTop, because that is an example of a screen resolution with which it is incompatible. Before we make this the default driver - and that point is some time off - we will fix these issues. But as above - it is still in the experimental stage, so expect glitches. By all means report them, but please don't expect them to be fixed in the near future!
marcelp1
Thu Apr 27, 2017 11:02 am
Richard.
Hi spl23,
I wonder if there is any way to get the screen working on Pi-top with just Jessie Lite installed on the card, instead of Pi-topOS?
Return to “Raspberry Pi OS”
