Diaoul
/opt/vc/lib no more in libraries searched paths (bug?)
Fri Aug 31, 2012 6:07 pm
I recently updated my RPi and it seems that now /opt/vc/lib isn't in the default searched directory for libraries.
IMO it should be, as Raspbian is shipped with those libraries there should be included. Forcing RPATH is a bad design. I think this is a bug and should be fixed ASAP.
If it's not, could you tell me the correct way to do a .deb with binaries that use stuff in /opt/vc/lib?
TarjeiB
Re: /opt/vc/lib no more in libraries searched paths (bug?)
Sat Sep 01, 2012 3:54 pm
I noticed this too; quite annoying and broke many of my scripts.
I put in "export LD_LIBRARY_PATH=/opt/vc/lib" in my .bashrc and my scripts for a quick and dirty fix...
recliq
Mon Sep 03, 2012 10:08 am
I think a maybe cleaner solution is to create a file /etc/ld.so.conf.d/vc.conf
and put the path in there:
echo '/opt/lib/vc' > /etc/ld.so.conf.d/vc.conf
After that you should reboot or run ldconfig.
TarjeiB
Mon Sep 03, 2012 2:13 pm
Thanks, that is a better solution for sure - but why did it break in the first place?
plugwash
Mon Sep 03, 2012 5:03 pm
asb, can you please comment on this.
asb
Mon Sep 03, 2012 5:10 pm
I've been unable to reproduce it, but do seem to have had a similar report from Dom. I've certainly not made any changes to /etc/ld.so.conf.d/vmcs.conf
TarjeiB
Mon Sep 03, 2012 5:51 pm
I edited 00-vmcs.conf manually, and now it works again. Just deleted it all, retyped and ldconfig.
Did it happen on edit? Did it happen on ldconfig? I don't know - maybe ldconfig isn't doing what it should on reboot?
Licaon_Kter
Wed Sep 05, 2012 10:21 am
I got this too, sometimes, but I'm messing around with kernel re-compiles so maybe this has something to do with it. A reboot seems to fix it. Strange stuff.
BFQ+BFS or RT on a RPi? 4'real: https://github.com/licaon-kter/ (source and compiled!)
Return to “Raspbian”
