How to install XBMC?
Posted: Wed Aug 29, 2012 4:26 pm
by Superman1001
when i try to install xbmc i get this:
[email protected]:/home/pi# apt-get install xbmc
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 xbmc : Depends: xbmc-bin (>= 2:11.0~git20120510.82388d5-1) but it is not installable
        Depends: xbmc-bin (< 2:11.0~git20120510.82388d5-1.1~) but it is not installable
        Recommends: python-qt3 but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
what have i to do?
Re: How to install XBMC?
Posted: Fri Sep 14, 2012 4:36 am
by onirrapdivad
I have the same problem...
Posted: Fri Sep 14, 2012 2:07 pm
by Licaon_Kter
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install -f
output?
Posted: Fri Sep 14, 2012 5:30 pm
by onirrapdivad
I have done the first two steps before,
What does "sudo apt-get install -f" mean?
Posted: Fri Sep 14, 2012 5:33 pm
by redhawk
-f probably means "forced" even if there are errors regarding the request.
Richard S.
Posted: Fri Sep 14, 2012 5:40 pm
by abishur
Just to make sure, you are using Raspbian correct? And the latest image that is obtainable off the downloads page? And you have the latest firmware (well apt-get update && upgrade should get you that, but I like using hexxeh's rpi-update tool just to be safe)
Posted: Fri Sep 14, 2012 6:50 pm
by plugwash
The debian XBMC packages are not built in raspbian and even if they were they would not be much use.
Various people have prepared Pi specific XBMC packages but they are not currently included in raspbian itself (they may be in future but there are other issues that need to be dealt with first).
Posted: Fri Sep 14, 2012 8:21 pm
by onirrapdivad
plugwash wrote:The debian XBMC packages are not built in raspbian and even if they were they would not be much use.
Why wouldn't the packages be of much use?
I used synaptic to find the packages, they are there but I always get an error when I try to install them; something to do with broken packages.
Could you link us to a discussion which explains the issues which you speak of?
Posted: Fri Sep 14, 2012 9:41 pm
by ghans
Posted: Fri Sep 14, 2012 10:01 pm
by mattanl
I installed XBMC using this link
http://www.raspbian.org/RaspbianXBMC
It took few hours (because it downloads the XBMC source code and then compiles it) but it worked.
Posted: Sun Sep 16, 2012 6:10 pm
by onirrapdivad
mattanl wrote:I installed XBMC using this link
Has anybody else had success with this method?
Posted: Sun Sep 16, 2012 7:52 pm
by MvK68
Yep, several times!
